0 Members and 67 Guests are viewing this topic.
hyiq
Quote from: ramset on February 04, 2017, 07:02:55 PM
Chris
Naaahh
I have to admit that your inspector Clouseau Shtick is more "out there" than I had thought ,
I'm not given you the "out" you wanna fall on your sword and be a martyr ?
so be it ! [but not by my hand ,the "boss obviously hasn't seen your nonsense]
or you could just do what you said you would do two years ago ?
I'm not the guy who came into the Bar and jumped up on the stage and yelled
"Gather round boyz and girls "Overunity !!!
But then the guys who knew how to measure showed up....
is it easier this way "they threw me out" ??
Naaah
Man up Chris
@All - Take special notice of the words used: "they threw me out"...
Now anyone with half a clue will see that this implies TEAM, meaning that Chet K and Stefan are VERY close!!! This of course we already know to be true! A little like Stefan and Arthur Tränkle
I have a Backup Plan, I always do, I am currently on a bender to expose!!!
  Chris Sykes
       hyiq.org
ramset
Chris
Really "they" has significance in this dementia??
Oh I'm sorry... I stepped into your delusion [for your comfort}
or is "your" whole list of "players" above  still only a ruff draft in your head ?
a work in progress
would it not be easier to Man up?
Thanks Grandma
hyiq
Quote from: ramset on February 04, 2017, 07:21:38 PM
Chris
a work in progress
Chet Kremens, you mean something like this:
Quote from: darediamond on January 15, 2017, 03:08:25 AM
Chris is right. Bucking coil when properly connected have no lenz at all and still gives output.
You can all see that my set-up is fucking Crude or rough. But still I get the effect. I loaded the secondaries and still there is no increment at all in the input wattage.
The whole P.O.Cs is covered by the primary.
You need to separate the charge by applying Vladimir Utkin Circuit which he stated in his PDF document under the title "Switchable Iinductance"
I am now moving away from that circuit to test full bridge and earthing circuit to see if I will able to draw current from the Earth Crust with or without Avramenko Plug.
Frequency to the primary from my mechanical switch was under 30hz
Input voltage to my primary was 90 volt DC.
The output wattage I crease as I increase the frequency. But MY LOAD WHICH IS A DC MOTOR DID NOT AFFECT THE INPUT WATTAGE AT ALL. I REAPEAT AT ALL.
Now time to test Bucking  primary and one secondary as come.
I will also test single strand primary coil over the bucking secondary to see if the output watt will drop or not as I notice using neodymium magnet that current flowing in Multifillar wire mimicks AC zig zag or push pull even if the current is DC.
Thank you Chris, Vladimir Utkin, Marathonman, Hanon, Though and all you other people on over unity.com for your selflessness and sincerity
Quote from: Graham Gunderson link=http://emediapress.com/grahamgunderson/mit/
3 Coils, Load, DC Switching(H-Bridge LC Tank) - Overunity: 5.7
Measured on Tektronix Scope X1 and X2 Clarke Hess Watt Metre (Try telling Clark Hess they have bad equipment, they will serve you!!!)
2016 Energy Science & Technology Conference
Quote from: Graham Gunderson link=http://grahamgunderson.com/ou/
3 Coils, Load, DC Switching - Overunity: 1.01
Measured on Tektronix Scope X2
2015 Energy Science & Technology Conference
Quote from: l0stf0x on October 11, 2016, 05:53:35 AM
Hey all, I have build a simple joule thief using bucking coil arrangement that I wound my self.. It looks very productive and I wanted to ask you if this it is "something"! or if its a common result.
Output from secondary coils are passed through a bridge rectifier to have dc for taking measures. (direct from battery VS through the circuit)
The load is 3 leds on a pcb with a BR, few resistors and a mini electr. cap. (Its the head from a hand crank flashlight)
Batery is a 18650
I made some measures..
Direct the load to the battery: 3.70V --- 0.58mA  ---> 0.2146 Watt
Through the circuit:                4.90V --- 93.2mA  ---> 4.5668 Watt
That's 2028% difference..
The loal direct to battery is very very dimmed..
Through the circuit is so bright that you can't see it directly.. near to burn I guess.
Quote from: Mark Balanger Advanced Electronic
https://www.youtube.com/watch?v=CPgnKpScGDA
Published on Dec 4, 2015
This difficult to tune circuit really does work. Once folks try to utilize my method of building and tuning, it will make life a lot easier to get one functioning. A magnet is used to change the flux path of the device once it is powered up, and, it seems that once used in a few different areas, the longer it remains powered and the frequency is found per size of the load, a device will need to be used for eacdh large device we utilize without the danger of being charged for that amount. Since this device uses from the uA to the mA range of idle current it is vital to know it can be used for very large loads such as continuous water or fuel pumps, and, many other devices.  Why aren't we building them for power in our homes ?? The coils use minimal idle amperage like wall wort power supplies, but at a much lower amperage. When we add load, the amperage dropped.  The more we add. The lower it goes. This cost me $2.25 worth of ferrite and copper to make.
Quote from: Wistiti
www.youtube.com/watch?v=RKfr8bwVhkc
Published on Feb 25, 2015
There is my second video on youtube!
In this one i tried the partnered bucking coil presented by Chris Sykes "EMJunky" on an already made toroidal transformer...
The only thing i would like to add is Thank you Chris!!!
Quote from:  Юрий Лиховид
https://www.youtube.com/watch?v=jWzZqw8eLDU
Published on Sep 4, 2015
A little-known "Aharonov-Bohm effect" (1959) is working against the old and known "Lenz's-Law" (1833). The result is an "anti-Lenz" effect.
Soon will be a video: "Anti-Lenz effect - the final version".
Quote from: Thaelin on December 09, 2015, 02:16:31 AM
Yuri did what I did, and got the same results. It baffels you to see it.
Even worse, is when you try to prove yourself wrong and the results
hold rigid.
Now lets see how bad the pack tears this one up.
Independent Replications!!!
  Chris Sykes
       hyiq.org
ramset
Chris
Almost to the last man
your "replicators" still search and search and search for OU
anyone who even casually visits these forums Knows that .
they don't seem to have found it yet ??
Libeling  myself and Your Host Stefan with Lies will not change that.
manning up would ??
Thanks Grandma
hyiq
Quote from: ramset on February 04, 2017, 07:35:14 PM
Chris
Libeling  me with Lies will not change that
manning up would ??
Actions speak very much louder than your meger desperate words Chet Kremens!!! Can you see all those Actions above???
You regularly keep coming back HERE, to this Thread... Why?
  Chris Sykes
       hyiq.org
