Friedrich Luling Magnet Motor
Started by DreamThinkBuild, July 05, 2015, 05:31:08 PM
sm0ky2
Quote from: dieter on March 05, 2017, 03:03:16 AM
So this dude has found a way to turn off the permanent magnet at the sticky point he says. Great. Does he also reveal hiw he does that?
If not, honestly, then this is just another guess n speculate thing. And these things never work.
Such a prefered myth consumption loop is really an interesting behaviour pattern. I wonder why people don't concentrate on open source concepts.
Perhaps you have never heard of Howard Robert Johnson?
nosnbora
hello,
i read for 2 years in this forum now, just signed up only because this great approach to lünings magnet motor.
i think it doesnt work like this because the iron blocks, once in line with the magnet, will stick very strong to the magnet in the middle.
yes, there is a spring to pull it back, but i wouldnt underrate the force the iron sticks to the magnet.
you can disable or at least weaken a permanent magnet by attaching a coil around it. or better: the square shaped coil is attached between the iron blocks and move with them over the magnet.
i think if the coil is fixed on the magnet it doesnt make a difference because then the coil holding the ironblocks in place...
this coil has to be energized only for a very short pulse to set the iron blocks free again, so the spring can easily pull the iron blocks back.
thats the only thing why the motor shouldnt work properly. and i think thats the reason why there are some wires on the motor in the orinigal video.
is this too easy? ^^
Eniac5state
RSTERGAR  you are the best builder i have ever seen in this field !   But we are in modern times now with hightecher materials:
"Can we first keep it simple ??  This is how a magnet motor should work:
Make magnets on rotor. Say two or four.
Now get a stator magnet in the vincinity of the rotor magnet.
The rotor will now turn towards the stator. Easy. But now the rotor will stop at that point so,
the stator magnet should isolated so the rotor can run in its own momentum. Easy.
But a trick, what if we use a high efficiënt elektromagnet as the stator magnet?
We don't have to shield anymore and can use neodymium magnets !
"But a strong elektromagnet costs energy" say the dummies. Not anymore. There is an
elektromagnet that can hold a person with two AA BATTERIES ! They are on sale.
Just make those switchable and the engine is nearly ready. Smile and start building.
Then attach a generator to it."
Do these people know where these 2 AA batteries magnets that can hold a person, are sold ?
If you can't do that easy task you will never reach anything without the help of others.
This is called very dependant on others. Like a kid.
norman6538
Where is this
"elektromagnet that can hold a person with two AA BATTERIES"?
Norman
Quote from: Eniac5state on April 12, 2018, 05:57:34 AM
Do these people know where these 2 AA batteries that can hold a person, are sold ?
If you can't that easy task you will never reach anything without the help of others.
Eniac5state
Rstergar important.
  Your engine is missing the vital part. It needs a lightweight flywheel
  so that with one magnet action, the engineshaft will turn 5 times by
  itself. A lightweight (fly)wheel with good bearings from a kidsbike.
  Not a heavy massive wheel. So attach a longer axle and the flywheel sits
  beside the table. Now we are getting somewhere. In the very beginning
  a car engine was 8 liters and 30 hp. Nowerdays we have a 0,5 liter
  engine with 340 hp. Just a bit of extra knowhow gives extremely better
  results. No good flywheel = no working magnet engine !
