The Old Standard Ignition System. Battery. Coil. Points. And Condenser....
Started by Magluvin, October 25, 2017, 07:14:42 AM
Magluvin
I was going to save this in case there is a rebuttal to my reply to brad..  But I just cant contain it any longer  ;D ;D ;D ;D   See I do this stuff, like leaving out the balast resistor functions of basically cutting the battery voltage in half for the primary, not commenting on this what I present below of the part of brads post I didnt cover in my reply, so that when the discussion goes on, I have ultimate ammo for my later posts and destroy the target. Ive been doing that for years here and it works very well..   Its not unfair that I do so. Its smart.  If others like Mh and in this case brad, wants to do technical knowledge battle on this field, then I will use this strategy and their own words to beat them..  Truly i dont wish for these battles. But they do occur for many of us.. So take that as a piece of advice when you are arguing something you really know about and someone disputes it. If they do have it all wrong, you will win the battle with these 2 strategical technical battle methods every time. ;) ;)
Notice i didnt say anything to this in brads post....
"Ok,regarding the topic at hand.
The condenser serves many purposes,and here is one to think about.
We all know that if we remove the condenser ,we get very erratic engine running--back firing through the carby-and all sorts.
But how could the timing be that advanced that it would backfire through the carby?.."
This is the reason for the question that is in the end of brads post.....
"What roll dose the condenser play here in this one example?"
What he is trying to imply is that there would be a spark when the points close.  Again,  "What roll dose the condenser play here in this one example?
This has MH all over it to make up a fantasy reason for the cap to say it does something other than help give resonance to the system just like Mh did in his first post!!  Exactly the same motive!! MH splattered all over it. ;) Follow me hear....
The statement was  "We all know that if we remove the condenser ,we get very erratic engine running--back firing through the carby-and all sorts.
But how could the 'timing' be that advanced that it would backfire through the carby?.."
All to suggest that there would be a spark when the points close for the reasons brad described later in the post. He is saying specifically about the timing advance as if the spark did occur when the switch closed, it would be sparking way before the compression stroke completes.. Well then, how does the cap solve that issue if the cap is shorted by the closed points switch? ??? ??  That is what the questions answer is suppose to conclude, that the cap helps in some way to prevent this spark when the contacts close and the secondary 'supposedly' gives a spark!!!!.. ;) ;) ;)   Huge fail and MH has his twisting little finger prints all over it and still cant get it right trying to do so just like in his first post here that I approved for discussion.  And then I destroyed him. lol ;D
Those in the know of this circuit should agree 110%.
Brad, the only way out of this mess is to admit that MH came up with the whole thing and you posted it as your own thoughts.  I know that you 'should' know better than this..   ;)   So here is your chance at an out here..  How do I know that MH came up with that twisted concoction?  Ive been here for 10 years and had a 'Lot' of experience dealing with him twisting things so badly that I just tear it up with his own words just like I did with your post and with his post.  It has his "the cap cannot oscillate with the primary no way no how" all over it just like his earlier description...By way of misdirection. By way of diversion tactics.... I would bet my membership here on this.. ;) ;) ;) ;) ;) ;) ;) ;) ;) ;) ;) ;) ;) ;) ;) ;) ;) ;) ;) ;)
But brad, if your sticking to your post as is, then Ill be waiting for your reply to explain it some how some way to make it right without changing anything.  Been here for what few hours now, rereading and rereading it all including my reply to be absolutely positive on this..  I got it right and you simply do not know what your talking about period. And that is sad if it is so..
Mags
Magluvin
Ya know what people? I have in the past suggested MH is an anti free energy shill. He does not like it in the least and freaks out about it. Well this whole thing here is just one example of why I have had those thoughts....
Think.  Lets say some of you do agree that the cap and primary do oscillate to produce a longer and more powerful spark.  Why is it that MH will go to great lengths to dispute this fact? Why if in his supposed genius big description of how the circuit works, completely and utterly destroys any idea that there would be any AC currents happening in the circuits operation what so ever. In his description there was no inductive actions of the primary in series with the cap when the switch is open and the cap would only ever see max voltage of 12vdc only, equal to the battery voltage meanwhile insists there is NEVER any AC, and the cap is an AC cap that is rated above 100 volts at least and max ive seen is 600vac range Because he is not as good at this stuff like he says he is? Nah. He knows exactly what he is doing. Correct him on that and it doesnt even phase him. He will conjure up another diversion tactic explanation to be completely absent of any resonant oscillations between the cap and primary and also even try to invent other ways of the reason for the cap, and those reasons so far are so ridiculous he has brad saying the cap while across a just closed switch will stop the spark that happens when you close the switch!!! Its so terrible that brad I believe will either not come back here or he will have to own up to the fact that it was all MHs words of purposeful misinformation just so brad can save brads own reputation. Im very comfortable and confident that this will occur. Brad gets up about 4am and comes and reads this and we will see. I seriously dont think brad has any other choice. I dont think brad came up with that scheme. Or is he shilling also? Nah that post is all MHs format, all of what brad wrote. Dont understand why he did that. If MH has it his way, as brads post goes "The condenser serves many purposes,and here is one to think about" he will give any other possible reasons for the cap being in the circuit, even making stuff up that makes no sense at all, thinking none of us would be the wiser, to completely avoid any possibilities of resonance in the circuit..  Darn tootin it was Mhs words.. ;) ;) Brad is way smarter than that. But again why this? ???
If MH is is so good at this stuff, then why cant he see the possibilities of an LC oscillation after the switch opens? Why cant he see that the field that the primary produced in the first place with the switch closed and then when it opens can induce the primary just as good as it would the secondary and pump the hundreds of volts rated cap up to more than 12v at some point in the cycle of operation?? Why imply as in brads post that the cap somehow prevents a spark on the secondary, when we ALL should know this particular spark when the switch closes cannot happen and it does not happen and will only happen when the switch opens, and suggest that the spark is killed off by a cap that is shorted by the same closed switch at the time the supposed spark is suppose to happen as described in brads post? ??? ??? MH THINKS WE ARE ALL STUPID! WE WILL NEVER BE ABLE TO WORK OUT THE ISSUE OF HIS BS DESCRIPTION! Diversion tactics. And if one doesnt work out and he is fully called on it, he comes up with an even stupider one. And then another one and another one.. Its all about keeping on the heat no matter if he is caught in the act, then just come up with a new attack again and again, etc ,etc It is all about destroying the idea of resonance because it does provide a gain as I claim. Every single time I have brought up resonance in the past he has interjected and fights it to a brutal end. He IS an anti free energy shill. I mean hey, if my claim that resonance can give us an appreciable gain is not correct, then he should be able to debunk my claim easily with real circuit descriptions without any flaws, if he is so smart. ;) If I am wrong then brad should be able to debunk my claim very easily also. brad has a scope, works with engines, Im sure he has a coil and proper condenser around. But brad was shilled into posting what he did. maybe the issue brad had with the rotary transformer put him into a position that this is what he does now. I would hope not. Idont know. I like brad. but this here went way overboard and I have to stand my ground. When I posted that he may post his idea of the workings of the circuit, I did say that i would like to see just that, I knew i could beat it because that is how much i know Im right here, and I did just that.   I hope that is not the case and he says he posted what MH was asking him to and didnt pay attn to what it was all about.  I really hope that is the case, because Brads post has just as many seriously bad flaws as MHs post does.
But no. MH cannot debunk my claim legitimately.Cant do it. He has to twist his so called analysis to a point of impossibilities and fantastical functions and operations to try and do so and fail again and again, it is never ending. Cant come up with 1 GOOD reason why my claim is bad. Cant make a clean actual working circuit that explains his end. There is always 1 or more serious problems. And when I bust him on it he makes up another one and still acts as he knows it all and i know nothing. Again, it has to be he is a shill.. Such great lengths to no end.  Gotta be a paycheck at the end of that string he is tied to. If not, then he is just a whack job to the extreme. lol
He at time says he is just here to help people understand electronics and that none of us know anything.  But he cant even admit there is an oscillation between the primary and the cap when the primary dumps its collapse currents into the cap. Simple stuff. He will use the diversion tactic to reduce the possibility to nill to instill this into the reader minds, as can clearly be seen in his first post on this thread, and run off the presenter of the idea with a constant barrage of posts that just overthrow the threads to being useless. Well Im not running away from it like he would wish. Read his first post on the second page.  Its completely devoid of any inductive actions other than the transformer action and that is it. LITERALLY anything to avoid an inkling of the cap being anything but a pathway for the battery alone to "pump" (his words) the primary through the .14uf cap and the cap only ever sees 12v max. Charge the cap to 200v and dump that across the primary. You will get a spark. 12v aint gunna cut it. Its just insane at this point. Respect his knowledge?? lol he knows exactly what he is trying to convince everyone here of. He knows.. If he keeps claiming he is so smart and nobody can even compare, then why would he get this all wrong over and over and over each time he tries? He isnt as smart as he says??  lol it is the other way around, He knows exactly what he is saying, and trying to rely on his statements that nobody here knows anything. Here is an example of that for pms the other day.....
This one is a reply to me...
"Yeah, you don't know shit.  You have been asked to explain the resonance mechanism and you can't do it.  You are unable to explain how a simple circuit with five lousy components works.  I think at this point that all of us would think because of the intensity of the debate that for sure you hooked your scope up to the primary of the coil to see what you would find.  You hooked it up and you tested it for sure.  You had to have done that, it simply doesn't make sense any other way.  And if you saw your holy grail of resonance you would have posted the clip right away and declared victory.  But you didn't see resonance and because you lie and you are unethical, you are doing the only thing you can do now in a vain and pathetic attempt to save face.  And that is to chicken out and lie again and put on airs that you can't be bothered and it's "obviously" a done deal.  It's pathetic and you have reduced yourself to the level of a hapless clown.
You literally cannot cope with saying that you did not find resonance.  You would have an internal mini nervous breakdown if you did - you are blocked.  So the little lying sleazy weasel kicks in because that's the only thing you can do to "escape."  You are pathetic, dude.  Your self-programming is a complete and utter disaster.
You want to prove me wrong that you are not some emotional cripple that doesn't have the guts to back up his claim that he stated over and over?
Then do the test like Carroll and myself are asking for, the simple test that you know you should do and is very easy to do - as per the way things work around here.  Show us how smart you are."
Well firstly at the end, I spoke to carrol on Mh contacting him to post his theory on my thread. Carrol said he had gotten that request but did not reply as he was busy and on the road. And said he will not post it for him. ;) So Mh lies.  Ill ask Carrol to verify that talk between me and him. or any of you can pm him for that answer for your selves. I dare ya. ;D ;D ;D ;D ;D
Unethical??? Well lets see what carrol has to say about that.   ;) ;D
Man not showing the scope shot really has his panties in a bundle. As in, his undergarments all entangled in his crack.  The shots are coming. You probably think I dont know how to use my scope and didnt see it due to some issue or whatever and are counting on that idea so you perpetuate your stance until..... BOOM  your head pops off.  lol  Scared ya that I so far said it showed AC and higher voltages that 12v dc didnt it. lol  Sit on that a bit. Your world is going to change overnight.  ;)
But look how he tries to rip any possibility of resonance(oscillations between the cap and primary) to shreds.
Says in first line "Yeah, you don't know shit.  You have been asked to explain the resonance mechanism and you can't do it. "  Well i have been explaining it since before I opened the thread, which is before he says he AND carrol are asking.  lol carrol knows nothing of this.  ;) Any lengths to hurt my standing on this. Even using carrols name without his knowledge of such, and now he has used brad, and I have to be sure of it from all I have explained here so far.
Here is one to me in pm after the one above....
Well I just asked Carroll if he would post my explanation which will be written in proper technical English when discussing electronics, something that you clearly cannot do.  So when you say, "You cannot even come up with a reason why the circuit has more output with the cap than without," you are lying.  You know you are lying, and we all know that you are lying.  And you make the "condenser play" for something like the third or fourth time.  One more time, you are lying.  You are either a compulsive liar or a pathological liar."
Lol lies then calls me a liar.. thats rich isnt it? How many times here did he make YOU READ that I am a liar??  He is not just instilling the statement, He is installing it. The power of suggestion. Shill tactics 101. Get everyone to believe what you say by saying it again and again and again..... I read a lot of books on hypnosis in my early 20s. If anyone wants to know why, ask and I will post it. Its longer than I want to put here in this post. So ask and I will share that.
Then to me again...
"Now that I have asked Carroll to post my explanation in the thread you are either just balking and being irrational now that you know I am going to write it up, or you are alleging that I have found something online.  You are just lying some more.  And I think you are freaking out a bit because you have been stating all along that I have no analysis and I am bluffing.  You are probably dreading seeing me show you up for the bad and sad clown that you are.
I have been doing circuit analysis on this forum for YEARS and I have rock-solid integrity.  You're a fucking mental case."
He will stop at nothing and lie again and again.  After he reads this, lets see if he can get carrol to confirm any of his involvement as MH suggests.  It will not happen because carrol is not in this with him at all. I know. If any of you reading know him, send a message and ask him.. I will be vindicated and MH will be the liar here. bet on that 100%  lol its just too much ya know?
And then what he says of his years of circuit analysis here??? Well how many fantasy circuit descriptions does he have to come up with to debunk me before this years of circuit analysis becomes apparent to us the readers? ??? ??? ??? ??? ;D ;D ;D ;D ;) ;) ;)   Like I said, I beat him with his own words successfully. A lot!   ;D He gives me all the ammo I need. Its almost too simple, but I have also been here for about 8  9hrs straight. Why? Because it is important that people here know about this. Im not saving my ass. Im helping yours. Didnt save my ass at all. This shop stool is killing me right now.  :( ;D
And here is another one to me after that.. Notice that I have not shown the scope shots yet? lol Remember the 2 strategies for fighting the technical knowledge battles I spoke of earlier?  Well that one is still in the ammo box.  ;) ;D Just waiting for the specific target to be in my sights. I dont care at this point if I say this here. Mh will just pawn it off after reading this as I dont have the shots that shows resonant oscillations, until I do show them.. Then things will change.  You will see this soon. ;)
Lol he even says that even if his analysis is wrong "it's going to make you look and feel like a little clueless peon."  Oh really?  If anyone agrees with that then you need to reread his fake news analysis and then my reply on the second page here very carefully and tell me what you see then.
"Now, are you going to share the fact (that I am almost certain of) that you found NO RESONANCE with your peers on the thread and you are up a creek without a paddle?  Your pregnant pause is about to break water.  Are you going to try to use your noggin by talking with your peers and figure out what your scope shots are really telling you?  Or are you just going to play the sassy dumb ass bitch with attitude like a clown?
And when my analysis does get posted, even if it's wrong, it's going to make you look and feel like a little clueless peon.
Hey Magsy wagsy, how does the resonance work to make the spark stronger?  Doh!  It's LC resonance!  That's the ticket and that's the explanation and I'm sticking too it.  10 bloody years of working on the bench and lusting over resonance and that's all you got?  The forum has people just above background noise, and after 10 YEARS you are about 2 dB above background noise.  Keep winding those coils."
It goes on and on. All to try and debunk a claim that resonance give us a gain. And he takes it all the way and claims that there is no resonance at all.. nuts But not nuts.  He is shilling to the max on this.  This is my solid opinion and Ive said it many times over the years..
Finally, this I predict. When I do the scope vid and show, he will say Im doing it all wrong and make all these different ways to put the scope with added parts for the benefit of the best scope shot reading, meanwhile the extra parts config will  kill off the resonance by way of the funked up design of the so called correct way to use the scope here, that will not show the resonance OR say that what we see is nothing but artifacts and it proves nothing.  lol been there before. I know..  On sunday I will show that prediction come to life.  ;D   ooo this is gunna be fun
Ok im tired and beat, And MH is a shill.  lol Tried to edit this as well as possible. Been here since 8pm doing all these posts looking over it all multiple times and it is now 402 am.  So there may still be some errors.
mags
Magluvin
And Brad, if you delete any of these posts before WE discuss it with Stefan in order to let him be the judge if need be, I will show stefan my page saves as full evidence that this crap is going on.
I promise you that.
Mags
Magluvin
Just went over it all again.
Why am I posting all this? Why am I hammering at it? Because my claim of gain by resonance is real. I am defending it to the hilt. Not one explanation by these to supposed professionals can get it right in their own claims of knowing how the circuit actually works as can be seen too clearly, to be a judge of whether resonance has anything to do with anything here. They havnt shown a workable circuit function theory yet.. But damned to be that the real actual circuit could do anything better because of the cap and resonance, it just has to be another explanation. :-\ ;) At this point they know they cannot change the circuit as thee circuit is well known as to how it is put together. The only thing they can do now is make up some concocted alternative unworkable actions and functions to try and debunk my claim.  Well it is all coming to a head here.  I want to see what comes of all this today before I show anything more with my setup.    Its sunday ammo. ;D
I said before here that I have a dpdt relay with one half of the contacts rigged for buzz mode and the other set of contacts for points switches. Works nice.
Mags
Mags
norman6538
Brad thanks for filling in the numbers to what I described. That makes it very clear....
The Tesla circuit it truly multifunctional and STILL VERY USEFULL  today in our internal
combustion engines.
Its too bad we have to have all this other distraction discussion.
Norman
First thing to do,would to be to look at the ignition coil,which is just a transformer--what is it's rated output voltage?
Most are between 30,000-40,000 volt's
So,the average supply voltage(battery voltage) when an engine is running,is around 14.4 volts.
Lets say our coil is one of the 30,000 volt one's.
The average turn ratio in an ignition coil is around 100:1
So in a transformer sense,100 x 14.4 would give us a voltage of 1440v at the secondary when the points close.-->Remember,we are talking about normal transformer voltage produced here,and not flyback voltage produced across the secondary--which is where the 30,000 volts comes from.
Most plug gaps are between 1 and 1.2mm
It takes 1000v per mm to form an arc within the environment of the engine cylinder  ;)
