Inductive Kickback
Started by citfta, November 20, 2015, 07:13:17 AM
synchro1
Quote from: Magluvin on March 04, 2018, 04:49:52 AM
Ok, sorry it took longer than expected. Spent more time than I wanted to, but sometimes you have to try and test things and run into issues, etc.  But its all setup.
The input is 1v from the power supply. Im just using a push button switch to energize the kicking inductor. That coil is 24.8ohm and 10mh
The identical(practically) single wire and bifi coils, left and right respectively, are 43 ohm and 35.7mh. The pickup coil between the test coils will be the yellow trace on the scope and the blue trace will be monitoring the kicker coil..   Doing the vid now to show results....
Mags
@Magluvin,
Can you measure the inductances on the two coils please? Remember the 5% greater inductance measurement of the bifilar?
Magluvin
Quote from: norman6538 on March 04, 2018, 07:43:56 AM
Youtube says video not there.
Norman
Hmm, Im watching it again right now.  Ill look and see what might be the issue.
Mags
Magluvin
Check now. For some reason it was on private, but that should still let you see it if I give the link...
https://www.youtube.com/watch?v=4zSjnNdeZ-Q
Mags
