TD replications
Started by Floor, November 18, 2016, 11:14:23 AM
Floor
Before I follow through with these particular measurement sets...
I need to build some special fixtures / modify my test bench.
               because
1.
I'll need to quick change / remove the ceramic magnets from the "track" between
measurement sets (they will demagnetize / change each other if I leave them in
place for very long).
2. I need to set up to maximize the travel length on the test bench sliding unit.
3. I need to build some test bench attachments / fixtures.
          So.....
before I do that...
I want to do / finish the measurements @
https://overunity.com/18551/magnet-shear-to-direct-pull-work-ratio/msg548052/#msg548052
               (while the test bench is still set up like it is now.)
       best wishes
      floor
Floor
Still working on the other project...
Floor
This magnet device / method tested out as more mechanical work out
than in.
https://overunity.com/18551/magnet-shear-to-direct-pull-work-ratio/msg557293/#msg557293
I found that the patent has expired.  Users should verify that for their self.
I will be back to this topic tomorrow.
            floor
Floor
This build of this GoToLuc design modification begins at this point
(below) in the topic...
https://overunity.com/16987/td-replications/msg556715/#msg556715
This is only a few pages back.
I don't know how far I'll get with this today,  but Maybe pretty far ?
   best wishes
        floor
Floor
Made good progress today..
Jpg / photo below
