0 Members and 38 Guests are viewing this topic.
EMJunkie
Electrons = Electrons and Ions so I do not miss an Identity. An Atom is a Mass.
Actually Subatomic to be precise, what's an Electron? A Subatomic Particle, making up the Atom, along with Protons and Neutrons, all of which has Mass... An electrical Current is Electrons (Free Electrons, Outer Orbital Electrons) from the Atoms of Copper in our Case. Where One Ampere is 6.24 x 1018 of the Copper Atom's Electrons / Second.
Now who is the Idiot?
   Chris Sykes
       hyiq.org
   Chris Sykes
       hyiq.org
twenty years before tech standart :
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=22&ND=3&adjacent=true&locale=en_EP&FT=D&date=19970102&CC=DE&NR=19522450A1&KC=A1
I hope that you does not -really- expect an answer to this rabulistic question !
I am not here to reflect yourself !
EMJunkie
Quote from: EMJunkie on November 10, 2016, 07:34:25 PM
E.G: Turn Ratio's which by the way is (Between 2:1 and 3:1 Approx - Step Down) - But, the Input Voltage is 312.7 and Output Voltage is only 9.46 Volts (Sync Rectification is the Reason)
So, with 312.7 Volts RMS on the Input, with a 2:1 or 3:1 ratio, we should have had 156.35 (2:1) or 104.23 (3:1) Volts on the Output.
Instead, Graham shows the Spike (As the Electric Field - Voltage) at Sync Rectification Switch off of the Mosfet. This Spike is 700 Volts ish. This DC Wave with the 700 Volt Spike is DC -9.46 or so Volts which is hard to see because of the scale. The Triangle, or Saw Tooth Wave is the magnetic Fields (Opposing)
This big spike is due to the Current Change, from one Partnered Output Coil to the Other, ah'la Time Rate of Change of the Magnetic Field between each coil, Electromagnetic Induction. Sharp Gradient's... John Bedini's Inductive Collapse at SG Transistor Off Time, Fly Back. As Graham said, this happens at Mosfet Switch Off.
Note, this is not the Current, its the Voltage on the Sync Rect side of the Output Coils, The scope Shot below the top Scope Shot shows the Current. The Green Wave is the Output Current.
    Chris Sykes
       hyiq.org
P.S: I still think there is a Measurement Error on Graham Gunderson's MIT - There should be 2x Current Probes on the Output Wires, One Probe on Each Wire, as there is more than 998mA in that Globe, each Coil, Partnered Output Coil will likely have the same, so the Amps Mean should be 2 or so Amps, not nearly one. E.G: Ohms Law: Current (I) = Voltage (V) / Resistance (R), so 9.46 / 7.56 = 1.25132 Amperes. I know that Resistance changes with heat in the Filament, @12.6 Volts the Resistance is 7.56 Ohms, a 21 Watt Globe. So Grahams Output is more than he measured in my opinion.
In my Globe, 21 Watts, @9.46 Volts, my DC Current is 1.4 Amperes So all I can see, is Graham has not accounted for all power on the Output!
EMJunkie
@lancaIV - I have asked you before, please stop posting completely irrelevant rubbish to this thread. Go and start your own thread for that stuff. Please delete your last post.
    Chris Sykes
       hyiq.org
EMJunkie
I should make this point again, the Total Average Power in the Primary Coil is 2.0 Watts - At the same time, the Total Average Power in the Secondary Coil's is 8.378 Watts
That means, that the ONLY coupling from the Input, to the Output, is entirely MAGNETIC in Nature - Electromagnetic Induction
    Chris Sykes
       hyiq.org
