0 Members and 37 Guests are viewing this topic.
yes it can
5 (25%)
no it cannot
11 (55%)
I have no idea
4 (20%)
Total Members Voted: 20
partzman
Quote from: poynt99 on June 30, 2016, 04:19:12 PM
Do you not agree that a changing inductor current results in a changing B field around the inductor?
Yes I agree.
If so, then would self-induction not be present?
Yes.
It seems to me that regardless how the emf is produced (either by applied voltage or induced magnetically), there would be a corresponding self-induced cemf.
It would seem so and I have no problem with magnetically induced Emf or Cemf.  I fail to see a justified Cemf with applied Emf for reasons I've covered in my example in the previous post and because of this view, I also do not hold to an Emf/Cemf feedback control loop with an applied Emf.
In order to support my opinion, I plan to attempt to define the self inductance of a single loop utilizing current and flux but my math skills being what they are, it is going to take some time if in fact I can do it at all.
I have attached an older Bureau of Standards document on the self inductance of single loop turns for the reading pleasure of anyone interested.
pm
Edit
tinman
Quote from: poynt99 on June 30, 2016, 01:11:13 PM
Awaiting your responses Brad.
It is ironic that you are using the sim to try and prove what some believe !may! happen,when that sim has been programmed to show exactly what it has been told to show ;D
Did you expect the sim to have a mind of it's own?,or will it simply follow the rules it has be given?.
Did the people that wrote the program for the sim have an ideal inductor to test,so as they could write the program and parameters of that sim to suit the inductors reaction's,or was it written based around the very same !laws! that are being discussed here on this thread?.
Brad
tinman
 author=MileHigh link=topic=16589.msg487498#msg487498 date=1467306568]
QuoteYou are a coward.  You offer up your own "theories" and then when you are asked to provide examples of your theories in action you chicken out.  You chicken out because in fact you can't illustrate a simple example of CEMF being less than the EMF with a coil.  You chicken out because in fact you can't draw a graph showing the mechanism for "CEMF current" in opposition to EMF current for an ideal coil and a real coil.
You mean like--if at the end of the first time constant,the EMF induced current is 25 amp's,then the CEMF current will be 75 amp's,and we can charge a battery for free? ;D
QuoteYou talk the talk but when asked to walk the walk you are a coward.
You mean somethink like the most efficient JT circuit?
Are you taking me up on my challenge then MH--so as your not seen to just talk the talk ;)
QuoteI can suspect that if you went to try to graph the two opposing currents you would quickly realize that it doesn't work.  That would mean you would have to admit that your theory that you have stated repeatedly is wrong, it's nonsense.  That would mean that you are wrong.  That would lead to you having a nervous breakdown so the only "escape" is you laughably saying, "I will do it but you have to do something first."  It's just one big Brad sizzling brain fry.
Like i said MH,send me the ideal 5H coil,and we'll get started--or do i have to use an imaginary one?. ::)
QuoteYou're the weakling, you're the fraud
JT,pulse motor,or rotoverter MH?--your choice
QuoteAnd that's just you being a pure jackass.  I just used some numbers for illustrative purposes.  Do you understand that term, "illustrative purposes?"  That's just another case where something is explained to you and any normal person would just accept it and move on.  But you shamelessly repeat nonsense like that over and over thinking that you are "scoring points" when what you are really doing is looking like an idiot and digging yourself into a hole.
You used those numbers to try and make my statement look stupid,and you continued to use those numbers to try and tell PW that i think there would be current flowing back into the battery---i can go and get those posts if you like,but you know you said that.
You also know that if you had of used correct ratio's,then my statement makes perfect sense,and that would have made you look like the jackass--as you do now.
QuoteAnd let's not forget Brad, that the well of your mistakes and gaffes and misunderstandings is so deep and so plentiful and so full of material, that it's a bloody Saudi Arabia of idiocy.  If I milked the well like you will repeat nonsense about me over and over, we would need a separate thread just for that.  Repeat every mistake and gaffe and misunderstanding you made back to you 20 times and we would end up with a thread that is 500 pages long.
I think you would find,that most of the thread would be full of your mistakes,as i keep proving you wrong with many of your idiotic comments and claims--like the most efficient JT circuit.
QuoteAnother vain idiotic feign at misdirection.  You know that I am not interested and you know I have no equipment.  Every time you say something stupid a bell rings somewhere.
So says the book worm :D
QuoteSure, your sizzling brain learned more in the past three months than you learned in six years worth of staring at spinning pulse motors spin.  Why don't you just smash your oscilloscope, it's a waste of time.
You are a coward.
Why do that ?. Do you think it is producing it's own CEMF,and screwing up the measurements?.
Brad
Brad:
So you are still a coward.  You are afraid to illustrate your "theories" with concrete examples.  Instead, we get some mindless diversionary trash talk revolving around the usual "you don't do experiments" nonsense.
QuoteYou mean like--if at the end of the first time constant,the EMF induced current is 25 amp's,then the CEMF current will be 75 amp's,and we can charge a battery for free?
Make a graph of current vs. time for the alleged "CEMF current" and the EMF induced current and show the world what you mean.
Oh, you won't do that?  Then that means your proposition is a fail, your theory is junk, a mistake.  You are just too afraid to admit that.  You are a coward.  You are weak.  You are a fraud.
QuoteAre you taking me up on my challenge then MH--so as your not seen to just talk the talk
And once again we see you duck.weave,and dodge any challenge that is presented to you--you always have,since the day you joined this forum.
How about this Brad:  Straight to your face, NO, the answer is NO.  For the tenth time, I don't have any equipment.  Pound that in to your frying brain.  Does that sound like "ducking, weaving and dodging" to you?
QuoteLike i said MH,send me the ideal 5H coil,and we'll get started--or do i have to use an imaginary one?
You have to use an imaginary real coil, and you have to use an imaginary ideal coil.  Draw a set of graphs showing current vs. time for the "CEMF current" and the EMF current for both types of coil to back up the statements that you have made multiple times.  Illustrate your proposition using your intellect only.
QuoteYou used those numbers to try and make my statement look stupid.
No, I used those numbers for illustrative purposes only and it was late at night and I was very tired.  You are talking paranoid delusions.
Right now your statement looks totally stupid, it doesn't make sense at all.  You don't need the illustrative numbers I made up to create that impression.  Correct ratios won't make any difference.  Draw up two graphs to back up your own statements to prove me wrong.
One more time for good measure:  Oh, you won't do that?  Then that means your proposition is a fail, your theory is junk, a mistake.  You are just too afraid to admit that.  You are a coward.  You are weak.  You are a fraud.
QuoteSo says the book worm
This "book worm" could whip your ass on a bench any day of the week with one arm tied behind my back and blindfolded, even though I haven't been on a bench in 25 years.  You say crazy things like there is no voltage drop across a resistor, or a battery across a coil doesn't constitute a current loop.  I would spin circles around you and leave you dizzy.
What's so annoying is that you are a fraud just like some YouTube free energy pitch man is a fraud.  You have the same M.O. but you aren't asking for money.  But you play the same game of evasion and deflection and do whatever ass-backwards-bending you have to do to save your fragile ego.  There is basically no difference between you stalling and deflecting when asked to graph the current vs. time to illustrate your "theory" and asking John Rohner to measure power-out vs. power-in on his fake Papp engine.  Neither will ever happen and in both cases it's a form of fraud, one is for money, and one is pure intellectual fraud to save your fragile ego.
If you admitted that you were wrong you would probably have a nervous breakdown.
Brad:
You can hate me all you want, but what I hate is intellectual dishonesty.  Look at your response to the sim that Poynt made, you just talked useless trash talk about the inner workings of the sim itself, which of course you haven't the slightest clue about at all.  That way you avoid actually talking about the real subject matter - the results of the sim as it relates to Poynt's interesting question.
I get the feeling that you were the type of kid that when playing checkers with your friend, if you were losing then you just hit the board with your hand and sent the pieces flying and ruined the game.  Better to ruin the game and act like a bully than actually lose and being seen as losing.  That's the vibe I am getting from you.
Look what your belligerent attitude has gotten you.  Endless frustration when trying to discuss things with you, and obviously your attitude hurt you as you grew up.  You were too self-assured and too "smart" to learn things willingly, somehow you always "knew better."  You definitely "knew better" when it came to language and now you are reaping the results of what you sewed.  And here is the real kicker when it comes to that sensitive issue:  The information age started 22 years ago, time flies.  22 years ago you may have come to the realization that the written word was going to be more important than ever.  People would be submitting work reports online, your peers and your bosses would be reading them.  Everybody started using email.  One would think that you would have woken up in 1994 and said to yourself, "I need to kick myself in the butt and finally fix my spelling and diction issues because it is now going to be more important than ever."  You were a fully grown man 22 years ago.  But that didn't happen.
