How Rosch probably faked their 5 KWatt KPP AuKW
Started by hartiberlin, May 05, 2015, 10:41:49 PM
hartiberlin
Hi All,
I recorded the dismantling process today.
Unfortunately I missed the switch off of the AuKW,
but at least I captured all the later stuff pretty well.
These are bilingual Videos English-German language.
https://www.youtube.com/watch?v=D3M0uBASnV4
https://www.youtube.com/watch?v=XIiaU74xRP4
https://www.youtube.com/watch?v=4--SdBE0z64
Well as the AuKW was still running a few minutes ago before I recorded
the first video, the question is now, how they wired that up that they still had today all
the power at the output ?
If there was no hidden cable through the connection support beams, then how
did they input the power to all the loads today ?
Well in the last days we had a still frame only in the Livestream from
8th of May evening to today midday.... so
in that time frame they could have tampered with the device..
Did somebody record the switch off of the AuKW of today ?
Would love to see this.
Many thanks.
Regards, Stefan.
PIH123
Quote from: hartiberlin on May 13, 2015, 02:06:19 PM
Do you suppose that during all of that "Live" feed downtime,
they had time to:
.  remove the wires from the support tubes
.  patch up the small 1 inch diameter hole from the demo room to that area above the office in the adjacent space
.  install a honking big battery in that "generator"
.  turn it back on in time for the "show"
Surely they couldn't get all of that done in less than 96 hours ;)
Spackle must take at least that long to dry, let alone paint over.
So did anyone get to look inside the "generator" ?
Pete
PIH123
J.D.s photos.
Another nail in the coffin.
Stefan, you have been quoted multiple times by Stuart / Sterling on PESN as having changed opinion.
QuoteHe's still having a hard time with the science, but pretty much admitted that while he doesn't understand how it could work, the demonstration did seem convincing that it was working.
So please review again the photos available (from J.D.) after the brackets were removed.
Please open them in their own tab so that you can more easily zoom in on them.
Photo 29 (http://www.pureenergyblog.com/wp-content/uploads/2015/05/DSCN1325_1000.jpg) shows a guy photoing the lower bracket position.
The top holes of that bracket were nearest to the gap in the prefab wall (comparing the 2 bracket photos) and there is a dark smudge above the top right hole.
So we know the lower bracket must be this photo http://www.pureenergyblog.com/wp-content/uploads/2015/05/DSCN1327_1000.jpg
The "pattern" of etching of the prefab concrete can be seen over the entire surface of this part of the wall.
So far so good.
And so let's look at the upper bracket position http://www.pureenergyblog.com/wp-content/uploads/2015/05/DSCN1328_1000.jpg
Notice that the same "etching" pattern we saw everwhere on the lower bracket picture is there...................................
EXCEPT FOR the entire area inside the 4 mounting holes.
Is there an equivalent German word for "Spackle" ?
Did J.D. bother to look for any open tubs of it ?
They had 4 clear days with no live feed to cover this up.
I bet this will cause Sterling to lower his rating to 9.89999999.
Also Stefan, you are quoted as having only considered "unseen portions of the control panel" for location of hidden batteries.
Is this true ? I did not listen to the entire 2 hour audio.
Thanks
Pete
MarkE
It is fascinating to observe the thought process over there.  They have absolutely no evidence that gravity or its application to fluids is an energy source:  zip, nada, nothing, de-minimus.  Rosch/Gaia do not even pretend to present any evidence that the paternoster drives the "generator" rather than is driven by a motor labelled as a "generator", much less that the paternoster passes more than 5kW, or that the supposed power out of the paternoster in any way exceeds the power into the small compressor.  There are no force or torque transducers in the system to measure mechanical power and the direction of that power flow.
S&S jump into an alternate reality where they assume the claimed miracle is true.  From there they go through exercises of trying to convince themselves that there is no trick in how the display was wired.  Such is the world of self-delusion.
While I don't actually think this is the case.... it is certainly possible that the bracket _bolts_ themselves could be used to make the necessary electrical connection through the wall. No extra holes or cables through the wall are needed, just some long bolts that go all the way through. Two brackets = two conductors, with the long bolts making the connection through the wall.
