0 Members and 109 Guests are viewing this topic.
l0stf0x
Hey Wistiti :), i use the same simple circuit.. with the 2n3055 and the resistor. I haven't made any other circuit yet.
Just build a small version of the air transformer .. :)
wistiti
Ok thank you freind!
Im on it as soon as possible!!!!!!!!!!!
Enjoykin2017
Hello people !!  :D
Always think on so called Magnetic Field like Material substance - Material Magnetic Mass. Only mass can bear the Force Fields of any kind. So any Force Field is Matter in own nature.
In Partnered Output Coils we simple strike 2 Magnetic Fields or 2 Magnetic-masses in anti-phase manner. Tiny process known as Magnetic recconection take in place here - also like in Plasma. And is a source of Free "Energy" or precise Kinetic Magnetic Fields which do a WORK. So AIR GAP is important thing if you experiment with air wound coils in Partnered Configuration. 1mm high or less and nothing of OU effect.
Reg.
Enjoykin
l0stf0x
I builded a small version of the transformer using two ready identical coils from microwave fan and I wounded the two secondaries.. I tested it
For some reason I cannot get current flow in the circuit. :( the meter show zero current!!
like the coils are open!?!? Can someone explain why I get 0 current with primary connected??  ???
So lets see the differences:
The circuit is the same so something wrong with primaries.
the new primaries are:
136.8mH and 134.5mH (389 Ohm and 383 Ohm) - wire width: ~0.1mm
the big primaries of the first build (working transformer) are:
1.95mH both (4.9 Ohm both) - wire width: ~0.9mm
So we have huge diferences here. Those new coils work at 220V. :(
But still I cannot explain the zero current, not even 1 microcurrent ?!?! Nothing! like the circuit is open :(
So lets forget about many turns and lets build a basic 1 layer each coil transformer to re-examine it !
l0stf0x
I made a third one, this time one layer primaries and 2 layers secondaries.
primary 30 +30 turns
secondary 60 + 60 turns
results are 3mA less and 0.1volt more with secondary sorted than open.. So there is gain but much less than the first transformer.
I will do some changes and I ll get back..
