use pulleys to multiply total # of rotations = AC electricity
Started by that_prophet, July 02, 2016, 11:35:19 AM
that_prophet
OK then, how do you explain away the 1000's of units of AC electricity, that I can get from the one spark of DC current = The cost for turning the 100cm circumference pulley over once. The AC generators are running free of torque, as they are just winding up massive voltage, and torque is only needed when you generate power, which equals voltage time current, and since we only need to generate one spark of current,(which is practically zero) to drive the input motor to rotate one single time, force = practically zero X 1000's of volts, still equals practically zero. And by the way, what exactly is it that we need to crank over the DC motor once,,, massive voltage, which is exactly what we have generated from our many AC generators.
Quote from: webby1 on September 23, 2016, 07:46:25 AM
I outlined a method YOU could use to build this and test it for yourself.
I think you need to build one before you post anything more on the topic.
 ::)  http://maddsci.tripod.com/george/id11.html
A super-power DC motor for cars, trucks, boats (even aircraft carriers), and planes?
a
disk rotor magnetic motor which, although not free, can outperform any existing electric motors now in use or undergoing testing by a factor of at least 1000 in terms of torque out for watts in
Simple truth,commercial of no interest ! :'(
that_prophet
Sorry, but I cannot believe that everybody is so fooled by the pathetic lies of evil spirits. This uses the simple mechanics of only rotating one large 100cm circumference pulley once, which by simply switching to a 1cm circumference pulley, can multiply your rotations by 100. This 100 rotations can easily be turned into 100 units/cycles of AC electricity, by simply connecting an AC generator to your small 1cm circumference pulley. If you only have to put one spark of current into a DC motor, to rotate a 100cm circumference once, and this gives you 100cm of moving belt. Then you run this 100cm of moving belt by a 1cm circumference pulley, with an AC generator attached, wouldn't that give you 100 cycles/units of AC electricity. That's one spark of DC input returns you 100 units of AC electricity. Now,,, try and tell me that you cannot manage to gain one spark of DC current, out of 100 units of AC electricity. Diagrams + more info on how this works is at http://free-energy.yolasite.com/
Please, don't listen to the torque argument, as this AC generator uses no torque, as it is just winding up massive voltage, because torque is caused when creating power, which is P=IV. Since we only need one spark of DC current, (practically zero) and massive voltage times zero current is equal to zero power = zero torque. You are just winding up massive voltage to crank over your DC drive motor with the large 100cm circumference pulley attached.
                                                           :P
                 https://www.google.pt/search?q=gewitter&client=opera&hs=YXr&tbm=isch&tbo=u&source=univ&sa=X&ved=0ahUKEwjQgdOolL3PAhVHvRQKHXSQCkAQsAQIJw&biw=1024&bih=637
                                       Flash/Blitz and Thunder/Donner
                                                      Kraft/Crafft
https://www.google.pt/search?q=tornado&client=opera&hs=F2W&tbm=isch&tbo=u&source=univ&sa=X&ved=0ahUKEwiMt8zQlr3PAhUIchQKHfEXDf4QsAQIKA&biw=1024&bih=637
                                       Og/"Auge"= Moment/Kalmen
https://www.google.pt/search?q=hurrican&client=opera&hs=Njr&biw=1024&bih=637&tbm=isch&tbo=u&source=univ&sa=X&ved=0ahUKEwjA-LyGl73PAhXHaRQKHW1yAY0QsAQIQg
                                                Hurrican,Furacao
                                       vertere/drehen/turning =torque       TORKELN,
        hicks ! (what a drunken human does)
        but also: Gyro-........
        Sufi/Safi-Derwisch-Dance
https://www.google.pt/search?q=gewitter&client=opera&hs=YXr&tbm=isch&tbo=u&source=univ&sa=X&ved=0ahUKEwjQgdOolL3PAhVHvRQKHXSQCkAQsAQIJw&biw=1024&bih=637#tbm=isch&q=gyroscope
                                  Mr. Joe,P=IU Amperage/current and Voltage/tension
A nice,productive,week wishing
                                                 OCWL
citfta
Quote from: that_prophet on October 02, 2016, 06:03:22 PM
You have absolutely no proof that any of this statement is true.  Anyone that has actually worked with AC generators knows that you are TOTALLY wrong with your ridiculous theory.  As soon as you try to do anything with that great voltage you think you are going to get then there WILL be torque.  That is one of God's basic laws and to deny that is to believe the lies that satan's spirits are telling you.
