24/365 solar cell output theory and experiments
Started by lancaIV, June 23, 2016, 07:30:16 AM
safety standards (pace maker ?)and EM emission efficiency ? :
https://web.archive.org/web/20070721102613/http://www.1000inventions.com/country.htm
196 ELECTROMAGNETIC INDUCTION FOR DOMESTIC APPLIANCES H Henrique LAVIGNE Brazil
The problem to be solved:
Electrical home appliances are heavy (each one with an electric motor), they are linked to the electric net with uncomfortable wire, and they are not waterproof.
Description:
House electrical appliances such as blenders, mixers, etc., that can work without wires, attachment or buttons. They use the same motor which is not visible. They work with electromagnetic induction by proximity. They are waterproof and very light.
Presentation:
An electric motor, hidden under a table cover, moves an electromagnetic attachment that can alternately put into action, by induction and proximity, home electrical appliances or tools without wires, such as blenders, mixers, etc.
only 1 electric motor for all rotating kitchen appliances ?
then I prefer this one http://www.freepatentsonline.com/5463914.html
Application:
Home electrical appliances, electronical instruments and electrical tools.
Advantages:
Besides improving the aesthetics of the apparatuses, by eliminating wires, it turns them waterproof, easing their cleaning because the electric part is all closed, without holes for buttons, keys or plugs. They are lighter (no motor) and cheaper.
              It is easier and cheaper only to optimize one device than the total household !
Eliminating  energy wasting sources,making probably waste/garbage to energy(biocomposter,
Waste-Plasma-Incinerator)
                       0,8 KWh per day   http://mtbest.net as future standard !
                            Why not ,where the sun shines so often and long !
                            Natural  -    or artificial !
                       0,08 KWh per day                              as Generation Next-standart !
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=20100520&CC=DE&NR=102008057187A1&KC=A1#
similar
https://www.pads.com/resources/customer-stories/cool-earth-solar
1 sqm photo-(thermo-)  voltaic cell  as round tube by U = 2 x pi x r =  1 Meter high and 32 centimeter diameter
On 1 sqm cave/ floor ground can stay by A= pi x rv2 ~ 10000 sqcm/815 sqcm ~ 12 tubes
If the conventional solar cell full energy gain in hours is calculated with 900 h from 8766 h per year time,
artificial 24/365 photo-(thermo-) voltaic devices gives for the same area
( 8766/900 ) x 12 ~ > 115 times more energy gain per sqm per annum
by higher conversion efficiency technology this number increases by ?/ 15% actual conventional market efficiency
30%/15% = factor 2 x 115
45%/15% = factor 3 x 115
15% standart : before 115 sqm area to 1 sqm area for the same annual output = KWh electricity generation
Next geometrical optimation : from 1 meter tube  high to 1,5/2/2,5 meter high
With such efficiency market entry
https://www.greenoptimistic.com/green-ferrite-solar-cell-japan-20110920/
the before/after area ratio :  > 1000/1 by 2 meter high tubes
Probably I will get today 23 GB info about 60% conversion efficiency graphit cells in pre-industrial development and this would theoretically mean :60%/15% x 115 x 2 meter = 920 x energy gain per sqm area/year improvement
60% = between
https://scitechdaily.com/new-solar-energy-device-is-100-times-more-efficient-than-previous-design/
actually "2%" and predicted 10 fold = 20% conversion efficiency
and                                          Up to 92%
https://www.graphene-info.com/nanotech-engineerings-92-efficiency-graphene-cnts-solar-panel-claim
and                                         UP TO 97%
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=14&ND=3&adjacent=true&locale=en_EP&FT=D&date=19910228&CC=DD&NR=287597A5&KC=A5#
Important are clearly also converter longetivity and technology failure knowledge :
https://www.aau.edu/research-scholarship/featured-research-topics/making-solar-panels-last-longer
We are not in hurry to reach the 1000/1  ;)
A nice and peacefull sunday ( cristian hemisphere) wishing
p.s. :
for some in hurry , 60%/15% x 115 x 2,25 meter tube ( 2,3-2,5 mtr. conventional construction room high) =  ::)
http://heatstick.com/_GlowWarm.htm.  photons/phonons/excitons conversion   efficiency in in/out put Joule. ?
   ELECTRIC CANDELA TUBE
https://www.cam.ac.uk/research/news/hybrid-materials-could-smash-the-solar-efficiency-ceiling
the physical/ chemical border line between " an- and organic : hard/soft/hybrid" !
