0 Members and 90 Guests are viewing this topic.
l0stf0x
Thanks alot for the information EMJunkie, I had no idea ...you saved me time..  ;)
Actually is not my work. I just replicate Wistiti's work.
Even I haven't succeed with proper measurements this setup is very promising.
I will try some different coil setups today. I hate winding coils  :P
Quote from: EMJunkie on October 11, 2016, 05:40:01 PM
Hi l0stf0x - Thanks for reportng your great work!
Sometime back, we did a Battery charge test using the same circuit. This was another of Wistiti's works, orriginally from SkyWatcher I think?
Using standard Battery formula's and proceedures, we did get some good results!
So, This is worth investigating!!! See below Image.
Gyula, please correct me if my calculations are wrong! We did do several experiments and got slightly different results at different stages of these works.
   Chris Sykes
       hyiq.org
P.S: Digital Multimeters are very unreliable at High Frequency and should not be trusted %100, but all in all, good work!!!
EMJunkie
Quote from: l0stf0x on October 12, 2016, 01:26:11 AM
Hi l0stf0x,
I think a Battery Charge Test is a fairly good way to test your current setup before you tear it down!
No need to rewind coils, do more testing with what you have already!
Plug in the Figure into the above equations and this should help you out.
   Chris Sykes
       hyiq.org
P.S: There are considerable losses to Charge a Battery, this can be researched if you require.
l0stf0x
Yeah I ll do more testings before check other coil setups.. Thanks for the advice EMJunkie
Quote from: EMJunkie on October 12, 2016, 01:57:54 AM
Hi l0stf0x,
   Chris Sykes
       hyiq.org
wistiti
It is Nice to see someone else build and play with this circuit!  :)
Good job!
wistiti
May i suggest you for your next build to wind your coil on a hollow core... This way you can slide the ferrite inside for fine tuning.  ;)
By the way the credit for this circuit goes to Skywatcher http://www.energeticforum.com/renewable-energy/19931-bucking-coil-inverter.html
