0 Members and 173 Guests are viewing this topic.
John.K1
nelsonrochaa
Jeg
Quote from: EMJunkie on December 16, 2016, 03:21:06 PM
Walt Rosenthal shared a similar diagram:
   Chris Sykes
       hyiq.org
Just great example showing  the interaction between magnetic flux, and juice that flows inside conductors. Which at the end, shows that both consist of the same ''material''.
Also, in this circuit case, it would be like a dielectric explosion when switch turns off. Constructive interference between the 90 degrees coils, enhancing more the intensity of the explosion which already takes place even without the horizontal coils.
Hi Chris, thanks for your endless contribution. I wish you and all a happy new year. ;)
EMJunkie
I have met so many good people here and in my time before ou.com. I really enjoy what I do, sharing Concepts, ideas and try to stimulate progress!
Being able to see the progress of others is my reward! Those that are focused, have direction and know where they are looking.
It is true, today we are seeing more progress by individuals than ever before! My problem is that it is not as much as I would like to see. Many have no will to investigate "Where Electrical Energy is Manifested"
Back to our Wire Concept:
If we were to take an analogy, one where we have a single Wire, one that is completely Insulated, with no conductive opening to a Load. A completely Insulated piece of Wire.
This piece of Wire happens to be wound around a Pole Piece of the Stator in a "Generator" with a Rotor at full RPM's.
None of the EMF that is "Generated" in the "Generator", inside the Copper Wire, the Conductor, can escape, all EMF is contained, like Water is contained in a Bucket!
Like the Bucket, if we were to make a hole, in the Insulation/Plastic, then we have an Exit Point for the Electrons/Water to flow.
So, the medium is completely contained Inside the Insulator/Plastic - The Medium being Electrons or Charged Particles inside the Wire, or Water inside the Bucket.
The Magnetic Field is a direct result of the Flow of Electrons, Current (I). A flow of Water is also termed as a Current.
Lenz's Law is Directly a Result of the Magnetic, the Current, switch off the Current, there is no more Magnetic, no more Lenz's Drag, also no Output.
Another way to do this is, Induce another Magnetic, Current then becomes: I = da+ + da- : which is approximately 2x the Current that was initially Induced as Floyd Sweet told us, then the Drag on our Input is reduced, and we keep an Output - Simply by Inducing a third Action. Not normally thought of or even considered. This is Partnered Output Coils.
Picture this Illustration:
The Magnetic Field is increasing with the applied current over time, we have a 3D structure: Electric Field - A Vector Potential.png
There is a Curl, I sometimes refer to this as a Spin, that is directly associated with this Structure: A Vector Potential.png
On top of this structure there is another Symmetrical Structure (Partnered Output Coils), split into two parts, separated by the Bloch Wall: A Vector Potential.png
The Partnered Output Coils are two Coils, with Current (I) that is each traveling in opposite Directions. The initial Structure has Current that is traveling in a Single Direction, so Mathematically: 1 + -1 = 0
If the Current in both Partnered Output Coils is sufficient to keep the Magnetic Field high enough, we have induced a NEW point of Equilibrium. We have manipulated Nature's Yin Yang:
Quote from: Nikola Tesla
Ere many generations pass, our machinery will be driven by a power obtainable at any point of the universe.
Throughout space there is energy. Is this energy static or kinetic! If static our hopes are in vain; if kinetic — and this we know it is, for certain — then it is a mere question of time when men will succeed in attaching their machinery to the very wheelwork of nature.
What is Kinetic Energy: Energy which a body possesses by virtue of being in motion.
Quote from: https://www.brightstorm.com/science/physics/heat-and-thermodynamics/kinetic-and-potential-energy-of-atoms/
Kinetic and potential energy of atoms result from the motion of electrons. When electrons are excited they move to a higher energy orbital farther away from the atom. The further the orbital is from the nucleus, the higher the potential energy of an electron at that energy level. When the electron returns to a low energy state, it releases the potential energy in the form of kinetic energy.
So, any and all Charged Particles that are in motion, including Electrons in motion, are Kinetic... Obtainable at any point in the Universe, yes this is Mass Energy!!!
   Chris Sykes
       hyiq.org
partzman
Quote from: EMJunkie on December 30, 2016, 03:57:21 PM
Partzman - No, you're not "one of those dummies", you led many for a long time! Did all the hard work for others.
Then took your work to a private bench because others persuaded you to, so there was no benefit to the community, just to those that have private access to your private bench.
I believe we are seeing some sort of pattern here now...
I most certainly do not expect anyone to "Fall into Line"! I expect people to use common sense, to make educated decisions. Logical decisions.
The world was shown the best demonstration, with the top of the line "Measurement Equipment" by a skilled and experienced Electrical Engineer - Yes, Graham Gunderson - Yet you of all people ask for proof?
I cannot show you proof of this level, I have budget equipment, my Electrical Engineering Skills are not at Gunderson's Level, I have, however shown for many years proof of concepts, using the exact same configurations, yet you still ask for proof?
YOU are all letting these technologies slip away from you - YOU need to study this with all you have, never let this get away from you like you starting to.
THIS IS SO IMPORTANT!!!
It is the Time Rate of Change between the Coils, which is Electromagnetic Induction that Pumps the Energy we are looking for! It is the Third Coil and the Magnetic Field from it that reduces the direct effect of Lenz's Law back on the Primary Coil which opens the door to increase in Output to Input.
   Chris Sykes
       hyiq.org
P.S: I am very happy to see that this post has stirred up the Pot and got some attention!!! Like I said, this is very important! Our technology is slowly moving away from Transformers and Coils as we see today, moving into solid-state switching and so on, much change we have seen already!!!
The next generation will know very little, and have nearly no experience with Transformers and so on, just like we today have little experience with Magnetic Amplifiers and Saturable Reactors!!!
It is NOW or never!!!
Chris,
I'm not sure what you are referring to when you comment that I have gone "silent".  I continue to post my work on OUR and if there are periods of time with no postings from me, it is because I have hit a wall in my research.  I'm also a little confused by what I am missing technically as you state above.  So, as an example to perhaps remedy your opinions above, I've attached a paper below which discloses one version of my MEI (Magneto Electric Induction) research efforts.  This was openly posted on the OUR forum under my MEI bench for all to see plus all the up to date results of this work as well.
As can be seen, this device has a negative input power of -21.17w or -33.24w referenced to the sinewave on CH1 depending on the source of current measurement.  The output power is a real 33.2w rms.  This is the type of POC that I referred to in my post.  This is fully documented and replicable by those knowledgeable in the art.  Is this device capable of self running?  At this point in time no, but that is the goal of course once certain technical difficulties are overcome.
In regards to Graham G, I openly provided all my work in attempting to replicate his device both on the bench and via simulation.  I personally concluded that no positive results were going to be seen by my efforts unless he were to provide additional info so I quit on the project.
pm
