seychelles
TK YES IT CAN BE PROVEN THAT A BIFILAR ELECTROMAGNET IS STRONGER
THAN A NORMAL SOLENOID ELECTROMAGNET. EASY TO PROVE TKAE 3 METRES OF A GAUGE WIRE
AND WIND IT A BOLT. THEN ON ANOTHER BOLT SAME AS BOLT X WIND THE 3METRES OF WIRE OF
COURSE IT WILL BE 1.5 METRE IN BIFILAR AND TEST THE MAGNETIC FIELF STRNGTH.. WITH THE SAVE
PRESET VOLTAGE AND LET US KNOW THE ANSWER. TK MATE..SO TK HOW DID YOU GO WITH YOUR TEST
BED MOTOR WAS I VINDICATED..
That's a nice big installation all right. It wouldn't last very long around here, though... we have golf-ball sized hail that visits us every few years... and stray dogs that would chase the sheep away ... and you'd have to irrigate the grass or it would die in the summer heat...   :-[
But meanwhile, back in the city... here's my preliminary demonstration of the "coil shorting" in this little shunt motor. I short the stator (field) coils through a diode, and then through a car brake light bulb. This is pretty much the same scheme that SEYCHELLES diagrammed some pages back, except I'm only using a single diode and I'm not about to rewind these field (stator) coils without a darn good reason. No, it doesn't keep running if I do the switch thing as in SEYCHELLES diagram -- maybe I need a washing machine motor for that part. But what it does do is pretty interesting anyway. Draw your own conclusions from that.
http://www.youtube.com/watch?v=hvgBkm-QuYc
seychelles
SO MIMI WHAT THE HECK ARE YOU DOING ON THIS FORUM..
THIS FORUM IS FOR BELIEVERS NOT DOUTERS,NO SKEPTIS,
OTHERWISE GO AND BUILD AN ATOMIC POWER STATION THAT
IS OVERUNITY.. THE SUN IS OVERUNITY. THE UNIVERSE IS OVERUNITY
THE FIRE THAT BURNS BENEATH YOUR FEET IS OVERUNITY. THAT FIRE
IN THE CENTRE OF THE EARTH IS ACTUALLY FUSION THAT IS WHY HELIUM 3 IS PRODUCE..
AND THE FUEL IS SEA WATER..HEAVY WATER DEUTERIUM..
Quote from: seychelles on July 08, 2015, 07:08:37 AM
Your definition of BIFILAR is clearly not the same as the winding Tesla used in his patent, nor is it the same as we usually use the term here. You have apparently described simply TWO PARALLEL WINDINGS, which of course have LESS RESISTANCE than the single winding using the same amount of wire. Of course when the same voltage is applied, your PARALLEL windings will have less resistance therefore more current flowing and even though it has fewer total turns it may indeed have a greater field strength. This has nothing to do with the Tesla patent.
You can also use a winding style that I call "hairpin bifilar" which is a non-inductive winding--  which results in anti-parallel current flows close together, thus cancelling the magnetic fields, producing no magnetism or inductance if done properly. But the Tesla bifilar, aka series bifilar, style is what I thought you were talking about, since YOU mentioned Tesla in your post. This style does not cancel magnetic fields nor enhance them. DC current through this winding will produce the same field as in an ordinary winding of the same geometry.
minnie
Seychelles,
           go ahead and use your time and money on clothes washing
machine motors.
  Tell me, where is it going to generate all those photons you're
looking for?
   You ought to get about 5kwh. Per sq. mtr/day near the equator.
I get a great deal of pleasure from this forum and have learned a
lot. I'm interested in the people who contribute and their "predictability"
far more than the silly ideas, haven't yet seen anything workable-
but you never know......
