Magnet force shield
Started by Floor, January 21, 2017, 11:14:49 AM
norman6538
Floor none of the above drawings are what I did. But here is what is used for testing.
http://overunity.com/17097/magnet-force-shield/msg498602/#msg498602
text at top 2 large magnets (as repel poles)
text  at bottom 5 small magnets
And your text said "pull the center magnets toward you"
which turns the repel force on and push it back into place to turn it off......
so here is the sequence that would show work done by the permanent magnets.
1. easily pull the magnet toward you with the
repelling magnets held in place and then
2.  release them to do work and then
3. you can easily push that magnet back and
4. move the work done magnet back in place
making a full reset to repeat the steps.
Norman
Floor
One more for the road
                     floor
Floor
@Norman6538
Was there a balance (nearly) between the attractions and reputations as you
withdrew the mid magnets.
If so, there will be no sticky point, unless the magnets accidentally are allowed to
move side ways or to twist.
What did you observe, specifically ?
norman6538
Attached is a photo of my setup. I used 2 7/8l x 1 7/8w x 3/8 thick magnets  like poles facing each other. and a magnet stack 1 1/4 long   7/8 w  3/8 thick. The magnet stack is surrounded with thin white aluminum like rain spouts. You can see N marked on the
left and S on the right.  The black on the right is tape and glue to hold the magnet
stack in a firm position.
The magnet stack is mounted so it swings toward the camera
and as you can see it is sitting at the sticky spot half way pushed out.
I will make another setup with a magnet stack longer than the repelling magnets to see if that changes anything.
Norman
Floor
Thats a trip Norman.
I don't know what is what in your photo, but I can tell you this much,
I don't think I can get any data and / or expect that your set up has
any value to the topic as an "experiment".   Its not precision enough.
If building is not "your thing" you might be better off  in hiring someone
to build a test device for you.
                     thanks for the attempt any way
                regards
                     Floor
                  PS
                I built my test device over a 6 week period.
                Lots of hours (over 200) to design / build it.
