0 Members and 72 Guests are viewing this topic.
wistiti
Quote from: idegen on December 27, 2015, 06:24:21 PM
I love Junkie, but dumber you are a now than  before Christmas.
The best way to prove
The device self running.
no the wall
no damil
no wifi
no electrosmog
Share this stupid idiots ...
this is great!
what is this good for???
I do not understand we its purpose Junkie?.
That is exactly why i did not post so much here...  :(
EMJunkie
Quote from: wistiti on December 27, 2015, 06:33:05 PM
Hi Wistiti,
Yes Idegen is one of Humanity's Let Downs. A professional Driveller!!!
I do not understand
Couldn't be more true!!!
He thinks he is doing a service to humanity - Hahahaha Funny isn't it!!!
   Chris Sykes
       hyiq.org
EMJunkie
Quote from: SkyWatcher123 on December 27, 2015, 04:44:51 PM
Hi emjunkie, thanks for the kind words, though i'm just experimenting and trying to learn more in hopes of making something of more value for me and others.
That is part of the reason i haven't posted, but mainly didn't have much new to share and figured i would just post in the thread i had already.
I'm always watching and learning though, well at least from some. ;)
peace love light
Hi Skywatcher,
Nice to see you're still around!
Yes, it takes a little time, but that's the same with anything in life.
Wistiti has done some excellent work also! I think it really is making an intuitive decision on each device and learn as much as possible from that device. Like I have said, I too am still learning. I try to learn something new every day! One can never know everything.
EDIT: I think it worth saying again, Turns Ratio is important. I am still trying to figure out the best method of working this out.
   Chris Sykes
       hyiq.org
EMJunkie
no the wall
no damil
no wifi
no electrosmog
this is great!
Idegen - Try, I ask you to try, build the last Circuit Wistiti Posted, with a 1:3 Turn ratio - Input:Partnered Output Coils
Use the Equation I posted: E = CVAverage - See: Reply #6599
Record your starting voltages and AH ratings, run the device for 1 Hour, rest the battery's for 1 hour. Record end Voltages.
Post your results.
Will you do it? Or you too Busy at: Exxon Mobil
   Chris Sykes
       hyiq.org
P.S: Also a good read: http://hypertextbook.com/facts/2001/KhalidaNisimova.shtml
EMJunkie
I was thinking last night, from the perspective of a Layman, there is no real rhyme or reason why three Coils, Partnered Output Coils, could "Generate" more Electrical Energy than would typically be seen in a conventional Transformer.
But, wait, a Transformer works on Electromagnetic Induction, its how Transformers Work! Transforming Electrical Energy, from one set of variables to another via means of Electromagnetic Induction!!!
The whole reason I have detailed, through out the entire time line of this thread, the importance of How Electrical Energy is "Generated" - I tried to get the minds of the inquisitive going with such quotes like:
Quote from: EMJunkie on January 16, 2015, 02:20:49 AM
@ALL
Ok, I am going to throw it out there!
How: Charge is Separated!
Charge is Separated, Negative to one Terminal, Positive to the other Terminal.
Why:
In a Generator, the Conductors experience a Force, via the Magnetic Field, and each Charge is pushed to its corresponding Terminal. Charge Separation!
References:
URL: https://www.youtube.com/watch?v=lcGWO_x8tpM and https://www.youtube.com/watch?v=U9m86joRSMg
URL: https://www.youtube.com/watch?v=aaWG_6WCkTA
URL: https://www.youtube.com/watch?v=p1BXNFlIaHM
The same is true in Battery's, Chemical Force Separates Charge!
The same is true in Solar Cells, Chemical Force, induced by the Sun's Rays, Separates Charge!
Lenz's Law is ONLY apparent when Current is drawn from the resulting Charge Separation, E.G; Energy.
So Energy is not Generated at all! It was already there! Not Separated! At rest! Equilibrium!
It is the case, and everyone here should know this, that a Changing Magnetic Field in the Proximity of a Conductor will "Generate" an EMF. But this is not always true!!! There are requirements that must be met for this EMF to be "Generated"!!!
With open eyes, one will easily be able to see what is being said in this quote:
The feedback loop: Previously mentioned, you will more clearly see how the loop functions at the time you see the physical construction of the stationary armature of stator assembly. The underlying principal (forget Millikan's experiment) has been derived in that magnetic effects vary on the square of the current. As the load on the machine increases, the volt-ampere product increases. The rate of flow of charges increases. Quantum mechanics state not all electrons in copper are free to carry charges. Then it's time to set the wheels in motion to free them from binding magnetic forces. Once this is done, conductivity will improve and resistance decrease as we are dealing only with electrons. Copper will not change to another metal as atoms which are mostly empty space would have many electrons to spare anyway. To free enough electrons to effect conversion would require magnetic forces approaching infinity.
What does this mean? Well it is really simple. This is simply taking normal Electromagnetic Induction, giving it a mammoth dose of Steroids and thus now we have TURBO CHARGED Electromagnetic Induction!!!
This I have detailed in my experiment shown in Guidelines to Bucking Coils - Page 14 - I clearly show how the Charges in the Conductor can move very much faster when the Magnetic Field is reduced!!!
This is really important information!!!
All of it!!!
Our Standard theory's are great for what we have today, but are not the full story, we can do so very much better!!! We Humans have a lot more to learn yet!!!
   Chris Sykes
       hyiq.org
