0 Members and 53 Guests are viewing this topic.
Quote from: tinman on September 26, 2015, 08:25:21 PM
EMJ
Could you throw up a schematic for the best performing transformer to date for your setup,and i will put one together today,and post my findings here in way of a video.
Give a list of all the materials needed,along with dimensions,and i will build it to those specifications.
Brad
He won't do it -- because 1) he knows that nothing he has built is actually OU; and 2) when you, of all people, are able confirm that there isn't any OU available from his "design", he'd have to slink away in shame and he'd lose his audience of hopeful believers.
And you and I both know this. He's bluffing, that's all.
tinman
Quote from: TinselKoala on September 27, 2015, 12:51:45 AM
See what you started, Brad? So much for the "Open Source" philosophy. Now any and all false claimants, when challenged for details, can just say "I decline to divulge, just like TinMan did, so long ago."
We all have our reasons TK.
Quote TK:
QuoteThe device was originally designed by Overconfident, who died of a brain tumor (malignant melanoma) several years ago.
The video was put up on YouTube to prove a point to Omnibus and was taken down after only being up for 27 minutes, as soon as Omnibus had seen it.
All copies of the video available on YT are unauthorized, plagiarized and many have been altered in various ways. Someone copied it without permission in the 27 minutes it was up and reposted it and it's all downhill from there.
The device is now lost, but you know where it may be (even if you don't realize it).
Teaching? Yes, undoubtedly. Did anyone learn anything from it? I certainly did.
"If what you think you are seeing appears to violate some physical law or principle, examine your assumptions...."
Out of respect for the memory of Overconfident, I really don't want to discuss it further. It was done to death back in the day, anyhow.
Now i would like to know how you had that thing running,and if it still exist-who has it,what will become of it?
Seems sharing the video is a no no,so i wont share it here.
EMJunkie
How many times have you been asked to provide proof of your claims? You keep bloviating and still refuse to provide any valid measurements in support of your claims.
How many times have you said "good bye"? You keep returning?
The title to this thread is a lie. There is NO FREE ENERGY coming from anything that Chris Sykes has made, can make, or will make. He is a _false claimant_ and simply thrives on the attention he gets here. And he can't even PROVE ME WRONG !!!
TK - I have no wish to prove you wrong!
Your opinions are yours and you are welcome to them, I am not here for you, I am here for one reason and one reason only - To try to help those that wish to be helped. To start a ball rolling that will hopefully, one day, bring a better future for all... I am trying to do my bit...
You say: "simply thrives on the attention he gets" - TK, I have to just shake my head at this statement! If attention was what I was after, then it has been nothing but negative from Page 7 on! But, I am still here, even after all the Insults, attacks and continued Verbal Diarrhea of Distractive Posts that a few Nincompoops are well known for across the entire Internet!
I am most certainly not here for attention! You suggesting that is a display or your true arrogance.
   Chris Sykes
       hyiq.org
EMJunkie
Quote from: TinselKoala on September 27, 2015, 12:56:50 AM
I don't play Poker...
But, hey, please remember, you don't have to keep coming back!!! I am not forcing you, Steffan is not forcing you to keep coming back, even after 354 Pages, 5309 posts, after being asked to leave in the past because of your reputation...
I am not the only one that keeps returning...
   Chris Sykes
       hyiq.org
Quote from: tinman on September 26, 2015, 09:22:57 PM
This is incorrect,and EMJ is correct in that there were flasher units that used resistor capacitor time constants to switch a relay on and off. The speed of this switching could be changed either by changing the value of the capacitor or the resistor. In fact,the unit that used this principle of operation were not only more reliable but safer also. The thermo mechanical flasher unit will also not work with todays LED bulb's,as the current required to heat the spring loaded flip flop switchs element is to low,where as the unit that used the RC time constant to switch will work just as well with LED bulbs as it will with incandescent bulbs. The early adjustable intermittent wiper circuit uses this very same RC relay,where the fixed resistor is change out for a variable resistor to change the time off period between each cycle.
Vortex
Your comments of late are most out of caricature,and i would have thought that some one of your nature and history would have many of these RC type flasher units lying around.The fact is that there were both types,but you insist that there was only one that used the thermo mechanical operation,and that any one that argues against this has pretzel logic ??? .
Below is a pic of a relay that works on the RC time constant.You will see no heating element in there.
Does the attached image that was referenced to in the original posting look like an RC-based or a thermal-based flasher to you?
