Overunity is it possible?
Started by lltfdaniel1, October 08, 2017, 01:41:49 PM
lltfdaniel1
I am being slapped to say the conversion law doesn't allow this, well the more i see the more i understand.
I wanted to start off with nature it is hooked up to possible equivalent of the zpe.
Positive void vacuum whatever always bangs on the door is all i have to say but is cut off and is incompatible.
This is why the device that show overunity is impossible i can see that but overunity is already achieved in nature i might add this is where the impossible comes from.
O well at the very very best is that it will be used for energy saving methods.
Thing like impossible em drive http://www.popularmechanics.com/science/a24745/science-behind-em-drive/ this idea is born out of nature me thinks and does work.
So the only thing i have proof is that the earth accomplishes the impossible effect that is all the the only proof i have and isn't moot that is where the idea was born out of.
The em drive isn't using the zpe vaccum (negative vaccum/zpe conversion effect) but uses the (generating it self positive equivalent of the vaccum)accelerator wave of the earth with its unbalanced spin and thus doesn't conserve/conversion energy
They should know why it destorys energy in the conversion effect because they will discover it and disprove of the traitors who disprove of free energy wrong especially Einstein wrong as well but is tricky to achieve such a feat.
at the heart of zpe is the conversion effect and there are waves of motion(exactly like the accelerator effect that i am on about with earth or em drive) that disproves of this entirely.
68:16 But by this, THEIR KNOWLEDGE (science - 1 Tim. 5:20), THEY PERISH, and by this also its power consumes them.
twh 1:1 Thousands of earth years ago,far away,in this galaxy,on the morning star(venus),the Lord Guardian Of Divinity,King ruler and Guardian of the Universe,put down a revolution led by Lucifer(Iblis)
lltfdaniel1
If there are no motion in Zpe then the converting or conversion is true because zpe is massless.
Then you will ask what causes the motion where it is tricky to answer and leave you speechless this is power to destory in the motion of waves from zpe, there shouldn't be any motion in zpe i might add by its nature regarding self combustion effect of zpe or consuming.
If you cannot create or destroy then and is correct but that means and is plain to me that it is massless and has no vibration or any motion.Because it is a mimick of the real force.and thus because of cannot create or destroy makes sense to me as why it is an equal force.
But for some reason it goes off to infinity and is hard to explain.
Either way using really simple physics it is clear that the impossible em drive works or the acceleration effect i am on about which is done by the earth for the earth, because it is connected to the opposite effect of zpe it self that is how it breaks the law simply put two different nature of energy.
lltfdaniel1
Just trying to simplify the process if you view it as a magnet mtor or gravity motor then that ios the very same basic physics i am using to apply for this.
If you can see it that way then you can see the impossible effect of the earth so in essence earth is breaking the laws of physics which it is.
A self running heat pump should not work according to the law of conversion..well to my understanding it is tapping into positive vaccum energy which isn't law of conversion and in any case it bypasses this law of conversion with ways off you know beating lenz law, if you can do that then you certainly achieve this and yes it wouldn't work thanks to conversion law but the way it is the heat pump externally gets energy from vaccum and is automatically connected to the positive vacuum which achieves this.
The heat pump beats the law of conversion, do you see where i am going with this?
So your fridge is beating the law of conversion, see?
if it doesn't beat the conversion law then you cannot extract energy from environment.
work it out and in any case i can see it with my really simple physics understanding.
If you know about how the heat pump works then add it to the understanding.
The heat pump has an open circuit which defys the conversion law and is in harmony with the enviroment.
So done with open circuit it returns energy back to nature, which is connected to positive vacuum energy and does not get cut off
so externally you have to collect the energy.
LabDeSyn
Is overunity possible?
Yes! What we call living nature or life, exists only in a state of Overunity.
All living creatures are in fact energy converters.
Our idea about food as input energy is to narrow.
Our idea about physical strength as output energy is to narrow.
Because of that, we don't see the magic happen in our own existence...
Berto
lltfdaniel1
Quote from: LabDeSyn on October 20, 2017, 01:26:02 PM
Berto
The way the heat pump gets hotter to no end in potential is indeed breaking the law of conversion and should be cut off but doesn't regarding the design of heat pump in your fridge that is.
Just like a self running solar panel but done with the heat pump simple to understand and is achievable.
Solutions like the heat pump can be unlocked and used to fully defeat the conversion law to it's fullest.
This zero point force if you can call it a force, is lame. Radiant energy is incompatible energy and like positive and negative following each other, well with zpe being incompatible doesn't follow positive zero point is a negative energy so there must be a positive one outside of the box.
So if you want to think out of the box well it would be hard, i'd start with nature and look closely at nature.
