Dr. Stiffler's "New" Quantum Energy Reciever.
Started by synchro1, August 05, 2015, 08:20:49 AM
Jimboot
Quote from: synchro1 on August 08, 2015, 07:57:21 PM
@Hoppy,
Try a Tesla bifilar pancake coil in place of the generator capacitor. Everything else checks out.
I may give that a go today. I tired the copper plates plastic and neos yesterday. Before hooking up the fbr I put the scope on AC and measured the plates directly. Adding the magnets definitely increased the voltage I was measuring. Only a few millivolts though. I left it charging a cap overnight. I'll change the fbr I'm using today for some signal diodes. Nothing too exciting for me though. May try a cap today too. My setup still feels like a smog collector though. My bench is in a converted shipping container with flouro lighting. So it makes a good faraday cage but I did have lighting and electric heating running at the time.
Quote from: synchro1 on August 08, 2015, 05:53:59 AM
@MarkE,
I'm an experimentor, not an "Ivory Tower Egghead" like Mr. Know-it-all with more of your extra assignment material. Conrad-Electro built a magnet core bifilar for me and concealed his spontaneous charge results for Mile High.
How many worthless, hum drum posts about Faraday's Law did you help upload on this subject along with Mile High? Your obnoxious "No O.U." click failed.
No, ConradElectro did not "conceal his spontaneous charge results" for me.  He built a "series bifilar" coil and I gave him some simple guidance on comparing the magnetic field strength produced by a "series bifilar" coil and a regular coil of the same number of turns using a simple compass setup that was aligned with the magnetic north-south.  Contrary to your claims that the "series bifilar" coil would produce a stronger magnetic field, that in fact did not happen.  What happened was normal and expected - the strength of the magnetic field was related to the number of turns of each coil, irregardless if it was "series bifilar" or not.
You made all sorts of claims about the "series bifilar" coil so when Conrad had his setup and was doing his testing, I posted on at least two separate occasions inviting you to ask Conrad to do some tests for you.  Those could have been tests to check for special high voltage generation or "spontaneous charge" or extra energy storage capabilities because of the increased inter-winding capacitance or whatever other fantastic claims you had been making about a "series bifilar" coil for months.  You did not respond.
Can you give a link to a video where Stiffler shows it working _with_ the magnets, then he _removes_ the magnets and shows that it no longer works?
synchro1
Quote from: TinselKoala on August 09, 2015, 06:38:26 PM
@Tinselkoala,
No, I have yet to see one. Stiffler says something in video #4 about his unusual capacitor being designed for "Underwater" use?
