GEM=(Geometrical Electricity Multiplication)
Started by that_prophet, January 18, 2017, 05:13:14 PM
that_prophet
http://free-energy.yolasite.com/
.    This works on the simplest of pulley mechanics, to multiply the # of rotations + by attaching AC generators, we can actually multiply AC electricity. It can get away with seemingly breaking the laws of thermodynamics, by using simple pulley mechanics to multiply your total # of rotations. That can be significant, considering that AC electricity is created using rotations, and the more rotations equals the more AC electricity. If you use a DC motor to drive a 100 cm circumference pulley for one complete revolution, it only costs you one single spark of DC current, spark=(the small amount of current that it takes to revolve one full time)  to give you 100 cm of moving belt.
.    Then all that you have to do is add an even larger belt, and run this length of 100 cm of moving belt past 1 – 10 mini-pulleys of 1 cm circumference with AC generators attached, you can gain 100-1000 units/cycles of AC electricity. YES,,, that's a return of 1000 units/cycles of AC electricity, all for only one single burst of DC current, the small amount that is required to rotate the motor one full rotation. It is truly that simple,,, and why hasn't anybody figured this super simple free energy technology before? It is because evil spirits are still, and have been trying their hardest to hide this technology from us humans.
.    How can you explain away this simple logic, of trading one rotation of a DC motor, for 1000 rotations of AC electricity. HOW CAN YOU NOT MULTIPLY YOUR AC ELECTRICITY,,, and you could be multiplying it by even greater factors, if you added a larger drive pulley, or more mini-pulleys of 1 cm circumference with AC generators on the same belt.
.    Satan + his fellow evil spirits have been pulling the wool over our eyes for too long. Please, join me in defying the evil rule on this earth, and not only help stop funding terrorists, but help us gain the advantages of anti-gravity.
-   I say this because I found this ancient technology in the Holly Bible = Ezekiel 1:16, where he is trying to describe what a running UFO motor looks like. "a wheel in the middle of a wheel", or as I pictured it,  a small wheel, running on the inside of a large wheel. But, since I did not have that ability to have a small wheel, running on the inside of a large wheel, I decided to go with a pulley, and have both wheels=pulleys run inside this larger belt.
.    Is not this sooooo simple, that it aggravates you to hear that this has been in the Holy Bible since the times of Ezekiel? I hope so, and that it proves to you that there is a most powerful spiritual warfare going on behind the scenes.
.    How can you not gain massive amounts of AC electricity, when you only pay for one rotation, and through simple pulley mechanics we can multiply our AC electricity by 1000's of cycles.
   There is no torque problems, because these AC generators take practically no torque to rotate. They are like free running motors until load is put on them, and because you have 1000 rotations to only generate one small bit of DC current, when divided out by 1000, each rotation does not cost practically any torque.
PLEASE,,, we could all be building our own AC electricity generators. We could start new industries, building all of our electric tool, toys + appliances, with self powering GEM motors in them.............
+ think about all of the pollution that we could be keeping out of our air, by making GEM motors for our automobiles
that_prophet
Quote from: Dog-One on March 07, 2017, 07:08:15 AM
Joe,
You're not seeing the obvious.
With a generator having a large pulley, it is easy to turn it.
A motor with a small pulley makes it easy for the motor to turn a load.
Your setup is ass-backwards.  You have the motor connected to the
100cm wheel which means the slightest resistance on that wheel will
make the motor impossible to turn.  Then to make matters worse you
have ten generators with small pulleys; again if these generators have
the slightest load on them you have no leverage, no torque to turn them.
Even if the generators have zero load, the bearing resistance will be
enough to where the large wheel skids instead of turns them.
No, my setup is just right, I happen to be trading one rotation of a DC motor, + a large pulley,
For massive amounts of rotations of many small pulleys, with AC generators attached,
Returning me massive cycles of AC electricity
What you are stating is attempting to use mechanical advantage completely
backwards.  Instead, at every point you are creating a mechanical disadvantage.
I don't even have to get into the electrical side of your GEM, I can see
mechanically you have everything flip-flopped.
I happen to be trying to multiply the total # of rotations,
+ by adding AC generators, multiplying the total amount of AC electricity.
By trading one rotation of a large 100 cm circumference pulley
For 100 rotations for each of the 10 small 1 cm circumference pulleys = 10X100=1000
That is trading 1 rotation for 1000 rotations = using simple pulley mechanics
+ by adding AC generators to these 10 small pulleys, you are multiplying your AC electricity
And there is no torque problem, as these AC generators are just winding up massive voltage
As they only need to generate one spark of DC current,
Which is all the current needed to rotate you DC motor one single time
+ you get 1000 revolutions of your AC generators,
To add up to the one spark of current needed
That is one small bit of DC current,
Divided by 1000 cycles of AC electricity,
Which is equal to practically nothing
ramset
Joe
working on getting you that Sim so you can model these things
trying to get one with some support so you can get help working with it.
any questions let me know
I have been getting ready these last few days for a very strong storm which could collapse some of my Outbuildings
the storm is here now [2ft plus snow upto 80 MPH gusts
will touch base tomorrow [if I still have power....
thanks for your patience
respectfully
Chet K
Thanks Grandma
that_prophet
Thank you Chet,
all that I can think of is, as long as it can handle many different size pulleys,
with many AC generators attached
I can't see why others can see this,
you are trading one rotation of a large pulley,
with the 1000's of revolutions that you can get from 10 mini-pulleys
you are creating massive voltage = electrical pressure
with your 10 free running AC generators = 10X100=1000
to generate the single bit of DC current that is needed to drive your DC motor one revolution
Sorry to hear about your storm troubles
+ sorry for not being here on Sunday, if you phoned then.
I was out to Church, + then visiting my ex-wife
Quote from: ramset on March 14, 2017, 10:37:48 AM
Joe
respectfully
Chet K
that_prophet
This uses the 100 cm of moving belt that comes off of one single rotation of a large 100 cm circumference pulley to run past 10 or multiple # of small 1 cm circumference pulleys to multiply your total # of rotations. Then by simply adding AC generators to these small pulleys, we can multiply the amount of AC electricity. Yes, by adding multiple small 1 cm circumference pulleys to the same belt as the large 100 cm circumference pulley, we can multiply the # of rotations, and by adding AC generators, we can multiply the amount of AC electricity. On one half of this system we are using the 100 cm of moving belt, to wind up massive voltage, by multiplying the # of rotations of free running generators on many small pulleys. Then, on the other side of this, we are using the high amount of voltage to rotate the large 100 cm pulley one single time.  These many small pulleys run free of most any torque, because they are only winding up massive voltage, and only need to generate the small bit of DC current, that is needed to rotate the large pulley one single time, producing 100 cm of moving belt. I can say this because torque is needed to generate power, and P=IV, which is, power is equal to "I"-current times "V"oltage. Since the current is practically zero, and zero times even massive voltage is still equal to practically zero power=torque. http://free-energy.yolasite.com/
