0 Members and 18 Guests are viewing this topic.
EMJunkie
For a long time, I have suggested a very simple experiment:
Quote from: EMJunkie on May 18, 2015, 08:25:01 PM
Please try a simple experiment!
you will need:
   1: a Coil, 200 or so turns, No Core!
   2: A Neo Magnet
   3: Short the Coil, tie the ends together.
Sweep the Neo Magnet past the Coil, observe the Magnetic Field Interactions. A Dead Short on the Coil will Invoke Lenz's Law and the Fields will (On Neo Entry to Coil Proximity) Oppose each other!
This is SUPER Important to Understand!
Field Opposition!!! Charges in the Coil are already Separated, Current is the Cause of the Magnetic Field (Lenz's law), but the Current was already available, already on the Terminals!!! Waiting to Flow through a Load!!!
Understanding the absolute most basic concepts of Electrical Energy "Generation" is critical!
   Chris Sykes
       hyiq.org
EMJunkie
@PartzMan - In GG's device, you must realise, once the Sync Rect is switched, once the Flow of Current reverses, there is no stopping this flow by Switching the Fet back on again!!!
I have said this before, this switching you have mentioned, is a one shot thing per Cycle!
Quote from: EMJunkie on August 08, 2016, 09:56:26 PM
A test, I have seen this many times here on this forum!!!
What LED's will Light:
   D1: ?
   D2: ?
   D3: ?
Fets as you already know, when off, are only good for a single Direction of Current Flow, not both, we are seeing both directions of Current! Current flow the other way, the Internal Diode will just conduct, there is no OFF on the Mosfet in this Direction of Current Flow!!!
Gunny says at:
Video @1:04:06
We're stuck with a technology that only works in one polarity, but its close, to what he requested in one of his (Nikola Tesla) books.
So this big pulse here, appears when the Mosfet is switched off for a small but precise amount of time. And some of the things in what I call the Chain oscillator here set that time.
So there is a number of delay Circuits, that are arranged in a Ring, and they sort of pass the baton to one and the next, right, so we have one delay creates this wave, and it passes it on the next one, and a third one and so forth, and that branches off to another delay circuit, that looks right here and creates a delay until here (SR Switch off), runs another delay until right there (SR Switch on), and that particular delay turns off the Mosfet on the on the Output Circuit.
When it does, it breaks the Current, there's Flux Imbalance in there, and when the Circuit is broken, the voltage is no longer defined by us, its defined by the Magnetic Field. And the Magnetic Field's want to equalise, like if we just had a fish tank with the water level here and there (Hands showing Water Levels), and a piece of cardboard in the middle of the tank, and then like magic, just make it vanish, what would happen to the water? (Hands show equilibrium of water levels), and so that's what we see in the output current, that's the water sloshing.
Video @1:34:06
He said, I'm just Open Circuiting the Output and that's what's giving me the Spike and the answer is yes.
I think this Critical Point has been missed by many.
   Chris Sykes
       hyiq.org
forest
It is much simpler, and can be condensed into one simple sentence :
magnetic field is the source of energy.
EMJunkie
Quote from: forest on January 02, 2017, 03:35:58 AM
Hey Forest,
I agree, but this is not the source of the Electrical Energy. This, the Magnetic Force, does work on the Charges inside the Copper Wire, to Separate the Charges, pushing the Charged Particles, which have a Magnetic Moment of their own, which also have Mass of their own, to one end of the Wire. This is the Potential Difference in Charge, Voltage.
These charged Particles are a Composition of the Atomic Structure of the medium, in our case Copper.
For example, swipe a Permanent Magnet past a Wire made of Carbon Fibre, No EMF is "Generated"! Only in a Conductive element can Electrons Move!
Floyd Sweet also says the same thing:
Quantum mechanics state not all electrons in copper are free to carry charges. Then it's time to set the wheels in motion to free them from binding magnetic forces. Once this is done, conductivity will improve and resistance decrease as we are dealing only with electrons. Copper will not change to another metal as atoms which are mostly empty space would have many electrons to spare anyway.
Also, please take some time to watch: How Magnets Produce Electricity - 1954 US Navy Training Film
   Chris Sykes
       hyiq.org
forest
Good question, I'd like to know if really induction cannot happen when the 'wire" is just a carbon fibre or carbon rod as used in zinc-carbon battery. Unfortunately I cannot test it.. Could somebody test it and post video on youtube ?
