TD replications
Started by Floor, November 18, 2016, 11:14:23 AM
Floor
Its been on the test bench and insertion and or removal of the out put
magnet is > 5 grams at either end (start end or finish end of output travel).
                             link here at O.U. dot com
https://overunity.com/16987/td-replications/msg556837/#msg556837
P.S.
this topic is now back open for discussion
   floor
norman6538
1. is  the stack underneath really necessary?
2. the text says the magnet travels from left to right (because like poles repel on the left and opposite poles attract on the right ) but the red arrow goes right to left.
Is that a mistake?
Norman
Floor
1. Yes.  The stack underneath is what makes it possible to remove the
output magnet while it is so near to the end of its run.
2. Thanks.
Yes, its a mistake.  But not in the way it might seem. The output magnet travels
in the diagram from right to left, like the arrow, not as in the text as was written.
the text is corrected below.
Floor
The output magnet must be stopped / manually blocked at that 1/16 inch from
the end on the left, or else the magnetic forces will cause it to travel too far.
Beyond or before that point (1/16 inch from the end), insertion / removal
(most importantly at that end, is removal ) is affected adversely.
At the other end, insertion is adversely affected, if its either side of 1/16 inch.
Floor
partial quote
Quote from: Floor on April 16, 2021, 07:32:44 PM
correction
That's < 5 grams
floor
