The bearing motor
Started by tinman, May 28, 2015, 11:10:41 PM
shylo
I don't have any copper plate to try this, would aluminum plate work?
It must have something to do with the eddy currents.
Gravok, I skimmed your link and will read later, Thanks for that.
How much potential can be generated with this type of set-up?
The heavier the copper ,the more amps?
artv
gravityblock
Quote from: shylo on June 09, 2015, 08:13:53 PM
artv
Yes, an aluminum plate will work.  A larger diameter disk and magnet increases the voltage.  Higher rpms and stronger magnets will also increase the voltage.  A thicker copper disc for more amps.  Eddy currents only occur when the outer rim of the conductive disk is larger/outside the magnetic field.
Gravock
tinman
Quote from: gravityblock on June 09, 2015, 07:50:37 PM
Yes, it's a big bite to swallow for someone who is so far off.
Gravock
Gravoc
I think you need to revisit your statement.
On one disc we have current flowing from the outer circumference to the center of the disc. On the second disc we have the current flowing from the center of the disc to the outer circumference.  As the disc are the conductors, we now see that the current is flowing through those conductors in opposite directions. How you came up with current is flowing in the same direction through the conductors has me lost. You need to think a little more on the magnetic fields produced by a ring magnet also.
This is when people get lost, when people like yourself go making incorrect statement as youjust did.
tinman
Quote from: Magluvin on June 07, 2015, 02:27:57 PM
I would need to see that to believe it.   If you take 2 disk mags and have them face each other say 1in apart, and the magnets are set up do they can spin on axis, if you spin one, the other wont spin. There is zero force on the other magnet to spin with the other.
Likewise, we cant get the disk magnet to spin using dc through a wire, no matter the position or orientation of that current carrying wire. The field from the wire will only affect the magnet as a whole, not as if the field lines are teeth of a gear and torques the magnet into rotation.
The key idea of having the ring magnet mounted to the copper disk in a homo polar dynamo is the fact that the magnet rotates with the disk yet the disk still produces current. But if we mount a magnet to the end of a coil and move the magnet and coil through space, what ever direction, we get no current in the coil. So the solid ring magnet mounted to the copper disk and when they rotate together, current is produced in the disk, is a very very special case in point.
The very foundation of that destroys the idea that there are no field lines along with the idea of change in field strength on a conductor is needed to produce mutually inducted currents in the conductor.
But this is pretty much the only special case for that argument. At least that I know of.
What attracts me to the idea of having the ring magnet attached to the rotating copper disk is the possibility of no drag when currents are sent to a load..  Typical gens need increase in input as the load increases. But here with the magnet spinning with the disk, if we draw current from the disk, is there a need for more input torque to overcome drag/lenz? And if so, with the mag spinning with the disk, what is causing the drag if the 2 components are mounted and spinning as one?
So say if there is no drag. Is that the secret to a true lenzless gen? ;) And if there is drag, what are we dragging against? The field itself, as these fields are all around us?  If so, then that is possibly the holy grail of solid state motion devices. If we can drag against it, then we should be able to produce motion with it by pushing and/or pulling against it, like a silent ufo, car, plane, etc.
Mags
Mags
I believe I have a version of the homopolar generator that will have very little CEMF. The CEMF is created at the outer contact brush, so we need to get rid of that brush. I have a design that has both brushes on the shaft, and none around the outer perimeter of the disc.
I will draw it up tonight.
Tito L. Oracion
Take a look  it is rotating, no anything but flowing of water only. ;D
https://www.youtube.com/watch?v=dpdRMwiG1P8
