Why this seesaw is working against physics laws
Started by vikram_gupta11, September 27, 2017, 10:32:03 PM
vikram_gupta11
Hello sir,
I know about it but I am talking about spring based piston generator not coil + magnet.as spring based generator will not create word of the kinetic energy of ball when ball hit it at the time of timing and reversing.
I already mentioned that the kinetic energy can be in increased by adding more box with the top of long tube but input same so the friction of generator can be compensated.
Low-Q
Quote from: vikram_gupta11 on December 05, 2017, 03:24:40 AM
Hello sir,
An ideal spring does not take or give away kinetic energy. The mass will bounce up and down forever like a resonance system. The spring load itself does not apply or help the generator in any way. As soon as the generator is loaded, the spring will not longer bounce freely, but become slower and damped. Se it this way: A load works just like a shock absorber. A shock absorber picks up the kinetic energy so the car does not bounce out of control when driving on a bumpy road. The shock absorber becomes hot, because its job is to introduce friction to the resonance system.
Vidar
vikram_gupta11
Hello sir,
But in this device this will not happened .spring generator means if I use a wall made with flexible rubber and this rubber wall hit a piston generator mounted outside from the device then I don't thing that it will not bounce back.it will definitely bounce back.
One more thing if I use two piston generator mounted on the both end of long tube then the ball will also bounce back after transferring it's kinetic energy to the piston.
No need to worry about bounce back of ball as the counterweight will work to get the seesaw it's original position as there is no hurdle in it.
I have already mentioned that the system will get back it's initial position if ball fall down or doesn't but interesting point is kinetic energy of ball.
Now you will again raise a question regarding load that the load will create problem but ball is free to move in the tube so ball and generator will work separate ly .there will be no hurdle regarding load.
vikram_gupta11
Hello sir,
If you will see closely in the video that ball has been stopped for a moment after hitting with top and again bounce back so  the generator will not work to create hurdle after connecting load .
vikram_gupta11
One more thing I forgot to tell you that when I took counterweight equal to the weight of ball500 gram and tilted the arm then the system get it's initial position also from 120 degree to 360 degree.
Now if I have a spring generator then it will be a mechanical advantage as fall is falling down at the time of tilting and reversing so the ball will bounce back more due to compressed spring .
