About Perpetual Motion
Started by Gabriele, August 10, 2015, 02:11:24 PM
Gabriele
Hello. Here is a WM2d simulation. With electrostatics (or PERMANENT MAGNETS?). The costruction of the ring isn't very accurate. Left-half-thorus is 0,99998975 of right thorus.You can see. If somebody can build a draw 100% equivalent is better. Magnets (electrostatic objects) are polarized N S
               S N
So when the array rounds gaining energy(?),when is rotated with the central gap to the center of the thorus,we can block it,catching work,moving it to the center again,and realligning to the start point repeating the game. Tell me what you think.
Gabriele
Gabriele
Perhaps I found a way. Unfortunatley i can't imagine a system to absorb energy from this method. Imagine a capillar can rise water for example 10 cm. Ok,now make it long 20cm. Anyway the water rise only for 10cm. Put it on water,water will rise 10cm. If you let sink capillar into water(imagining it very very thin,so Archimedes law could be trascurable) you obtain an energy due to force of surface tension of X for the distance defined by 10cm,and an X half for the rest. Energy we need to extract it from the water for 20 cm will be the same(X*15).Imagine now initial situation. Put a rod thiner than the capillar from top,inside the capillar. Liquid will rise for the rest of 10 cm emitting energy. Let sink capillar and the rod for 10cm(we gain X*15). Now let only the external capillar sink,gaining energy. Better up side down in Hg.
I appreciate comments.
Nobel pls :D
Gabriele
Gabriele
What I need to underline is that if the system,could work,it not depends by gravity,but from surface tension only. If it works here on earth,it will work in space too. Is the concept clear? Can you help me with the question in the red drawing? Would be clearer if i draw entire process? Thanks
Gabriele
Should be possible. (About the red drawing: You can imagine let both thin glass walls escape from mercury,then reinsert only one. Energy you will obtain is minuscule,but positive)
