0 Members and 35 Guests are viewing this topic.
Delivered by Oliver Christoph Waldhelm and only dedicated ,solely,to him and nobody other,top secret 8)  DELTA ALERT (commercially by global tecnique use , if other will know and use this Method :) ) :
"stinknormal" transmut(t :-*  if female with to nice legs)er :
DC current to AC-current conversion, internationally common named: INVERTER,inverter
if only direct-direct international common named :converter
latin  vertere : in german : drehen,wenden,wandeln
                        in englisch: rotating/turning and so on ........
In Germany,Physik/Elektrotechnik, GLEICHRICHTER (DC/DC) and (DC/AC) WECHSELRICHTER
                                              DREHSTROMTECHNOLOGIE
                            https://en.wikipedia.org/wiki/Three-phase_electric_power
in Theologie ;)  franko-phonetische Version:   Le Loi,c'est moi ! Trinity
Have a nice weekend-end
                                       OCWL
Utopia Now
Hallo Chris thanks for the patent name and pdf  (Earl Koenig, Patent: US 4806834 )
Quotehttp://overunity.com/15395/partnered-output-coils-free-energy/msg493277/#msg493277
The pictures in the patent  are  the one`s I was looking for ,  but the text  I was looking  for  must have been from an other patent ...  something  about  producing worlds strongest magnetic field ...
But I am happy , Thanks.
Why is CW/CCW important   was your question  ..  you probably want to know  what  my opinion is  about  it  or  what i understand about  it ..
Well  nearly all info  I got from your website :  http://www.hyiq.org/       and video`s  :   https://www.youtube.com/user/SweetSQM/videos
It reduces the Lenz Law effect and therefore Electricity or the waves travel faster than it would do "normaly"  in a wire  I think
If you puls such a coil with DC  you get  this ringing effect I think  ( see picture 3 from Sergey Alexeew )
"It is building energy, it builds it up to a certain level  and than it cuts off and than it cycles back"  Don says
https://www.youtube.com/watch?v=Cr07kI7HhzU#t=3695
"This is your OU looking at you strate in the face"  Don says  But I  still have to understand what the resistor is for  ....   is it the Load  that  has to be there ...
Or maybe I am wrong and it is`not what is on picture 3
I wonder why many devices have apart from a kicking ( pulsed DC )  coil  also a "modulator" coil .
https://www.youtube.com/watch?v=KT2KmdHk_5k    here I am just guessing,  assuming ther is a modulator coil
https://www.youtube.com/watch?v=akhWruQSOZw#t=130   here Fabrice talks about the m.coil
and here a typical setup in this case from  Sergey Alexeew ( see picture 1 and 2)
Is it like the magnetometer :  http://www.hyiq.org/Updates/       that  a small magnetic flux from the Earth North or South  can make a big difference in  a CW CCW coil configuration  where  the extern  Earth magnetic field is, does  the same     as  the modulation coil magnetic field of the OU devices.
Well   next time i will continue probably.
But it is  good that  you asked the question  because  it  makes me try to understand it better.
Utopia Now
EMJunkie
Utopia Now - Great work and research!
On another note, the whole Graham Gunderson MIT Replication has fallen completely flat on its face!!! Both here and over at doggy incorporated where they theive OU.com users for pilfering hard working individuals.
I find this classically funny! Reyuki asked me to leave, then a month later they find out that everything I posted was right, rush to replicate and fall flat on their faces! I wonder why!!!
Far to many know it alls with only a couple hard workers!!! All should be working to replicate, none should be lecturing others on hows its done!
Now what did I say:
Quote from: EMJunkie on May 29, 2015, 06:19:42 PM
A Demonstration will not help you! What will help you, is reading and learning the detailed descriptions I have given you and also putting the Diagrams/Schematics/Animations together.
Wow, how many times do you need to be told, too many damn self proclaimed experts!
   Chris Sykes
       hyiq.org
darediamond
Quote from: EMJunkie on October 08, 2016, 03:58:01 PM
How come you are not showing a complete Bucking coils generator circuit Chris?
What of the Ground connecion which really makes Bucking coils Overunity Gen?
You need to give out everything to help the world.
What should the value of those capacitors be in capacitance?
Time is short - The trick to these devices:
I thought you all would already know and see this? We have covered this many times! Turns vs Magnetic Field and the time rate of change of it.
You must "Generate" enough Electrical Energy to cover losses and some for your output!
If youre not "Generating" any extra energy, then your device is an in-efficient transformer!
Again many times we have covered Faradays Law, E.M.F = -NdPhi/dt
Study this here: http://farside.ph.utexas.edu/teaching/302l/lectures/node95.html
Add more turns slowly to see a result, too many turns is also bad. You have to feel it, work with it, have to see what small changes you make, if they are good or bad. Like I said, this tech is everywhere, nearly every experimenter that made it, uses these ideas and concepts. You have to be willing to work for it! But dont be greedy, this can be very dangerous, thus my comments stay below 5KHz, High Frequency is very dangerous!
My friend Wistiti made his device work in only a few months. Its simple! Cheap!  and works exactly the same as so many other devices out there: https://www.youtube.com/watch?v=RKfr8bwVhkc
Wistiti is a Genius!
We humans need to learn from people like Wistiti! This works, there is no BS to it! The same as Юрий Лиховид (Yuri Likhovid) - Anti Lenz Effect
Thaelin, exact same device:
Many hundreds of inventors have used the exact same techniques! Don Smith - How to Generate Energy - Use the Right Hand Grip Rule to see what Don is Saying!!! - It works, and I have told you how to get there!
   Chris Sykes
       hyiq.org
P.S: If you have paid attention and studied the data, I have released everything you need! There is no secrets here, its all commonsense!
P.P.S: There are a lot of Thieves and Con Artists out there that do not give credit to those they steel from, so be careful with your work! Some are paid to thieve your ideas and develop behind closed doors for their own benefit!
EMJunkie
In the complete scrambling trying to come up with fantastic new theories and explanations new threads have been spawned:
Quote from: ramset on October 01, 2016, 05:40:52 AM
Here it is hoped some Of Smudges work can be shared and discussed for all to ponder, Not certain this is the best spot to post this particular musing
however it is a moderated section so hopefully the discussions will be relevant .
*Snip
Introduction
Graham Gunderson exhibited his "Magnetic Implosion Transformer" at the 2016 Energy
Conference. This device apparently delivered more power out than was supplied. Gunderson
admitted that he did not know why this was so, he had discovered the effect by accident while
experimenting. He did demonstrate waveforms pertaining to input and output, along with a
computed waveform of the flux through the secondary. The input waveform was of a special form
and the transformer output was converted to DC using synchronous rectification that effectively
produced a very short interrupt during which the flux changed sharply. This paper presents an
effect that could explain why Gunderson's device gave those results. Because of its importance in
offering means for extracting energy from ferromagnetic material it has been given the special name
"The Gunderson-Smith Effect".
A significant feature of the transformer is the rapid change of flux during the secondary interrupt
period. This suggested two avenues of enquiry, one being the possibility that energy could be
stored in the compression of the mylar film situated between the two core halves, and that mass
inertia might play its part in slowing down the change in compression when the flux changes value.
During the slow flux change between secondary interrupts the compression would follow the flux,
but in the fast flux change period the core faces would not move hence creating an imbalance
between the magnetic energy and the stored compression energy. After exploring this in some
detail it has been found that this imbalance does not lead to over-unity.
The second possibility relates to the frequency response of the core material where its permeability
can have different values for different rates-of-change of flux. This is much more rewarding and
the following sections explore this in more detail.
*end Snip
experiments are being considered here
http://www.overunityresearch.com/index.php?topic=3345.0
also being discussed here
http://www.energeticforum.com/renewable-energy/20546-magnetic-implosion-transformer-replication-3.html#post293226
respectfully
Chet K
Now I ask you, those that have studied carefully, those that have working devices, do you see anything wrong with this above statement?
It may be worth a read of the attached papers. Some brilliant work by very smart minds, but they are light years away from actually getting a device to work!
What I suggest is go and spend a month read all of Floyd Sweets papers, all of T Henry Moray Papers read all you can find on Lester Hendershot and others that thought logically!
Dont just read the papers, become the Writer when reading! Think as they thought!
   Chris Sykes
       hyiq.org
