tinman
Pirate88179
Quote from: tinman on June 26, 2015, 09:17:49 PM
I guess you dont see the blocking diode on coil A,and the position of the connecting wires of coil B.
That is because coil A is not charged from coil B.
I will make this simple for you. Get your self a bucket that will hold water-this will be your cap.
Now get two garden hoses that are connected to two different taps-tap A and tap B. Turn both taps on so water is flowing out of each hose,and into the bucket.
Question 1-Is the water from tap B flowing through tap A before it is collected in the bucket?
2-Can the water from both tap A and tap B flow into the bucket at the same time without flowing through each other first?
Now lets put a T piece in the hose coming from tap A,and we will connect the hose from tap B into that T piece,so as now the water from both tap A and tap B will flow through the same hose to get to the bucket.
Question 1-If tap A is turned off(the blocking diode),can the water from tap B flow through tap A to get to the bucket?
2-If water is flowing from tap A and tap B,will the water from tap B flow through tap A before it gets to the bucket?,or will the water flowing from tap B turn in the direction of flowing water from tap A at the T piece,and flow into the bucket along with the water from tap A?.
Contrary to belief,rocket science really is very simple.
Brad:
Excellent, precise analogy here.  If this applies to your circuit, including the "black box", then it makes a lot more sense to me now.
Thanks for posting this.
EMJunkie
Quote from: tinman on June 26, 2015, 09:31:08 PM
And where or how did you come up with that?
We both agree that a higher energy state can be achieved from a lower energy state,but weather or not that higher energy state can do more useful work than was used to create it is yet to be seen.<-- this is in reference to my gas/two tank combo experiment in the !open systems! thread.
The best thing to do EMJ to show MarkE he is wrong,is to show him your system working in an OU mode.
@Tinman - I have had lots of suggestions along these lines.
Like I said, I have to save the best till last, to protect myself, all my hard work, my investment in Time!
As you're doing with yours!
Where do you think this excess "Energy" comes from? Its not from the Input! Is it?
Something for you Tinman, The "Magnetic Field" is Nature's Battery! Storing Conserved Energy in this field! To properly understand a Magnetic Field, is to properly understand Energy!
Why is it Conserved? How is it Conserved?
Let me ask you, If we could take all the Energy out of a Magnetic Field instantly, what would happen? Wow, Mind blowing isn't it!!!
   Chris Sykes
       hyiq.org
synchro1
The arrow in the symbol of the diode points to the direction of the conventional current (flow of + charge).
tinman
Quote from: EMJunkie on June 26, 2015, 09:52:36 PM
   Chris Sykes
       hyiq.org
If you take all the energy out of a magnetic field in one instant,then you would have less energy than what it took to create that field. you would also have a piece of material that in now as good as a bolt sitting in your parts tray.
Why would you want to remove that field?,why not let the field serve it's purpose within the device.
If we were to use say a PM,then would it not be better to neutralize that PM's field until such time as it is needed to provide a force?--both mechanical !and! electrically.
