Free energy with Seesaw and Kinetic movement
Started by vikram_gupta11, October 15, 2016, 11:22:12 AM
vikram_gupta11
 Dear Sir,
the model is almost done  I have tested it with my hand power and it is working after notice the velocity of balls and hitting the side wall of tubes. but I'm trying to attach a motor of 1 watt input force to run it and the kinetic energy of the balls are as per my calculations.
So now I'm confident that this will work.
Vikram
Low-Q
Hands ar far from accurate measurement tools. Hands doesnot even give you an indication.
Hook up the output from the seesaw directly back to the motor with wires. If the motor goes crazy and and don't stop to accelerate, you got over unity.
I guess the opposite will happen - the motor will stop.
Good luck
vikram_gupta11
Dear Sir,
you mean ,the motor that is providing input will be stopped  when balls will strike with side walls of tubes as I would like to tell you that I don't have piston generators to get electricity out from the system.The only problem I have is non availability of piston generators.
Please tell me what is your indication .Is it about  input motor or about piston generators . if your indication is about piston generators then I assure you that this device will work and if it is about input motor then again I think you are wrong.
Vikram
Low-Q
Do you have a supplier around that have plastic tubes? I thought if you wound magnetic wire around them, and put a magnet inside, they would act like a piston generator. I have tubes, magnets and copper wire, but I do not want to waste more time in building things I know doesn't work. But you are free to try it out when you have the necessary equipment. Maybe if you buy one flashlight that have piston generator, you could try the concept.
Vidar
