Permanent magnet motor
Started by Jim36, May 18, 2015, 01:24:19 PM
guest1289
From my previous post,  I'm not sure if  magnet-motor-3-4  would function, but it's an interesting design,  not only for reasons as to why it would not,  or would function,  but also as to what sort of levitation effect it would have .
   Below, I have re-drawn  magnet-motor-3-2  to use more conventional  shapes,  and that is called   magnet-motor-3-2-5
  (  not that I think any  magnet-motor  would actually function )
forumblog
  I'm   guest1289,  this is my other account,   for other things I'm doing  .
  Could the stators in  magnet-motor-3.2  that I just posted,  be replaced with simple metal-plates,  thereby making this a viable engine for railways .
  (  Also,  could someone design a  magnet-motor using a row of  donut-magnets,  exploiting the well-known neutral-zone  in the donut-magnet,  I can't think of any way  )
Pirate88179
Quote from: forumblog on February 17, 2016, 12:47:16 PM
Why are you using 2 different accounts on here?  Do you not know that this is against the Terms Of Service that you agreed to when you signed up for this site?
I suggest that you eliminate one of these accounts before the Admin eliminates both of them.
Thank you.
forumblog
   I definitely did not know there's an actual rule( terms of service ),  stating that you cannot have more than one account.  I did wonder though .
   I do have a very valid reason for having to use 2 accounts,  I won't detail it on the forum,   but there must never be exception to rules,  or the site won't work  etc .
   The mistake I made is that I actually stated that I am guest1289,  but again,  I didn't know it's against the rules .
   There are probably a lot of people on here that have 2 accounts,  for all sorts of reasons,  but of course they don't state that they have 2 accounts,  so it won't be a problem for them .
   It will affect me,  no longer being able to use 2 accounts( and stating on my posts that I am the same person as another account ),  but obviously I will no longer be able to do that .
guest1289
Magnet-Motor-1-1
Below, is the new diagram for this motor,  and the area labelled   'effect-point' shows how I'm trying to re-design the only merge-point  in this motor. Basically, I'm trying to induce some more  magnetic-attraction-strength into the weak/thin  side/end of the merge-point  by using  the strong/wider  side/end of the merge-point.
    My drawing skills have again failed, because I have not fully drawn what I wanted to draw.  This needs an artist .
  (  In the diagram,
      -  At the  'effect-point',  more of the weak/thin  side/end of the merge-point  needs have more of the strong/wider  side/end of the merge-point closer to it.
      -  The stator needs to more accurately get wider and wider.    )
  So, for this particular design, I think the stator would not be magnetic, it would just be metallic .
   The options for this type motor are infinite.
   ( I thought I had invented this motor 1 year ago, I can't go into more detail here.  However, some months after I invented it, without having drawn it, or discussed it with anyone, I saw a diagram on the internet which resembled my idea, but I did not check if the component that resembled my idea was actually a stator, and I did not read any details about it, I don't know if it contained a written description.  I have not been able to find that diagram since.  But last night, I found another magnet-motor pre-dating my motor,  which although does not work in the same way, it does contain a similar component.
  My-Fly-Wheel-Device
  Have a flywheel using a passive-magnetic-bearing instead of an axle, and house it in a vacuum,  use the minimum electricity possible to first get the flywheel moving from a non-moving status, and then speed it up to a suitable speed,  then,  using a totally-frictionless  electricity-generator design incorporated into the device, generate-electricity,  and use it to keep the fly-wheel spinning.
   Keek in mind the flywheel would only be started up from it 'non-moving' status once, in the lifetime of the device.
   The electricity-generator design could just be magnets moving past a perfectly-smooth single electrical-cable loop,  and if needed, there could be much smaller cables to drain of any eddy-currents. ( of course this electricity-generator design would generate much less that other designs )
