0 Members and 127 Guests are viewing this topic.
MarkE
Quote from: Spilled Fluids on July 15, 2015, 07:35:14 PM
Why do you even entertain this Jovian filbert? We all know that his verbal diarrhea is nothing but nonsense words strung together to make himself look intelligent...alas the effect is negative on that point.
He never responded to any requests for proof or verification of his lame theories on R-G either; just put out a lot of Jovian trolling.
I think it is OK to periodically offer anyone a chance to try and justify their claims.  If they actually have an idea then it gets the idea out there to discuss.  If they are just trolling then it usually doesn't take more than a couple of on point questions to send theim into obvious diversion or full retreat back into the bush.  This time I think it took a grand total of two questions.
Spilled Fluids
Quote from: MarkE on July 15, 2015, 09:08:56 PM
How many chances do you think this monocot deserves with all the troll posts he has spread across the various forums/blogs?
synchro1
@MarkE,
All those redundant questions have been answered by me in triplicate in our past discussions. You labored through more JLN videos. You're just a stinking farce.
MarkE
Quote from: Spilled Fluids on July 15, 2015, 09:18:02 PM
He can squander all the opportunity that he chooses.  It doesn't cost me much to give him a chance at least once in awhile.
Farmhand
I can see multiple ways that a setup like this could be arranged to achieve the effect by deceit. Even by mistake.
If I remember correctly the vacuum cleaner motors I've messed with that look like Tinmans motor all required that I cut the field coils series connections to the brushes.
The standard motors have the field coils hard wired in series with the brushes, I had to cut the coils connections to the brushes then fit wire extensions and terminals to
the field coils and secure that.
It takes more than a quick glance to see the actual coil connections.
When I completely disconnect the field coils and run the motor from just the brushes the field coils are capable of producing very little power, I am confident that there is a mistake of some kind.
Shorting the field coils with a diode does improve the efficiency over just powering the brushes with no shorting but there is no comparison to the motor running in the standard configuration.
Considering the claims of MIB's and stuff I'm calling bunk on the demo's.
There is no reason to believe the drawings reflect the device demonstrated.
So for me there is only a magic show performed, I've seen better magic shows.
