0 Members and 109 Guests are viewing this topic.
gotoluc
Quote from: hyiq on February 18, 2017, 07:38:56 PM
Well Luc, help then, Replicate Wistiti's Work (125%), Yuri Likhovid's Wour (114%), Tinman's Work (118%), Graham Gundersons Work (560%), show your work!
The Time is now Luc, focus your effort on the task at hand and share your results!
Lets see if you really are trying to help, like I hope you are!
   Chris Sykes
       hyiq.org
As you know last year I worked on your stuff for months at Tesla Energy Solutions.
I've just posted to Itsu that I did not find OU from those months of tests.
Again this week I replicated wistiti's toroid test after seeing woopy's video, thinking I could of missed something but again no go.
I see Itsu and maybe others giving it their best shot and why I'm saying we are trying to help.
Keep cool and give a little credit to those that try even if they don't give the results you want to see.
Let's see what comes of it.
Luc
hyiq
For those interested, I built some small Measurement Blocks, a little rough, but work well. Very Simple and very easy. See Below
I was lucky enough to be passed some information, and also a Wattmeter by a very good friend of mine. This information came from an HP Engineer, who worked at High Frequency Measurements many Years ago. The paper work I received was very enlightening, not information that is easy to come by. Perhaps information that should be locked away in Hewlett Packard's Archives somewhere.
So I thank my friend for sharing this with me. I also thank the HP Engineer for sharing his work.
   Chris Sykes
       hyiq.org
hyiq
Quote from: gotoluc on February 18, 2017, 07:57:06 PM
Luc
Luc, perhaps you should go and read the recent posts between Istu and I, maybe even Brads last ten posts, reading your last posts, it appears you are not reading whats going on, perhaps you are not aware of whats going on here?
You see, I have posted a ton of Data pointing out a the amount of detail, that everyone here either does not know or want to point out. Choosing to Ignore!
John Bedini said it best: "Everyone changes things, it wont work if you change it"
I agree, but would like to add, not enough detailed attention is present when people make a replication. I have seen so many time, the most basic things are missed and no attempt is made to try to fix these simple problems. Attention to detail is very important.
So, as you say:
Well, currently, we have a list:
Quote from: proteus on January 07, 2017, 04:10:33 PM
Thanks Chris
Works exactly as you say. I am shocked at how simple this is.
P
Quote from: darediamond on January 15, 2017, 03:08:25 AM
Chris is right. Bucking coil when properly connected have no lenz at all and still gives output.
You can all see that my set-up is fucking Crude or rough. But still I get the effect. I loaded the secondaries and still there is no increment at all in the input wattage.
The whole P.O.Cs is covered by the primary.
You need to separate the charge by applying Vladimir Utkin Circuit which he stated in his PDF document under the title "Switchable Iinductance"
I am now moving away from that circuit to test full bridge and earthing circuit to see if I will able to draw current from the Earth Crust with or without Avramenko Plug.
Frequency to the primary from my mechanical switch was under 30hz
Input voltage to my primary was 90 volt DC.
The output wattage I crease as I increase the frequency. But MY LOAD WHICH IS A DC MOTOR DID NOT AFFECT THE INPUT WATTAGE AT ALL. I REAPEAT AT ALL.
Now time to test Bucking  primary and one secondary as come.
I will also test single strand primary coil over the bucking secondary to see if the output watt will drop or not as I notice using neodymium magnet that current flowing in Multifillar wire mimicks AC zig zag or push pull even if the current is DC.
Thank you Chris, Vladimir Utkin, Marathonman, Hanon, Though and all you other people on over unity.com for your selflessness and sincerity
Quote from: Graham Gunderson link=http://emediapress.com/grahamgunderson/mit/
3 Coils, Load, DC Switching(H-Bridge LC Tank) - Overunity: 5.7
Measured on Tektronix Scope X1 and X2 Clarke Hess Watt Metre (Try telling Clark Hess they have bad equipment, they will serve you!!!)
2016 Energy Science & Technology Conference
Quote from: Graham Gunderson link=http://grahamgunderson.com/ou/
3 Coils, Load, DC Switching - Overunity: 1.01
Measured on Tektronix Scope X2
2015 Energy Science & Technology Conference
Quote from: l0stf0x on October 11, 2016, 05:53:35 AM
Hey all, I have build a simple joule thief using bucking coil arrangement that I wound my self.. It looks very productive and I wanted to ask you if this it is "something"! or if its a common result.
Output from secondary coils are passed through a bridge rectifier to have dc for taking measures. (direct from battery VS through the circuit)
The load is 3 leds on a pcb with a BR, few resistors and a mini electr. cap. (Its the head from a hand crank flashlight)
Batery is a 18650
I made some measures..
Direct the load to the battery: 3.70V --- 0.58mA  ---> 0.2146 Watt
Through the circuit:                4.90V --- 93.2mA  ---> 4.5668 Watt
That's 2028% difference..
The loal direct to battery is very very dimmed..
Through the circuit is so bright that you can't see it directly.. near to burn I guess.
Quote from: Mark Balanger Advanced Electronic
https://www.youtube.com/watch?v=CPgnKpScGDA
Published on Dec 4, 2015
This difficult to tune circuit really does work. Once folks try to utilize my method of building and tuning, it will make life a lot easier to get one functioning. A magnet is used to change the flux path of the device once it is powered up, and, it seems that once used in a few different areas, the longer it remains powered and the frequency is found per size of the load, a device will need to be used for eacdh large device we utilize without the danger of being charged for that amount. Since this device uses from the uA to the mA range of idle current it is vital to know it can be used for very large loads such as continuous water or fuel pumps, and, many other devices.  Why aren't we building them for power in our homes ?? The coils use minimal idle amperage like wall wort power supplies, but at a much lower amperage. When we add load, the amperage dropped.  The more we add. The lower it goes. This cost me $2.25 worth of ferrite and copper to make.
Quote from: Wistiti
www.youtube.com/watch?v=RKfr8bwVhkc
Published on Feb 25, 2015
There is my second video on youtube!
In this one i tried the partnered bucking coil presented by Chris Sykes "EMJunky" on an already made toroidal transformer...
The only thing i would like to add is Thank you Chris!!!
Quote from:  Юрий Лиховид
https://www.youtube.com/watch?v=jWzZqw8eLDU
Published on Sep 4, 2015
A little-known "Aharonov-Bohm effect" (1959) is working against the old and known "Lenz's-Law" (1833). The result is an "anti-Lenz" effect.
Soon will be a video: "Anti-Lenz effect - the final version".
Quote from: Thaelin on December 09, 2015, 02:16:31 AM
Yuri did what I did, and got the same results. It baffels you to see it.
Even worse, is when you try to prove yourself wrong and the results
hold rigid.
Now lets see how bad the pack tears this one up.
   Chris Sykes
       hyiq.org
hyiq
@All - Look, I am sorry, I do get Cranky, and sometimes I might come across wrong, but:
   1: I am here to present my findings from some 7 odd years of Experiments.
   2: My Time here, should warrant consideration, often posting several posts a day.
   3: We have Independent Replications by very credible people!
   4: I am not showing my work, there is no need to, the reason should be very clear - Look at Guyla's last response to my response to Itsu's Phase Shift Question on Parallel and Series Resonant Circuits!!!
   5: Often the people I like, I expect the most from, so I get a bit frustrated with things. I DO respect everyone here and would very much like to see everyone succeed, however this may not be realistic.
   6: If one's results are not what we should be seeing, there will always be a reason, I have tried to help on every occasion, however much of my suggestions go unread, and un-responded to.
   7: I simply would not be here, if I didn't think this was important. I have done the best I can to backup everything of value with references and so on. Cross reference will help you in your research.
This has never happened before, in the history of Energy Machines!!!
So when people come to this Thread and disrupt it as they have for several years, please remember, as many would, I get frustrated. I give my Time, my Experiments, and knowledge all Freely, I have never ever asked for anything in return, except a little effort on your Part!
   Chris Sykes
       hyiq.org
gotoluc
Chris,
As proof of an OU device I would only consider a post that includes a video demo of how Pin and Pout was measured.
I've looked at all the videos provided from each post and not one has used a power measurement method that can be accepted as proof of OU.
However, the good news is, I have full trust in Itsu's ability to replicate to the finest details and his excellent power measurement methods.
I hope you will accept his results as they will be the only one acceptable.
Luc
