0 Members and 143 Guests are viewing this topic.
yes it can
5 (25%)
no it cannot
11 (55%)
I have no idea
4 (20%)
Total Members Voted: 20
ramset
MH
Its not about your interaction with Brad here so much as your wanting to "End"
this nonsense resonance rhetoric at an OU forum which sees Resonance or tuning as a necessary component
worthy of investigation .
you position yourself an authority of all things resonant and By default assume that all who venture
into the study of resonance or resonant tuning .. as it may apply to OU  are lost ignorant or uneducated fools !
and this you gleefully do at an OU forum and hope to Teach your perspective to all.. and guide them
to the Light which shines from your unresonant  presence.
and yes the Pistol shrimp [I took the Bait] is a nice example of what can happen in a softer medium with a properly tuned resonant cavity and an impulse .
A Bug Knocking photons out of orbit should not be so readily dismissed with a Yawn.....
and cavity resonance and water cavitation  would definitely be an area worthy of
experiment ...
at an OU forum.
Thanks Grandma
Oh stop being a jilted resonance fetishist and get over it.  I don't position myself as an "authority of all things," that's a ridiculous statement.  Stop repeatedly putting words in my mouth that I never spoke.  Just bloody well stop it already.
Years ago I saw a posting from you about resonance where you were jumping for joy in some kind of expression of resonance mental orgasmic bell-ringing Nirvana.  Can you point me to an OU system based on resonance?  If not then just keep searching and don't bother me about it.
tinman
 author=MileHigh link=topic=16589.msg486217#msg486217 date=1465827168]
QuoteWhen you say "an ICE uses resonance to work better and produce more power" what do you think of first?  I am willing to bet you the average person thinks of a modern four-stroke fuel-injected four or six-cylinder gasoline engine used in any modern European, North American, or Japanese car.
I am not an expert but I would not be surprised if the following were true:
1.  There is no type of Helmholtz resonator to help put air into the cylinders before combustion
2.  There is no need for an "anti-resonance" resonant cavity in the cylinder head
3.  There is no expansion chamber on the exhaust gas outlet because it is a four-stroke engine and it has a stroke for expelling the exhaust gasses.
Being on a forum that researches OU,why would we be talking about generic !off the shelf! engines.
Weekly i fit extractors to !standard! motor vehicles,to increase  efficiency,power and performance.
Why have the motor do work to push out exhaust gases,when you can have extractors that suck it out. With one simple modification,we have removed the need for the engine to do work it dose not have to do.
You have such a negative attitude MH,and that helps no one.
Brad
Quote from: tinman on June 13, 2016, 07:38:50 PM
Brad
So what you are really saying to me is that if you make a reasonable assumption that your unqualified reference to an internal combustion engine is for a modern four or six-cylinder four-stroke fuel-injected engine found in a modern mainstream car, then the statement that there is no resonance at play to improve the performance of the engine is perfectly valid.  So a couple of months worth of haranguing from you about the "ICE resonance" issue was all pretty much nonsense.  Your communication skills are so weak that it didn't even occur to you to qualify what type of ICE you were talking about when you said that there was resonance used in an ICE to improve performance.  And then when that is finally looked at in detail the only resonance at play is the Helmholtz resonator for the air intake.
Months of being harangued and almost harassed by you over a bloody Helmholtz resonator.
And you still can't bring yourself to say that a struck wine glass, bell, or tuning fork will resonate.
I didn't have my Ouija board, it was at the shop.
