0 Members and 55 Guests are viewing this topic.
https://de.wikipedia.org/wiki/Elektrisches_Feld
https://upload.wikimedia.org/wikipedia/commons/thumb/b/bb/Fluorescent_tube_under_electric_line.jpg/220px-Fluorescent_tube_under_electric_line.jpg
https://i.pinimg.com/originals/55/3a/fa/553afa24fb80600792a560450b45c8c7.jpg
wrapping that tube by translucent solar cell ! Effect ?
1 W- h ~ 3,412141 BTU     1 W-Hz ~ 0,0009478 BTU   h/Hz here : 3600/1
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=2&ND=3&adjacent=true&locale=en_EP&FT=D&date=19900213&CC=US&NR=4900898A&KC=A
Tests of a prototype space heater constructed in accordance with the invention have shown that  11,000 BTU of heat can be generated from approximately  600 watts of power.
( Existing portable space heaters can generally produce approximately 5200 BTU of heat at 1500 watts of power. )
        5200 x 0,293 (BTU in Watt)  = 1500 Watt ( 1523,6 W )
  From pure DC or 50 Hz or 60 Hz or KHz or MHz AC or pulsed DC source ?
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=19900201&CC=DE&NR=3817730A1&KC=A1
http://translationportal.epo.org/emtp/translate/?ACTION=description-retrieval&COUNTRY=DE&ENGINE=google&FORMAT=docdb&KIND=A1&LOCALE=en_EP&NUMBER=3817730&OPS=ops.epo.org/3.2&SRCLANG=de&TRGLANG=en
                                     Now I have managed to achieve twice the watt with a 1 m long and 35 watt neon tube,
lumen/Watt =  https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fde.wikipedia.org%2Fwiki%2FLumen_%28Einheit%29
Can be    K  ≈ 683 lm / W
Can be    K  ≈ 125 lm / W.
                                                   lumen in lx-formula !
https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fde.wikipedia.org%2Fwiki%2FLux_%28Einheit%29
For the definition of the photometric units it was determined that for radiation of the frequency 540 · 10 12 Hz, which corresponds to yellow-green light with a wavelength of approx. 555 nm, the photometric radiation equivalent is 683 lm / W.The following applies to light of this wavelength: 1 W / m 2 = 683 lx.The eye is much less sensitive towards the edge of the visible spectrum (red, blue).1 W / m 2 corresponds to a significantly smaller numerical value in lux down to zero.
1 W / m 2 =
Emitter to receptor   fixed ?/variable ?     distance ?
A luminous flux of one lumen at a wavelength of 555 nm corresponds to a photon rate of 4.1 · 10 15 photons per second.[3]
ever to calculate with photons per second rate and quantity !?
        ANSI lumens"
ANSI Lumen" is a colloquial term in connection with the technical specification of projectors (including video projectors. This is not a special lighting unit, but it says that the luminous flux (colloquially "the brightness") of the projector in the lumen unit was determined according to a measurement specification developed by the American National Standards Institute (ANSI) . [11]
To prepare for the measurement, the projector must be set so that a five percent gray-tinted field can be distinguished from a ten percent gray-tinted field against a white background, i.e. two very light shades of gray . The projection surface is then divided into three columns and three rows and the average of[/color] the illuminance  {\ displaystyle E _ {\ mathrm {v}}} (in lux) of all nine fields. This mean multiplied by the projection area  {\ displaystyle A} gives the "ANSI lumens": [12] {\ displaystyle {\ mathit {\ Phi}} _ {\ mathrm {v}} = E _ {\ mathrm {v}} \ cdot A}Most of the manufacturers of projectors refer to the standard-compliant maximum settings, which are rarely optimal in practice. The luminous flux achieved with the optimal setting is sometimes significantly lower.
many possibilities to make formula-use errors and/or measure errors ! Or new discoveries !
                                            Metrik und Definition
https://www.southcott.com.au/media/products_guide/hydraulic_conversion_chart.pdf
Druck/Pressure,Kraft/Force,Arbeit/Work,Leistung/Power
1 hp = 1 PS " um cavalo,un cheval ,deux chevaux = 2CV Citroen( fiscal not physical !) "
     1 Pferde-Staerke not 1 PL = Pferde-Leistung =
  horse-force not horse-power
           AS FIXED AVERAGE VALUE = 1 average horse-force unit in Watt :
https://www.google.com/search?rlz=1C1AVFC_enPT797PT797&q=1+ps+in+watt&sa=X&ved=2ahUKEwiAjJurnIPoAhWmy4UKHf_yC58Q1QIoBXoECBcQBg&biw=1366&bih=604
https://www.engineair.com.au/services
Considering that a HP is the equivalent power of a mature horse and that statistics shown that a horse of 600 Kg is capable to reach speed of up to 88 Km h, this clearly shows that current vehicles with engines around 300 HP are just a waste of precious resources.
https://www.physicsforums.com/threads/psi-to-kw-conversion.700882/
sliding friction versus rolling friction and psi ( pressure )
https://contest.techbriefs.com/2012/entries/machinery-and-equipment/2491
Below that pressure, friction caused the engine to stop running. A scroll compressor of the same size required 8 psi to keep it running. The MECH expander required only 1 psi to keep it running.
the right side : lifter
https://books.google.pt/books?id=Zs8DAAAAMBAJ&pg=PA20&lpg=PA20&dq=popularmechanics+foldable+portable+building&source=bl&ots=IJEARu16YQ&sig=ACfU3U1ZNOlPQTF-jbUR17J3YvUpWsVjyQ&hl=de&sa=X&ved=2ahUKEwiZvqGhp4PoAhXoxoUKHcjbAKEQ6AEwAHoECAcQAQ#v=onepage&q=popularmechanics%20foldable%20portable%20building&f=false
                  by as little as 1 psi
minute 3:00 +
magnet in brasss tube
https://www.youtube.com/watch?v=HK3JOlY0V8Y
magnetic brake principle/ velocity minimizer
lifting a rotor : https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=26&ND=3&adjacent=true&locale=en_EP&FT=D&date=19860619&CC=DE&NR=3602039A1&KC=A1[/size]
                     https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=12&ND=3&adjacent=true&locale=en_EP&FT=D&date=20031204&CC=US&NR=2003222512A1&KC=A1[/size]
http://translationportal.epo.org/emtp/translate/?ACTION=description-retrieval&COUNTRY=DE&ENGINE=google&FORMAT=docdb&KIND=A1&LOCALE=en_EP&NUMBER=3826970&OPS=ops.epo.org/3.2&SRCLANG=de&TRGLANG=en
The current requirement, whether for one attraction pulse or for many, remains constant, even if the number of attraction pulses is up to several thousand per minute, because the attraction pulses occur in sequence, in fractions of a second. So there are never several attractions at the same time.
The power generator therefore only ever has to supply the power for one electro magnet.
ramset
Are experiments permitted in this thread or are they only done [receive help] at Above unity forum ?
if experiments are allowed here
Chris Quote
Raycathode, well yes, but to be a little more specific, its about Work in the System.
Asymmetrical Regauging can enable a machine to have an Asymmetrical Work Period. When your input is On, say its a 50% Duty, then one would expect to see a 50% work Period. These machines do not work like that, we can very easily have a 10% Duty, Input On Time, and a 90% Work Period after the Input Period Work Period. Thus giving a 100%, or very close to work period for only a 10% Initially. An Asymmetrical Work Region for the Input you supply to the system.
Getting your Potentials up, alone, is not enough! The System must all for the use, to provide Work with these potentials, Work is M.M.F vs M.M.F, or Ampere Turns vs Ampere Turns. A Potential is required for this to occur however, no Potential, No Work. One can have Potential but the System can do no Work!
end quote
we can invite experiments here to explore above example ??
Thanks Grandma
James F Murray III WO2014021913 , CONVERGENT POWER INC
Multi-Pole Switched Reluctance DC Motor .......
E.M.F.  and B.E.M.F. related :         [ 0201 ]
The TIME ( in frequency,pulses ) GENERATOR becomes the function-controler of all electric and static devices  !
https://worldwide.espacenet.com/publicationDetails/description?CC=WO&NR=2014021913A1&KC=A1&FT=D&ND=3&date=20140206&DB=EPODOC&locale=en_EP
[0081] At the instant illustrated, the DC motor has not yet begun to rotate, and there is no Back EMF, but the starting torque is relatively large at 637.986 in-lbs, which is 5.165 times the running torque. The Back EMF that develops as a function of the motor's increasing rotational speed reduces the start-up current of 135.965 amps down to the full load ampere (FLA) value of 26.326 amps. This "high start-up current," behavior is standard and expected in conventional Speed Voltage dependent motors.
[0201] The difference of these two values AL is calculated to be 8.666 x 10 <"4>H, and when this change occurs in one quarter of a rotation at 60 HZ, a measured Back EMF of 2.5 Volts results. This is a remarkable result, considering the fact that a change of the same degree within the air gap of a conventional Speed Voltage based motor generates hundreds of volts.
EMJunkie
Quote from: ramset on March 05, 2020, 08:23:34 AM
Chris Quote
end quote
Hello Ramset,
Although I have had my share of trouble with you, you got me banned for no reason at all, last time, I am willing to forgive you, why? Because I am Human. It was part of my plan. As you know! As this is part of my plan! What I am doing now! You allready know, I have my own Forum: www.aboveunity.com which is very successful!
Ramset, you will notice, and have noticed before, my first post:
Quote from: EMJunkie on January 16, 2015, 12:08:38 AM
This thread is for those interested in moving ahead with Free Energy!
Experiments and serious discussion only!
Yes, I am serious, I do not have time to waste, I am only wanting to make progress, share facts and experiments. This is the only way to move forward.
I have said here on this thread, Electromagnetic Induction as we understand it, is NOT Complete, there is more to learn, but Science had stopped back in the 60's and considered Electromagnetic Induction complete and satisfactorily explored. The Dogma of the mind is not Scientific and we can not lay blame on Science for this, it was directly the establishment that is responsible and not Science.
Today, it takes Men with determination, perhaps a little bit of luck, and some very serious discipline to make steps in the right direction. Many men fail, simply because they do not discipline themselves.
Ramset, can you discipline yourself this time around?
Let it be known, if the men named:
Picowatt
MarkE
PIH123
Idegen
one or two others...
These men, yes I have their full identities, were deliberately here to derail what I was doing! I knew I would have trouble with a few people. But this was on going targeted Attacks:
Quote from: EMJunkie on June 05, 2015, 06:09:19 PM
The following figures are just on the first page of the User Profile as of Today:
MarkE : 2 in 15 posts are not on this thread! 86.6% Vomiting Diarrhea here, on this Thread!!! See Here
MileHigh: 3 in 15 posts are not on this thread! 80% Vomiting Diarrhea here, on this Thread!!! See Here
Do you, the reader see a pattern here?
Is this called a Targeted Dis-Informational Attack?
Come and cause trouble, like last time, I will report to Stefan, and I will leave this place! I have no intention to waste years of my time sharing information with others when this much trouble was deliberately established by these men! I have much better things to do, better places to be, with much more productive things to be done.
This is the first and final warning for Behavior problems. I made it clear to Raycathode, and I will no longer be replying to his posts any more unless he gets back on topic and starts being productive.
Ramset, the same for you, I am not putting up with bad behavior, I expect, if you come cause trouble and are asked to leave, I expect you to leave. Not stay here and cause more trouble!
Bring forth your experiments, please feel free. I will help where I can!
Best wishes,
   Chris Sykes
When died Kirchhoff ? What was the electric infrastructure standart in his last educative - as professor/docent- living year ?
DC-EE to pulsed and variable speed AC or DC-EE !
Monophase to polyphase : Kirchhoff - Steinmetz-Kron circut architecture
We are now in the 220 KW/10 Kg power density motor and generator level = 22 W/Gr. rotative machine but also in the 6 Wp/Gr. myriads circuits photovoltaic converter era !
Sintering or sputting or growing :
partnered coils ( nano tubes) of polymeric materials,an- or organic  : as bio-solar converter,A.I.-converter with self-learn potential
cotton fiber plasma treated ( from hydrophyl to hydrophob)  ~ electromagnetic conductor ~ CNT
Kron " Tensors for circuits" + fuzzy logic = neuronal programing
Waymo- Uber-Tesla " autonomous driving" !
From agro-meat to bio-veggie-meat( self organizing and growth ) to bio-mechanics devices,self-growing on demand( sleeper/awaker impulse incorporated by polarisation change)
