0 Members and 43 Guests are viewing this topic.
synchro1
Quote from: conradelektro on January 31, 2015, 03:34:56 PM
I think the best is to just not answer the postings of Mr. synchro1. An attention seeker will be disappointed once he gets no reply. That works with children and should therefore be the right treatment of a never-grown-up.
Greetings, Conrad
@Conradelectro,
Bootlicker!
Here's the comment from Chris. Pay attention to what he's saying: This is the test Chris asked for, not MileHigh!
@ALL,
About Frequency's, a small experiment:
1: Fuse your input just to be safe first!
2: Slowly drop your running frequency down...
3: Hold in your hand, a small magnet, close to your device.
4: Keep dropping your Frequency until you can Feel the Magnet Jump around.
5: Check all around your device with the Magnet
I found this good to get a feel for what's going on. And, yes easy for the sceptics to go to town here, but it did help me.
Also, on a side Note: Start thinking about the potentials of the Partnered Output Coils! Think about each Coil being a Bucket, How much Water can it hold...
Kind Regards
   Chris Sykes - hyiq.org
   To Reach New Horizons!
P.S: You should hear a Chattering of your device. Aim for around 25 - 40 Hz to do this experiment.
P.P.S: This Experiment is fairly important, so please don't pass it by! Please Run the Experiment and report your Results!  ;)
Wobbulation=The magnet jumping around!
Why can't you run the test Chis asked you too? Clean the poop from your nose and get off your knees to that bigoted bully for a change Conrad!
synchro1
Here's the formula for the resonant harmonics:
"The first zero beat occurred at a point where the magnet rotation frequency was equal to 60 Hz divided by the fourth root of the Golden ratio (= (4/π)2) The next zero beat was at 60 Hz which was no surprise and both amplitudes were about twice the noise level of the 60 Hz hum. The next zero beat was about four to five times the ambient 60 Hz hum level and occurred at the square root of the golden ratio times 60 Hz. This means that the rotation frequency (wobbulation rate) reduced its rate by the amount of being divided by the square root of the Golden Ratio".
        The square root of the Golden Ratio!
conradelektro
I did again the test of the coil with both parts of the secondary (H2 + H3) connected in parallel with R2. The resistor R1 (input) should be in the right place this time:
10 Vpp sine wave from function generator, 2 khZ
Vh = 3.04 V
Vt = 3.28 V
Vr = 3.28 - 3.04 = 0.24 V
I = 0.24 / 100 = 0.0024
Ɵ = 17°
Watt through the primary H1 (input) = 0.0024 * 0.24 * cos(17°) = 0.55 mW
V0 = 0.38
Io = 0.38 / 100 = 0.0038
Watt through R2 (output) = 0.38 * 0.0038 = 1.4 mW
Result: input of 0.55 mW through primary H1 results in an output from the partnered secondary (H2 + H3) through R2 of 1.4  mW.
As you might have noticed, it seems to be an OU result. This stems from the rather high Voltage over the primary of 3.04 Volt. This means that the primary H1 has a much higher resistance (impedance) than the 100 Ohm shunt R1.
The Voltage (RMS) over (R1 + H1) is 3.28 Volt, which means that the Voltage drop over the shunt has become very small i.e. 0.24 Volt, indicating that very little current is running from the function generator into the primary circuit.
In the "normal transformer" situation, the current through the primary circuit is about 10 times higher, due to the very low resistance (impedance) of the primary. The resistance of the 100 Ohm shunt R1 is much higher than the resistance (impedance) of the coil H1 in the "normal transformer situation" (see here http://overunity.com/15395/partnered-output-coils-free-energy/msg436051/#msg436051 ).
I do not understand the measurement, there probably is a measuring error which I can not identify at the moment.
More tests are needed, please do not get excited. I am not an expert and the chance is very high that I made a stupid error.
Would be great if someone else (may be TinselKoala) could make a similar replication. I will switch to the audio amplifier to get a higher input, but it will take time, my free time is limited in the next week.
As I recall, EMJunkie was writing about very little current through the Primary if the secondary is in a bucking configuration. And my last measurements (checked and rechecked) show exactly that. The error is not in my numbers, it must be in the measurement set up.
Greetings, Conrad
synchro1
Quote from conradelectro,
"Result: input of 0.55 mW through primary H1 results in an output from the partnered secondary (H2 + H3) through R2 of 1.4  mW".
Definitive proof that all my allegations about MileHigh are entirely justifiable.
@Conradelectro,
Congratulations! You may be a candidate for the annals of "World Records". 2khz is probably right on a harmonic node. (4/π)2
Quote from: synchro1 on January 31, 2015, 02:09:04 PM
@MileHigh,
Conradelectro's just an ass kisser and you're still completely full of shit! Chris specifically asked the experimentors to examine for "Scaler Activity" in adjacency to the "Bloch Wall" of the "Bucking Coils" down in the Shumann resonant frequency range with magnet detectors. All you "Sting" racketers have done is find more ways to not get any authentic results as usual. Conrad and you both found ways to trivialize this kind magnet excitation demonstrated by Conrad last year in his "Took a Dive" Synchro coil tests.
You are shameless in how disgusting you can be.  What a horrible spectacle you are for everyone to see.  You are not even addressing your problem.  You stop harassing me with your gutter trash mouth.
If you persist in harassing me I am asking people of good will to report Synchro1 to Stefan.
