0 Members and 64 Guests are viewing this topic.
Farmhand
Regardless of the result, it is still a result, good work Conrad for testing this stuff and providing an open source example of the measurements the pitfalls and so forth.
To whoever wants to answer with a solid yes or no and why.
I have a question in the diagram below would it not be acceptable to ground the top of the secondary H2 to the function generator ground and make that end of H2 the neutral of the output then measure the secondary output that way ?
Basically flip his scope connections on the output . But use a thick short wire to make the connection. No good.
Quote from: picowatt on January 31, 2015, 11:06:44 PM
TK,
Here are Conrad's Pin calculations:
Vt is the FG output.
Vh is the voltage at the top of the primary.
Vr is the voltage across the resistor (which is equal to Vt-Vh).
I (input current) is Vt divided by the 100R of the series CSR.
Phase angle not withstanding, Pin to the primary is simply Pin=(Vh*I).
Conrad used Vr instead of Vh.
However, that is (Vr*I), which is the power dissipated in the series resistor, not the primary.
So, if Pin=Vh*I*cos() =3.04*0.0024*cos(17) =6.98mw
PW
What I would like you to clarify is why the differential voltage across the 100R -- the voltage drop Vr --  does not give the current in the entire primary circuit.
John.K1
Tinsel- regarding to your scematic, I would recomend to use seriall capacitor to make it resonance motor,which suppose to be much efficient (some say even OU) and to use the feedback to comparator and increase signal by opamp to maintain the resonance?
Conrad: have you tried to run your scope from battery via inverter- proper isolation from main?
picowatt
Quote from: TinselKoala on February 01, 2015, 01:53:13 AM
TK,
I don't understand this post.
The (differential voltage/100) does indeed give the current in the entire primary circuit.
The error was in also using that same differential voltage, Vr, as the voltage across the primary, which it is not.  The voltage across the primary is Vh.
PW
John.K1
Guys,am still playing with the kunel patent. How is it with the patenting process. Do they have to present functional model to get patent?
Any how, I made the shielding coil from Tesla's bifilar and it seems to be stronger electromagnet.  Now- just wondering how it would looks like to have bucket teslas bifillar coils ;)
