2nd law violation:new battery type "poor man's Karpen"
Started by jonfrommanahawkin1, January 29, 2015, 02:14:56 PM
jonfrommanahawkin1
This is a build that I've been working towards for over two years. When I started building batteries I knew about the Karpen pile which has been give the nickname "perpetual battery" and I've created just that.
The theory is simple "two dissimilar metals merged in a nonreactive electrolyte will stay on forever"
I came to that theory from learning about the original Karpen but there was one draw back, it was built out of platinum and gold. But because of its building materials the electrolyte had a wide range of acids and compounds. That made it easy for mr. Karpen to make his battery however very hard for you and me.
So after many experiments and long test periods I've made what I call the poor man's karpen. It has very low current but does use some galvanic similarities when it comes to voltage. It also does exhibit the gain in current when it is switched on and off like the original and also as you increase the surface area the current does increase as well.
This is the link to my video thesis
https://youtu.be/9xV9dZeaRcs
And I've take a lot of care to make it entertaining so you'll like watching
I would also like to state that I am in the process of make a scaled up version to make a usable light or power source
This definitely is a overunity battery
All the best
jon
4EvR perpetual
dieter
Very useful, thanks for sharing!
A tutorial as PDF would also be handy.
BR
jonfrommanahawkin1
thanks for the suggestion and i will work on that for my next design. but if anyone would like to make one in the mean time they are more then welcome too
all the best
jon
My knowledge of batteries is a bit lacking but how does this differ from a regular galvanic battery? And what is the electrolyte you used on this? Appreciate your answer.
jonfrommanahawkin1
a standard battery uses the negative ions created by the corrosion reaction of the electrolyte and the lesser metal, the Karpen battery has no corrosion by chemical definition to the two different metals. because the original used platinum and gold  he was able to use very aciline acids for my battery i do use a non conventional electricity but im going to keep that under my hat till i release the bigger version which is almost done
and i am very sorry for not telling you now but you can use regular tap water to get close to the same effect in the time being
im just worried someone will bet me to the punch . ive worked to hard at this to not get the right credit for it but if i can get the right people to see this and comment to assure my credit ill make it clear
again my apologies but you have to understand
