0 Members and 120 Guests are viewing this topic.
gyulasun
Quote from: hyiq on February 19, 2017, 03:06:20 PM
Gyula - Itsu did not provide any Input Measurements!!! You keep referencing Itsu's Input Power Measurements!!! You do not understand the Context and comments are there fore invalid.
Hi Chris,
This video here is where Itsu deals with the input power measurements, have you not seen it?
https://www.youtube.com/watch?v=30oujoUF2Uc&feature=youtu.be
And this video link was included in Itsu's post #7861 and you quoted his full post in your reply #7865  in which you included your series and parallel LC circuit measurements I objected and mentioned the 3 problems.
So what is the problem now? (apart from my 3 mentioned problems which are still problems because you seem to disreagard Itsu's video I linked above)
Gyula
hyiq
Isn't it funny, how the OU Goons start turning up - Timed entry!!!
One, Two, Three...
I was speaking with a friend who is a silent reader, the comment I received was: "they are desperate"
It is funny how people hold themselves when faced with imminent destruction - There is no room for the OU Goons anymore, you're all so see through, you're all so desperate, and so fake...
Now, here in lays another very big mistake: Call this evidence if you like!!!
Quote from: tinman on February 05, 2017, 07:41:52 AM
Mmm-ok
First results are in for the below setup.
This was a quickly wound transformer-so not very neat,and only low power applied,by way of my SG. The loads are two identical !grain of wheat! incandescent bulbs.
Unlike Wistiti's setup,i did not join the two output coil's,but rather placed a resistive load on each coil separately.
EDIT-i forgot to mention--to achieve these results,i had to use a square wave,and a frequency of 12.2KHz.
Still looking for the error,but here are the results so far-measured with both DMMs and scope using a CVR.
The scope and DMMs had only a 2% difference with value's,so an average was taken from the both results.All DMMs were swapped around,and came within +/- 1%
Tried using the clamp on meter,but currents are to small to register.
P/in-6.8vRMS @ 19mA=129.2mW
P/out 1-1.8vRMS @ 41mA=73.8mW
P/out 2-1.83vRMS @ 42mA=76.8mW
So seems to be running at 116% efficiency.
We are close to being within error range with such small currents,but none the less,all care was taken when making the measurements.
I will report back when i find the error-which seems to be oddly elusive ATM.
Brad
Sorry for the quick crappy diagram,but have lots to do ATM.
Also added a pic of the toroid,and as you can see-very crappy winding job.
And then a rebuttal:
Quote from: tinman on February 19, 2017, 08:32:49 AM
Well Chris-no cigar here-i found the error--> 2 incorrect value CVRs is all it took to throw the readings out.
At these small power values, .2 of an ohm can make a big difference.
So,my P/in CVR was .9 ohm's,and the P/out CVR was 1.1 ohms-well as best as my best DMM could make out. Both are banded as 1 ohm.
Brad
Input:
V: 6.8
I: 0.019
R: 357.89474
P: 0.1292
P1:
V: 1.8
I: 0.041
R: 43.90244
P: 0.0738
P2:
V: 1.83
I: 0.04197
R: 43.60547
P: 0.0768
Now, If I change any one of the Resistance Values by the error mentioned: 0.2 Ohms What end result do we get???
Yes, Ohms Law does not LIE!!!
You, the Reader, you are being deliberately Miss-Lead, strung Up, by Paid For Liars and Cheats!
   Chris Sykes
       hyiq.org
hyiq
Quote from: gyulasun on February 19, 2017, 04:04:19 PM
Hi Chris,
Gyula
Which is NOT the video we were originally were discussing Gyula!!!
   Chris Sykes
       hyiq.org
gyulasun
Quote from: hyiq on February 19, 2017, 04:25:59 PM
   Chris Sykes
       hyiq.org
Chris, I finish with you, no sense to continue.  Please remove  your point 4 line as I kindly asked you previously, I do not participate in your campaign here, ok?.  I wanted to help with my comments but you are making war.
Gyula
ramset
What a surprise
well Chris there is only one way a moderated member[Milehigh] gets his posts thru
and that is the Boss {Stefan}
the owner of OU.Com has to read and approve every single post.
which also means Stefan has to go thru the very annoying process of keeping track of this thread and its content
so no Chris its Not OU.Com "goons"
I see you have been talking lies about Stefan [the boss]  and others here ,so Now you will have the direct link you so desperately require to say these things to him Publicly .
also to note Gyula above is practically a saint here at this forum ,who also gives quite selflessly of his time
Gyula is unaware ATM that his request to have your torrid remarks removed [towards him] is only doable by Stefan
or a moderator .
Thanks Grandma
