Investigating the claims of member Synchro 1
Started by ramset, April 08, 2017, 03:31:33 PM
AlienGrey
Quote from: TinselKoala on April 10, 2017, 02:20:45 PM
Well, unlike some other people posting on this forum (without presenting a lick of proof) I do not pretend to "know" how to achieve OU performance in an electrical circuit. Yet!
However I suspect that IF it can be done, it will involve stressing space with extremely high voltage gradients and very fast transitions. See the papers published in mainstream physics journals by Hal Puthoff and Michael Ibison for some hints and some justification for my "guesses" in this matter. Polarizing the vacuum, changing the refractive index of space itself, tapping the real ZPE (not some bogus dreamlike fiction of what ZPE is), entraining environmental energy (as Tesla said "tapping the wheelworks of Nature) ... these are things that will require not only careful and knowledgeable construction of apparatus but also a solid grounding in actual physics. And maybe these things are simply beyond the reach of hopeful amateurs like us, or maybe not. Only careful and knowledgeable experimentation, along with hard criticism when stuff that is simply wrong is tossed about, will have any chance of finding out.
When people here repeat silly conjectures that are easily proven wrong, or buy into bogus models of physical reality that in fact do not represent actual reality, that does a real disservice to everyone who is honestly experimenting along these lines.  Censorship does not help when it is not based in reality. It is important to discuss even the false claims, by showing them to be false so that others do not make the same errors. Claims without evidence, or blindly falling into hopeful belief of fairy tales or money-grubbing YouTubers, can be dismissed as the fictions they are.
So how come Henry Moray managed it? And so did Tesla extract energy from an iron core and early morse code telex transmissions, and why did Gray at Oxford university need to 'doctor' Maxwell's calculations and even Albert Einstein said he found gross errors in Greys doctored publication of Maxwell's publication. ect extra.
They still do it today like the fake news you get on TV like Guys in white hats picking up dead kids from a nerve gas attack, everyone knows Syrian nevre gas is a killer on contact! so are they special or is it a lie.
Regards AG
Regards AG
I just want to repeat a passage from Tesla's patent 512340:
Quotel have found that in every coil there exists a certain relation between its self-induction and capacity that permits a current of given frequency and potential to pass through it with no other opposition than that of ohmic resistance, or, in other words, as though it possessed no self-induction. This is due to the mutual relations existing between the special character of the current and the self-induction and capacity of the coil, the latter quantity being just capable of neutralizing the self-induction for that frequency. It is well known that the higher the frequency or potential difference of the current the smaller the capacity required to counteract the self-induction; hence, in any coil, however small the capacity, it may be sufficient for the purpose stated if the proper conditions in other respects be secured.
(emphasis mine)
The "proper conditions in other respects" refers to the current and the frequency of oscillation. In ANY and EVERY coil.  In the patented winding, the interturn capacitance is increased and so, for a given current, a lower frequency of oscillation is required for this "neutralization of self-inductance" to occur. Also, due to the increased capacitance, the TBF coil's "LC" characteristics mean that the resonant frequency is lower than that of a comparable coil with single winding (which has lower distributed capacitance and hence a higher resonant frequency) when no external capacitors are connected.  Some early texts refer to this _capacitance_ which is able, at a particular frequency, to "neutralize self inductance" as a "negative inductance". In ANY and EVERY coil, TBF or monofilar, just at different frequencies.
AlienGrey
Quote from: TinselKoala on April 10, 2017, 11:23:23 PM
(emphasis mine)
So if there is no such thing as zero point energy where did Henry Moray get it from, and why is Never a Strate Answer so worried about Sun plasma attacks from the sun frying their warmongering space crap ;)? and where does the static electricity surrounding our planet come from, and isn't it the cosmic radiation from the sun's solar winds he was using by somehow turning into it ? which I'm not going into here, but by charging the local area of collection, he would be effectively raising the altitude of his collection dish and since everything is a frequency.
You can find all this information on the internet and the odd statements NASA blurt out and regret later on hence never a straight answer ;)
Regards AG
Where did I say there was "No such thing" as ZPE? Look up Hal Puthoff's papers. What I did say and mean is that most people in these forums who use the term "ZPE" don't know what they are talking about and are making up some fantasy thing they think is ZPE but isn't.
Where did Moray get his energy? I have some guesses about that, but they don't involve either real ZPE or the forum fictitious ZPE.  :o
The threat to satellites, especially those in geosynchronous or geostationary orbits, from solar plasma discharges (more properly called Corona Mass Ejections, CME, or solar flares) is very real, because they are way up in space and are not protected by the Earth's atmosphere and magnetic field as much as we are here on the ground. However, should a big CME strike the Earth, it will still create havoc both with satellites and here on the ground, as enough energy will couple into the wires of the electric grid to blow out a bunch of stuff, including the hard-to-replace grid transformers. Had such a large CME / flare event happened during the Apollo moonwalk missions, the astronauts would have been toast.
None of this is "secret" so I don't know why you bring up the "Not So Amigos" .
AlienGrey
Quote from: TinselKoala on April 11, 2017, 05:49:13 PM
Thanks for defining  an explanation you saved me the trouble although the Atmosphere and magnet field does not stop everything as we are actually bombarded with varying degrees of radiation and it's increasing as petrochemicals destroys our atmosphere and the earth's magnetic field is reported at an all time low ect
I thought an Amigo referred to a man friend so better to be 'not so amigo' as it were  8)
Regards AG
