re: energy producing experiments
Started by Delburt Phend, February 04, 2017, 09:31:19 AM
Delburt Phend
We know that kinetic energy is not conserved in motion alone. Kinetic energy allegedly gives off heat when small objects strike large object. This excuse of heat is negated in this experiment because there is no motion loss when a small sphere interact with a larger cylinder (twice).
If energy were conserved when the cylinder gives its motion to the spheres only a fraction of the motion would be contained by the spheres. The motion would not be available to return all the motion back to the cylinder and spheres combo. It would actually take 18 frames to cross the black square in this experiment; if energy were conserved.
The crossing of the black square in four frames at the beginning; middle; and end: is consistent with Newtonian Momentum Conservation. And the energy increase is about 450%. But this 450%  is very small compared to other arrangements.
Delburt Phend
A 305 gram mass moving 5.02 m/sec will combine its motion with a 972 gram mass at rest; the combined mass of 1277 grams will be moving 1.2 m/sec. This is not a debatable statement: it is the Law of Conservation of Momentum. If you know the velocity of the combined mass you then know the velocity of the incoming small mass.
You can count the frames as the black square crosses from side to side (four). By measuring the velocity of the spinning cylinder (1.2 m/sec) we then also know the velocity of the spheres (5.02 m/sec); when they contain all the motion.
The energy of the larger combined mass is .919 joules: the energy of the spheres is 3.85 joules. The energy increase is proportional to the mass difference.   1277 g / 305 g = 3.85 J / .919 J
This event has no mass limit; the sphere could have a mass of 305 metric tons. The mass difference can be very large; the spinning wheel mass could be 30,500 metric tons. A tower of dropping masses can increase the time over which the force acts; the energy increase would be 10,000%. The 305 tons can be throw up ever two seconds; and then output would be measured in megawatt-hours.
The output: construction cost; and maintenance, would be similar to a hydroelectric plant.
http://hyperphysics.phy-astr.gsu.edu/hbase/balpen.html
Note the word 'inaccessible'. The energy is inaccessible; it cannot come back. The motion energy would disappear: it is inaccessible.
But the experiments show that there is no loss of motion. Energy conservation is a false concept.
Delburt Phend
Accelerate a bar so that it is moving perpendicular to its length. Accelerate the bar to 1 m/sec and then catch it on the end so that it must rotate around one of its ends. When the bar starts rotating on one end the center of mass will continue at the same speed; in this case 1 m/sec.
When the center of mass continues at the same speed the energy of the bar increases to 133%. For energy to remain the same (when the rotation starts) the speed of the center of mass would have to decrease by 13.4%. The fact that the speed of the center of mass does not decrease means that energy is not a conserved quantity.
Momentum conservation always overrules energy conservation in real experiments.
F6FLT
Quote from: Delburt Phend on August 18, 2018, 09:42:42 PM
A 305 gram mass moving 5.02 m/sec will combine its motion with a 972 gram mass at rest; the combined mass of 1277 grams will be moving 1.2 m/sec. This is not a debatable statement: it is the Law of Conservation of Momentum. ...
You can't combine the momentum or kinetic energy of separate parts to have that of the whole. The analysis of the law of conservation must be made in the same referential frame, preferably an inertial frame, and the speed applies to the center of mass. Energy/momentum depend on the referential.
Quote from: Delburt Phend on May 19, 2018, 11:51:52 AM
https://www.youtube.com/watch?v=8Q7L2BOYkjE
I see nothing else than energy and momentum conservation.
What makes you think that the potential energy of the cylinder that is used when falling to feed the movements of the ball would be less than the energy acquired by the ball?
Delburt Phend
Is the frame an excuse? Is the frame something used by the smart people; to explain why the rest of us don't understand things that are perfectly simple. F = ma is perfectly simple; I see no need for it to be framed.
The problem with Q7L2BOYkjE is that the cylinder is still accelerating toward the ground. But I think we could take a snap shot in time where the cylinder is stopped; both in rotation and in falling: and at that point the sphere has all the momentum and or energy. So what is conserved all the momentum or all the energy; does it have all the mv or all the 1/2mv²? The proof of which one of the two is conserved comes from another experiment: the double despin     https://www.youtube.com/watch?reload=9&v=YaUmzekdxTQ
At two points all the rotational motion is in the spheres and (twice) the spheres give all the motion back. Two small masses restart a much larger mass: experiments prove that only linear Newtonian momentum is conserved when small masses give their motion to larger masses.
In the Dawn mission yo-yo de-spin; three kilograms stops the rotational motion of 1420 kilograms. If the initial average speed was one meter per second then the initial momentum around the arc of the circle was 1420 units.  When the rotation of the satellite was stopped the spheres had 1420 units of momentum; or 473.3 for each kilogram; requiring a velocity of 473.3 m/sec.
For ½mv² to be conserved the initial energy of 710 joules would require that the three kilograms would have a velocity of 21.755 m/sec. But then the 65.27 (3kg * 21.755 m/sec) units of momentum would have to restore the 1420 units if the weighted cables were left attached; as in the double despin.
By restoring the rotational motion; after the weighted string are left attached, the double despin proves that unlimited quantities of energy can be made from gravitation.
