0 Members and 111 Guests are viewing this topic.
EMJunkie
Post removed. Copyright content issue.
   Chris Sykes
       hyiq.org
tinman
Quote from: EMJunkie on November 28, 2015, 09:35:06 PM
   Chris Sykes
       hyiq.org
EMJ
You do not have to remove things that relate to something that has a copyright on it. The only thing copyright dose is prevent you from making and profiting from that copyright product. This includes the likes of video's and books-these you cannot post in an open forum.
EMJunkie
Quote from: tinman on November 28, 2015, 11:59:25 PM
EMJ
Will do you a deal Tinman - I will share some more data. How about you make it so that others out there get a bit more info on the RT?
   Chris Sykes
       hyiq.org
EMJunkie
Some years back, I created a thread that lost momentum very fast: Reliable and Flexible Switching System - I have already shared my latest unit, back on page 3: My Current Reliable and Flexible Switching System I have made modifications to my unit since then!
No one was interested. To this day, this is my most important piece of Hardware! I suggest you look into such a unit, build it for your self as I have!
Anyway, the point is: Magnetic Resonance
It is possible to build a System that once the right conditions are met, once bought into Resonance will produce effects that can be tapped by means of an Isolated Winding/s.  Some data: (Some of my notes)
5 Volts Input, Duty is 50%
My resonance Frequency is: 1,208KHz
When in Resonance, it gets very noisy - Before Resonance I use Current, it drops off as I move into Resonance. My meter shows no Current draw, no milliamps
I have a sensing Coil on one leg - Voltage on the Coil goes up showing higher Voltage at resonance as one would expect
Input Voltage becomes nearly Sawtooth, Triangle Wave - but is in-fact Square, H-Bridge Switched DC
There possibly might be some symmetrical arrangement with the Magnets here as on the other Coils I could not get this effect.
I suggest you view my early videos on the Fluxgate Magnetometer:
How and Why - A NASA Info Clip
Flux Gate Magnetometer or Solid state Generator
Please Note: When I say Saturation, I meant Reverse Magnetisation and not Saturation.
These Videos show how to Isolate Input from the Output - No Lenz Law Effects reflected back on the Prime Mover. Also I have attached the document from Floyd Sweet again, Magnetic Resonance.
   Chris Sykes
       hyiq.org
P.S: My notes were rough and quick. Taken only as general notes. Earth is necessary or this does not work. Also my initial Meter was a 3 Digit display, only showing 100's in milliamps. Using a second meter, I measured 22ma.
EMJunkie
And so, that is another interesting and effective way to reduce ones Input! The same effect for less than 1 Watt, compared to in the Video, I used approximately: 117 Watts.
   Chris Sykes
       hyiq.org
