Thanks to ALL for your help!!
MY PATENTED DEVICE DOES NOT WORK!
Started by mr2, May 29, 2015, 06:48:36 PM
forest
Would it be too hard to experimental prove if there is EM radiation in this case ? Do you know any scientific papers of such experiment ?
tinman
Quote from: forest on May 30, 2015, 12:59:29 PM
There is no EM losses or any other losses-->the !/2 charge that seems to be missing is still in the cap. The electrons dont just go zipping of into the sky,or get radiated as heat-the electron flow is what creates the heat. The higher the restriction to this flow,the more heat is generated-electrical flow friction.
When you charge a cap or a battery,your charging source is nothing more than a pump. This pump is what pumps the electrons from the positive plate,back to the negative plate. When there is no voltage across the cap,you havnt used the charge,you have simply provided a path for the electrons to flow to the positive plate. This is the very same as the water in the two tanks wanting to reach an equilibrium-->the charge is still in the caps. The problem is,there is now no potential difference between the two charged plates.
MarkE
Maxwell's equations tell us that any rate of change of current through a circuit radiates E/M energy.  Experiments go back to the 1800's.  Everyday thousands of engineers conduct these experiments in EMC labs doing what they need to to reduce the radiation to acceptable levels.
pomodoro
Beginners should also note that the capacitor holds no extra electrons when charged than it did when discharged.
tinman
Quote from: pomodoro on May 31, 2015, 08:46:32 AM
Beginners should also note that the capacitor hold no extra electrons when charged than it did when discharged.
Spot on ;)
