Why this seesaw is working against physics laws
Started by vikram_gupta11, September 27, 2017, 10:32:03 PM
vikram_gupta11
I'm insisting to ignore the input energy because there will be need to set up the device only one time as after that the device will get back this position due to itself power.
So energy analysis will also support overunity.
vikram_gupta11
Dear Sir,
I did an experiment regarding input.this time effort was so less that we can drop the ball using minimal input.i just had to tilt the tube only 1 cm.and ball is falling down.
Clearly showing Overunity and solving all problems.
vikram_gupta11
Quote from: vikram_gupta11 on February 09, 2018, 01:10:11 AM
Dear Sir,
I did an experiment regarding input and got success.this time effort was so less that we can drop the ball using minimal input.i just had to tilt the tube only 1 cm.and ball is falling down.
The input can be reduce more.
sm0ky2
What materials do you need to complete the construction of a 'self-running' system?
Springs or elastic materials can be obtained from recycled items.
Or you could use secondary lever mechanisms to store the kinetic energy of the ball,
which then tilt back and reset the main lever.
should be a simple next-step, to test if it can run itself.
vikram_gupta11
Hello,
Overunity is being proven mathematically as well as technically.
See the video.
https://youtu.be/isfw6JMfUbw
See the sketch as per my video.
The ball weight is 400 gram
Distance from fulcrum  of tube 0.35 meter
The ball is resting 1 meter
Now use pythagoras equation to calculate exact distance of ball.
It will be 1.060 m.
Now use torque formula
Torque= rf=rmg
So torque of ball is 0.400*1.060=0.424
So counterweight will be only 424 gram to Balanced the seesaw.
But I took 500 gram to take advantage of heavy counterweight. So seesaw will be tilted .
Now if I am releasing the ball from 1 meter height  and it will travelled 2 meter.
Calculate bthe kinetic energy.
Mgh=0.400*10*2=8 Joule
And counterweight will be rotate more than 180 degree.
The reason is that the ball will have to lift up only 24 gram weight
As counterweight is 424 gram so the will do two work at first it will work to balance the seesaw then the energy will work to lift up only 24 gram weight.
This is the main reason of overunity in it.
