0 Members and 176 Guests are viewing this topic.
hyiq
Quote from: tinman on February 10, 2017, 07:20:43 AM
I am referring to the current flow within a PM,that maintains the PMs powerful magnetic field.
Look at the magnet as a pump,where the virtual photons are ejected out one end,and sucked back into the other-just like a water pump draws/sucks water in one end,and forces it out the other.
How do we access this current/energy, that continually pumps these virtual photons in a continual loop.
Brad
I am a little surprised to see so little posts! So little activity!
I have been away for a couple of days, attending to some things, and there is only 4 Posts. but: 7324 thread reads in the last 4 days.
Often when something is discovered, time is needed, to understand and figure out where the absolute most fundamental concepts lay, to "Understand" exactly how a device works. I understand that some will be taking time to go through these steps...
   Chris Sykes
       hyiq.org
P.S: Have you ever seen a more simple, more straight forward, Simple to construct, Cheaper to construct, Free Energy Machine? Three Coils, One Input Coil, Partnered Output Coils, Energy Above Unity!!!
tinman
Quote from: hyiq on February 13, 2017, 12:55:39 AM
   Chris Sykes
       hyiq.org
I have ordered a larger toroid transformer,so as we can reduce measurement error,by upping the power levels being measured.
Also started my new job-back into the truck's.
Will be doing east/west runs this time,so will be away for weeks at a time.
Brad
hyiq
Quote from: tinman on February 13, 2017, 07:25:02 AM
Brad
Hey Brad - You're quite right, the CSA or Cross Sectional Area is a factor where we can improve the over all Induction. Because in Transformers: N = E 108 / 4.44 B A F
Of course this Equation can be rearranged to return another variable if required: E = 4.44 N F B / 108
Where:
   N = number of Turns
   E = EMF or Voltage
   B = Magnetic Field in Gauss
   A = Cross Sectional Area
   F = Frequency (Sinusoidal Hz)
Enjoy the Country Side! Nature's Beauty s breath taking!
   Chris Sykes
       hyiq.org
hyiq
Brad, we talked about some time back, how a Magnetic Field may not be bound to the local region it appears to be confined to, and that it may extend past the local boundary:
Quote from: EMJunkie on September 21, 2015, 06:53:13 PM
@Shylo - No, its Induction!!!
See: http://www.overunityresearch.com/index.php?topic=2760.msg45207#msg45207
Quote from: EMJunkie link=http://www.overunityresearch.com/index.php?topic=2760.msg45207#msg45207
For Everyone: Asymmetric Fields! Next to no Pushing, but at the same time opposition, allowing a force to Attract another Force. An addition to Newtons Third Law! How could this possibly work? Does a Magnetic Field extend past the Repulsive Force of another? Where is it that interaction of Fields are Really Occurring?
   Chris Sykes
       hyiq.org
I really don't like to advertise Over Unity Research because of their behaviour when I went over to them after being hammered by the OU Goons here, they were just as bad as the OU Goons!!! Changed the name of the Thread, demanded Proof, and were not willing to put any effort at all into learning anything of value!!! Just a bunch of spoiled children!!! Who has egg on their faces now??? Independent Replications
I put the top bit about the Fields in quotes because it was important.
Here, in Partnered Output Coils, we see Magnetic Field Interactions well beyond where we would expect to see them. Many Magnetic Fields at the Same Time in the same region of Space, eg: Inside the Core material.
Floyd Sweet, in the Lab Notes, it says:
Once moving, the flux grows and decays at the excitation frequency and apparently induced, by Flux Linking, a current in the output Coils which was in this case measured at 4.6A x 24.2V = 111.32 Watts – measured twice, observed by 3 persons.
This is exactly what we see, Flux Linking, with some Flux Cutting at the same time, and yes of course the Flux has to be moving, this is the Magnetic A Vector Potential! Also, Importantly, we see: "the flux grows and decays at the excitation frequency" exactly as was said!!! In other words, we control the devices with our input Frequency.
   Chris Sykes
       hyiq.org
woopy
Hi Chris and all
As i had a toroidal transformer at disposal, i decided to replicate Wistiti's experiment
Good and encouraging results so far. I hope there is no mistake in the measurement, but i try to be very carefull when we get such efficiency. Of course feel free to correct me if you notice some error.
https://youtu.be/Z3RQkQEv59k
Will reread this thread to better understand what is going on here. But not so much time at the present.
Hope this helps
Thank's to all of you for your work
Laurent
Edit: please read itsu's comment and my answer (next 2 posts). It is very likely that the results on the video is erroneous due to a faulty clamp meter.
