0 Members and 171 Guests are viewing this topic.
digitalindustry
Quote from: tinman on December 02, 2015, 02:30:27 AM
http://www.thinkgeek.com/product/1dbd/
this is the part i'm missing to complete my ship.
my mission on this planet is complete.
standby by for termination.
: D
digitalindustry
Quote from: EMJunkie on December 02, 2015, 01:24:11 AM
@Digital,
If you would like some advice, before you build anything at all, I suggest you study in detail How and Why an Electric "Generator" Works. This knowledge will be the most useful information you can obtain. Perhaps in your entire life.
An Inventor once said:
I can not stress this enough! Watching closely what happens in a Dynamo in motion!!!
   Chris Sykes
       hyiq.org
Thank you for this advice i always take good advice -
i'm the 'Build it and if the explosion doesn't kill you, you will learn' type.
agreed , as TM stated we see this 'trend' in nature we'd be silly to ignore nature.
i've even seen a permanent magnet more or less 'portrayed' as so many spinning vortexes. (dynamo's)
I agree with your sense of urgency, (i think it is warranted as i've stated) however my study of this place doesn't warrant probably the same outcomes. we may or may not disagree.
for that you may need a larger set of information, but you can/will gain that in time like anything.
digitalindustry
Quote from: EMJunkie on December 02, 2015, 03:04:23 AM
yes, you see the point I was making.
   Chris Sykes
       hyiq.org
isn't it not the case that with many of these various devices, such as the 'Akula' and the "Barbarossa Leal'  'Don smith' in essence it is using the  'Earth' as the other capacitance plate thus providing that 'disruption'?
this seems rather reasonable especially considering the Barbosa Leal device functions at 50/60Hz
tinman
Quote from: TinselKoala on December 02, 2015, 02:30:29 AM
And yet... the people who believe, and calculate, that the Earth _does_ orbit the sun are able to land robot spacecraft on other planets and moons many many millions of miles away after years of travel along complicated paths, even sending photographs back from Pluto... they can calculate where those moons and planets will be many years in advance and can navigate their remote-controlled vessels to just those places and times.
Meanwhile the folks that don't believe the Earth orbits the sun are doing.... what, exactly?
Relativity, and the choice of an appropriate frame of reference for the task at hand, are important.
Who said they use orbital calculations ?. Have you worked at NASA?. You are confusing planet positions with orbital calculations.
Take a tennis ball in one hand(the sun),and take a golf ball in the other hand(the earth). Now,while walking across the backyard (space)hold the tennis ball(our sun) up in the air,and then take the golf ball(our earth),and rotate that around the tennis ball while you are walking across the back yard. Then draw the path the golf ball took--do you come up with an orbital path,or do you come up with a helical path?.
The fact is,you cannot orbit a moving body,and our sun is moving through space. The only path the earth and other planets take in relation to the sun is  a helical path. Space craft trajectories are based around planet position to the sun,gravitational forces,ETC,-not around there orbital path in relation to the sun.
Watch the video below,and then you'll be full bottles on our path through our galaxy  ;)
https://www.youtube.com/watch?v=C4V-ooITrws
digitalindustry
Quote from: tinman on December 01, 2015, 07:42:46 PM
https://www.youtube.com/watch?v=5Lgkl2EEsVk
just watching  this now 1997 hey?
makes you think doesn't it.....
anyone got any theories on what went wrong?
hey Tinman is that your flat Aubry accent i hear? ha ha
you developed this didn't you? you are a time traveling reptilian. sent to bring us the magic of electricity.
Look a flux capacitor !
details of this experiment:
for any keen experimenters out there.
- this is just a coil wound in 4 segments (like Lucs two)
- each segment is wound opposing to the other, i.e 'left to right' or 'inside to outside'  (however you like to say it)
- and they are connected serial with a cap (polarized in this case) in-between.
- the reason there are 3 caps connected is (obvious because the two wires leading out of the coil are the 'neg and positive' which would then possibly connect to another cap in a  resonate circuit ( haven't go that far)
- in essence i suppose you could say this is a 4` 'series LC tank circuits' connected into a coil with a common core. (straight powdered Fe)
- caps are 100uf
- each segment is about 70 micro h only.
maybe caps are too large will experiment.
other things that could be done, experiment with parallel in the same or similar design, many other things.
