Light Source from MVP (Magnetic Voltaic Potential) by TLG-team
Started by dr.blue, April 05, 2017, 02:47:44 PM
QuoteIf you have the time and possibility I would request you to measure the MVP in N-S direction (E-W is not of interest).
On the contrary, PROPER CONTROL EXPERIMENTS are always of interest.... to people who actually want to find the Truth, that is. Consider what happens to your "theory" if E-W measurements show the same effects as N-S experiments. By avoiding this proper control experiment you are demonstrating what we call Experimenter Bias, aka Confirmation Bias. You will avoid experiments or happily ignore results that do not support, or that have the potential to invalidate, your dearly-cherished hypotheses.
Further, I will state that there is no reason for _anyone_ to disclose their locations to you UNTIL and unless you first honestly disclose YOUR OWN location.
dr.blue
Dear Mr. Chet
Quote from: ramset on April 06, 2017, 12:28:03 PM
this is a voltage only power/energy source !![the Claimants words]
I would appreciate if you refrained from referring to me as "the Claimant", it has a negative connotation. I would also like to make it absolutely clear that I'm not here to separate anyone from their money, I made a call for data, not money.
Secondly it doesn't make any difference what people choose to believe is running through the wires, it doesn't change the fact that a MVP can observed between two earths, and that it can illuminate some LED's.
If individuals in this community choose not to replicate a simple 2 wire 1 component circuit, and contribute with some data, then further communication seems rather pointless.
Thank you for your attention.
ramset
Dear Mr.blue
I would like  to order your specific LED ,if you provided a link ...I missed it
thanks
Mr.Chet
Ps
as per your above request ?
Done [modified post above]
Thanks Grandma
Quote from: dr.blue on April 06, 2017, 01:43:45 PM
Dear Mr. Chet
So you will of course be giving away your "commercial licenses" and your "consultations" for free, right?
QuoteIf you intend to develop commercial applications based on our work, you will obviously need to obtain a commercial license from us, and most importantly, you will likely require our consultancy services. Please do not hesitate to contact the undersigned in either case.
And it absolutely DOES make a difference what is going through your wires, because your CLAIM is that there is no current and your CLAIM is that it depends somehow on the magnetic field of the Earth. These are CLAIMS that require investigation in order to determine their veracity.
And what about your references to my "CLAIMS"? What is good for the goose is good for the gander. If you don't want people to refer to you as a CLAIMANT, which you certainly are, you should not refer to the CLAIMS of others with that word.
QuoteI deliberately choose not to entertain Mr. Koala's questions and claims, because it serves no purpose whatsoever.
(emphasis mine)
dr.blue
Dear Mr. Chet
Quote from: ramset on April 06, 2017, 01:45:29 PM
At this point it is anybody guess as to which LED's will work, personally I didn't keep track of manufacturers as they all worked with classical current, and that was the only application I had for them in the past. With the limited inventory I have, it's my impression that only every 3rd or so will work, even if it's from the same batch.
Some LED's will work, some will not work, some will only light up once and never work again, some will light up brightly, some will only glow slightly. Some LED panels work, some will not, some will only light up some of the individual LED's, some will... etc etc. But ALL will work flawlessly with classical current.
Therefore we would like to collect data about the LED's used, and maybe we will be able to isolate the exact reason why some work and some don't. The current working theory is that the reason must be found at the atomic level.
I provided a datasheet in my initial post for the 60V filament type LED panels, but that won't do you any good if you have less than 60V MVP at your location.
I have attached a picture of some of my inventory, those on the left work, and those on right don't work (in full), but maybe those that do not work for me will work for you and vice versa, alas additional research is required.
Kind regards
