0 Members and 170 Guests are viewing this topic.
Mr.Miyagi
F6FLT - If only you were a little smarter. Perhaps pointing out the mistake, rather that assuming the error to be correct may have given you the ability to become more than a post grad?
It should be noted, post grads are urged to use Ohms Law correctly, assuming values is frowned upon!
tinman
 author=Mr.Miyagi link=topic=15395.msg528997#msg528997 date=1546006753]
There you go
You confirmed your own lies lol.
Quote me:--> Our COP in this test seems to be 331%
Quote you :the false claims of OU
There you go,in big black writing --i never made any claim of OU.
QuoteWhen you miss 707 what are you missing Brad?
Oh look
4000 amps from a battery the size of two smoke packets  ;)
https://frankiesautoelectrics.com.au/noco-gb150-12v-4000a-lithium-jump-starter-pro/?gclid=Cj0KCQiAsJfhBRCaARIsAO68ZM6LVP1Cx2nduhClpJVkheCi0svLYC3Ygbnb6F6ewS93yseD9Zb3ngcaAvzjEALw_wcB
QuoteYour mistakes this week are getting bigger by the minute!
You just keep supplying the links to these OU devices,with the !top of the wozza! EE guys making sound math measurements lol.
QuoteWhen you assume a 10 Ohm wire wound resistor to be 10 Ohms at > 2 Mhz and Claim 331% OU in front of the world - Its a pretty big mistake Brad!
Two screwups in one paragraph lol.
1st--the resistor is 10 ohms at 2MHz
2-i never made a claim of OU
QuoteYou know, the Lies,  on a Capacitor - Your reputation is in tatters!
Like your !!top of the wozza!! EE guy in the video--that made sound measurements,your an epic fail-but a great liar.
Once again
Can you supply any evidence to back up your claim that Don Smiths device was OU ?.
Can you supply any evidence that Chris's POC is OU ?
No to both i bet.
You should give up while your behind.  ;)
Brad
Mr.Miyagi
Hahahaha this is hilarious!
Keep behaving like a Clown, your audience grows by the minute!
I am enjoying this!
Inadvertently you're advertising Chris's Technology, the technology you tried to thieve and then lost the ability to make work after the whole thing packed it in. But you're not smart enough to work this bit out.
Mr.Miyagi
Oh, did you see this:
Quote from: tinman on December 28, 2018, 07:29:39 AM
That is the difference between me and you
I make no claims of OU,and yet show my results
You make OU claims,and show nothing.
But anyway,that is normally how it is with those that make big claims like your self--they can never back them up with real evidence.
Brad
I refer to your post here:
Quote from: tinman on December 04, 2018, 12:31:27 AM
My self ,and a group of very talented people spent 2 to 3 months working on such parametric circuits not to long ago.
We were getting results with COPs in excess of 200%.
What i will tell you is that current can follow paths not considered to exist. After months of testing,we found that a portion of the input power can travel through mid air. This is the portion of P/in they are missing-they being the people in your posted papers.
There are two self running devices that i know of,and have seen running in person--but you simply will not see such devices on public forums such as this one,nor on youtube.
These are not overunity devices,but more so devices with an !unknown! power source. One of them is quite cleverly done,and extreemly simple to build. The other is more complex,and would take a well skilled machinist to construct,and a half decent EE to build the required circuits.
The first machine make use of room temperature nitanol springs-nothing out of the ordinary there,but how he is able to create the required temperature difference without consuming any power is the clever bit.
The second,more complex machine is a bit more baffling.
I have !as yet! been unable to work out as to why it continuse to run once the power source is removed,while driving the equivalent to a 320 watt load. This 320 watts i calculated quickly by how much water was raised a set hight in a given amount of time--so it is a !round about! calculation.
But as i said,these are the machines you will not find here on public forums.
Brad
Bradley, you're a compulsive liar
Honestly, is this the extent of your wisdom?
tinman
Quote from: Mr.Miyagi on December 28, 2018, 09:41:43 AM
Cool
Tell us about this phase angle that the scope cant calculate in,when measuring the power dissipated by a resistor via the voltage drop across it ?
Were all waiting for this one  ::)
Brad
