Rotating Magnetic Field's and Inductors.
Started by tinman, December 14, 2015, 09:08:53 AM
tinman
Quote from: poynt99 on January 02, 2016, 09:44:15 PM
As I said Brad, the simulation could use some fine tuning to not only increase the effect, but maintain or increase the flyback power as well. I just don't have the will nor desire to do so. But I am confident it can be done.
Well Poynt-like i have been told many times before-->having confidence that something can be done is not the scientific method. It is odd that you would have to fine tune your setup to try and achieve the same results,when i can just throw together any bits and pieces,and achieve the results.
It is also odd that all those that seem to think there is nothing out of the ordinary happening here,are also the very same people that cannot show the same effect using other means.
If it is so straight forward and ordinary,then why is it so hard to show the same results i show?.
I would like to see the same results achieved without the use of PM's. I mean if PM's do no useful work,then the results should be achievable without the use of PM's.
Brad.
gotoluc
Quote from: tinman on January 03, 2016, 01:22:41 AM
Do you have a pool Luc-or a decent body of water for an experiment ?
If yes,then you can power a small boat using nothing but the earths magnetic field.
Im sure you will work out how this is done now lol.
Brad
I actually have access to a large private pool which also has a private lake 100 feet away.
You should know I'm into boating and would love to make a boat (even if it's a toy) go forward without batteries or fuel.
Please do let me know how the experiment works as at this point I can't work out how it's done.
Thanks for sharing
Luc
tinman
Quote from: gotoluc on January 03, 2016, 11:23:57 AM
Thanks for sharing
Luc
You simply make a halbach array,so as one field is radiated out from the array,and the other is concentrated within the array. The field that is radiated out from the array will push against the earths like field,and be pulled toward the earths unlike field. The only problem being of course,is you can only go in a north or south direction-well maybe slightly off if you take a little.
Brad
gotoluc
Quote from: tinman on January 03, 2016, 11:41:19 AM
Brad
Interesting, I never thought a physical magnet could have interaction with the earths magnetic field to do work.
Have you built such a device and seen it work?
Thanks for sharing
Luc
tinman
Quote from: gotoluc on January 03, 2016, 11:54:26 AM
Thanks for sharing
Luc
You would be surprised as to how strong the earths magnetic field actually is. Mags has a video some where that shows the earths field spinning a disc magnet around to align with it's field.
QuoteHave you built such a device and seen it work?
Yes-a small boat shape cut out from foam.
I think i still have the video on my old computer. This was not my idea or design,it was something a member on IAEC showed a couple of years back. He also had a steel ball that he covered with small magnets,so as all one field was glued to the steel ball,and the other field radiated out from the steel ball. Even though he kept the magnets very tight together,there was still a small amount of flux leakage from the inner field near the corners of each magnet. But still,he could sit that ball on a piece of white surfboard foam,and it would float over to the north end of his pool every time.
Nothing of real use-not much different than facing the sails into the wind,but fun none the less.
Brad
