0 Members and 44 Guests are viewing this topic.
tinman
Quote from: EMJunkie on November 12, 2015, 03:01:14 AM
On something I have shared before but no one seems to have alluded to any replications or even study of any kind, the Jensen UDT?
Has anyone looked at this device at all here? For there is nothing I can do to help if one does not choose to help themselves!
Tinman, perhaps some thoughts on this device from you if you have time?
   Chris Sykes
       hyiq.org
Yes
Only when you center tap the two windings,will you get any power. There will be no power output available from the end of the two windings,as one cancels  out the other due to the winding directions of the two !search! coils.
EMJunkie
Quote from: tinman on November 12, 2015, 05:00:29 AM
Yes
Sorry Tinman, this is not correct!
Look again from a Magnetic Field point of view and look at how the Magnetic Fields Interact together! I can promise you that an EMF is generated in a perfectly normal fashion!
   Chris Sykes
       hyiq.org
tinman
Yes
tinman
Quote from: EMJunkie on November 12, 2015, 04:37:04 PM
   Chris Sykes
       hyiq.org
Lets just say that we are going through the half cycle that produces the magnetic fields from the primary as depicted below. If A is say ten turns clockwise,and B is ten turns anticlockwise,then no EFM is produced across A B. I do have the core to build this very transformer-if you would like me to build it and show you. You stipulate the turn ratio's for primary and the two secondaries,and i will build it and test it.
EMJunkie
Hi Tinman,
Turns Ratio needs to be approximately 1:3 - Primary:Secondary
Be careful, this setup can very easily damage your equipment!
   Chris Sykes
       hyiq.org
