0 Members and 74 Guests are viewing this topic.
EMJunkie
Quote from: EMJunkie on December 18, 2016, 06:24:10 PM
What is a Wire, an Insulated, piece of Electrical Wire?
Comprises of two basic components:
An Insulator
   An Electrical Barrier, an attempt to stop the Conduction of Electricity, with a break down rating.
A Conductor
   A Metallic, Conductive, element of the Wire, where an Open Path for the Movement of Charged Particles can be Invoked. Where a Magnetic moment occurs, a Magnetic Field can exist, or bee seen as the Source of the Magnetic Field, also being susceptible to External Magnetic Fields (sometimes referred to as a Parasitic Inductance).
But, if one wanted to build an Electromagnetic "Generator", using the principles of Faradays Law of Induction, then all one would need to do, is, swipe a Permanent Magnet at 90 degrees to the above Wire, and a Voltage Potential (EMF) would be Induced!
This, apparently from nowhere!
The Source, Charged Particles, the Atomic Structure, the Metallic Structure of the Conducting Element! - (Electrons/Ions) - Charge Separation! The fundamental basis for this lays in the Lorentz Force:
   Chris Sykes
       hyiq.org
Further, all subatomic particles, inside the Copper Wire, with a Charge, which in turn will have a Spin (Spin Up or Spin Down), and a Magnetic Moment associated with it, are susceptible to an External Magnetic Field - Polarisation.
The Polarising of the Subatomic Particles brings the particles into alignment in the desired direction, with the applied Magnetic Field. North to South, North to South.
As the Particles are being Polarised, an open gate for Subatomic Particle movement, known as Orbital Hopping and Free Electron movement can occur. The Wire, because of its insulation, acts as a Wave Guide, where all Charged Particles are Forced in the Direction (F) in the Lorentz Force. B is the Direction of the Externally Applied Magnetic Field, and V is the Velocity of the Moving Field.
See the Below Image:
   Chris Sykes
       hyiq.org
EMJunkie
And so, Electricity is simply, Subatomic Particles, moving with Velocity, this is known as Current, like Water flowing is also known as a Current, a Volume of Subatomic Particles Moving is Current (I), where One Ampere is 6.2 x 1018 Electrons/Second, The Voltage, being the Charge's Potential Difference between the Terminals, Voltage (V).
Over time, Copper can degrade, loosing weight, and often looking burnt. Much of this is put down to heating, but I would put money on it, some is also due to Atomic Changes in the Copper Atoms themselves:
   Chris Sykes
       hyiq.org
Meta
Chris,
The burnt wire is the sign of direct conversion of mass into energy, ie, E=mc2. The wire is now the very best wire to use in an energy machine since it is now contaminated (doped, in science terminology, full of holes).
The mass of the wire which is compressed space, is used up, as it provides the energy in the form of electron (pairs) and these pairs are not moving left or right up and down the length of wire, they spiral up/spiraling around the wire or spiral down/spiraling around the wire at the same time, like two notebook coils holding the paper in the binder. One coil of spiraling electron pairs is positive and the other going the opposite way is negative. One follows the Electron Theory (positive electricity) an the other follows the Hole Theory (negative electricity), the partner of the Electron theory. The tarnished wire is just the evidence of the negative Hole theory operating. The tarnish is the mass of the wires losing mass and being changed to energy or spiraling pairs of electrons.
The mechanism that creates these spiraling electrons stems from Sciences definition of a dimension...A dimension, by definition...is a 90 degree rotation of an electron..ie. once you learn how to arrange coils so they are 90 degrees to each other in 3D or 45 and 180 degrees in 4D, then you can rotate the electron pairs and make them pop out of the wire mass and become energy (electrons pairs), ie E=mc2.
Download Joseph Newman's The Energy Machine book and read how Newmans theory can easily explain what is happening in a wire....the atoms are just acting like spinning gyroscopes, according to Newman. Only the purist of minds can accept such simplicity.
https://archive.org/details/TheEnergyMachineOfJosephNewman8thEdition
cap100nf
To all free energy researchers a Merry Christmas to you all.
A special thanks to Chris for all your hints, very helpful indeed.
Kent /
Utopia Now
Yeahh, I also really appreciate   EM Junkie`s info very much   and  everybody else`s input.
Through the years i also gathered some info ... nothing new  but maybe ordered in a different way  ... about Partnered Output Coils, Donald L Smith,
Zilano, Fabrice AndrĂ©, Kapanadze  ..  and many others.
I put the info: schematics, links, explanations in several Prezi documents.
Here is a link to them   ... You can also download the documents     .. in the Prezi doc.  you can zoom and see video fragments and click on links.
    https://prezi.com/recommend/vwzwag678bmv/
I imagine, visualize : we all here understand and know free energy in 2017  ...  We will be able to replicate some devices  and  develope some of our own
because we comprehend the principles, the technologie the finesses   ...  and  we  are  having  fun along the way,  we enjoy the unfolding of new possibilities,
new connections with positive people  ...  a  new way of living life.
I am Happy
Utopia Now
