0 Members and 43 Guests are viewing this topic.
wistiti
Lostfox, have you try with a core in your coil?
l0stf0x
Hi Wistiti, :) not yet, I had that on my mind since the whistle exist at the new poc. So the noise its not from the core.
I will try to fit a core anyway :)
I almost double the secondary turns and the gain increased!!  (full load)(same battery, same voltage)
I got 4 Volt - 0.28 Amps !!
from
3.99 Volt - 0.34 Amps (before adding turns)
there is 6mm gap between primary and secondary, so I think the primary need more turns to get closer to secondary.
I was thinking to change the wire at primaries from 0.8mm to 0.3mm. I got plenty of this wire so the gap will be minimized.
That will raise the inductance of primary and maybe we'll get better results. we' ll see.
Quote from: wistiti on October 23, 2016, 10:03:16 AM
l0stf0x
@ Wistiti, Nope! with cores the gain disappears!
Maybe its not the proper way to place cores but that way we lose the gain.
the circuit consumes 1mA more with the cores! same voltage.
l0stf0x
The core to be productive needs to be between the two (primary-secondary) and not inside the primaries.
So I tried with few laminations between. and the result is much less gain than without just 0.03A less power only.
the laminations need to be oriented 90 degree and to be many too, to see if it has better result. That is impossible with this setup..
there is no enough space to fit that kind of core :-\ this need new transformer or new primaries.
Or maybe I could try placing peaces of thin iron wire between and see the difference.. I know its not the proper core but trying different things may help us understand better :)
wistiti
 :o ok
Thank you for giving us your results!
So as i see it for your device, air core are better... I have personally never try it... I will!!! :)
